Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 06-16-2008   #2266 (permalink)
emjay
Super Member
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
Re: Gone Until July, See you Peeps Later! (Pg. 150) - The Speedfoos' Turbo Thread!!
hey i did research the hondata site i jus wasn't sure if a regular kpro'd 02-04 rsx/type s ecu worked or not .. cuz i can get one on the forums for 1000 bux shipped ... thought maybe the d17 kpro is different ... I don't get why they wouldn't jus sell it as the RSX KPRO and sell the cam gear only .. instead they call it d17kpro lmao making me think its something different .. basically what ur saying is the d17 kpro is exactly an rsx, but they use the modified cam gear .. hmm ? also why does it say the basemap is for d17 NON VTEC? isn't it simply rsx kpro and why non vtec? what happens if u have VTEC ? u jus have to tow ur car?
emjay is online now   Reply With Quote
Old 06-16-2008   #2267 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questioned
I pretty sure the basemap they made initially was done on a non vtec car. I would contact Boilermaker or Andyman they might have a VTEC basemap you could use temporarily. You are correct though Kpro is kpro only difference is you need a special cam gear and change some wiring with your O2 sensors. Its' obviously a little more complicated than that but you get the jist now.
ronaldo9 is offline   Reply With Quote
Old 06-16-2008   #2268 (permalink)
Jza
Senior Member
Jza is just really niceJza is just really niceJza is just really niceJza is just really nice
this better include a shitload of pictures
Jza is offline   Reply With Quote
Old 06-16-2008   #2269 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
No pictures. Text updates only. Like the rest of the thread.
My guess is the reason it's a non-VTEC basemap is because of that very reason. It's a basemap. There are too many variables on a each boosted car to properly program the VTEC engagement for a basemap. Best just to leave it alone since you need to get it tuned anyway.
There is a difference in the programming between an RSX k-pro and a D17 k-pro. They are completely different engines with different operating parameters. I'm sure they could have made k-pro to work with a D17 ECU, however since they already had it for the RSX, it was much easier to simply re-tool the programming to work with the D17. Hence the reason we have to use a special cam gear (an RSX one from what I understand) to get the k-pro to work properly.
The car should be able to safely limp to a tuner with the basemap though.
speedfoos is offline   Reply With Quote
Old 06-16-2008   #2270 (permalink)
emjay
Super Member
Quote:
so foos, u kinda a lil confused me there lol because u say there is different programming ... does that mean i can't buy 02-04 kpro off rsx forums off a member here in toronto?? or i could and just buy the cam gear off of hondata.. and boom there's my kpro for 1200 .. member is selling used 02-04 rsx kpro for 1000 pick up
Old 06-16-2008   #2271 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
It would have to be flashed for the d17 anyway.
Buy a CRV 5 speed ecu from a yard, they're cheaper. Have it flashed, buy cam gear. My whole setup was about $1100 and I have a warranty on the ECU now.
Rufus is offline   Reply With Quote
Old 06-16-2008   #2272 (permalink)
speedfoos
speedfoos's Avatar
There you go. Listen to Rufus. K20 programming is different than D17 programming. You will be buying an $1100 paperweight if you buy that RSX one unless you k-swap. I'm pretty sure a re-flash can be had at a discount if you originally bought the k-pro and are switching engines, but you'd have to ask Hondata about that.
Old 06-16-2008   #2273 (permalink)
emjay
Super Member
hmm..
Old 06-16-2008   #2274 (permalink)
emjay
Super Member
how much does the flash cost??so basically in order to kpro .. i absolutely HAVE to and MUST pick up a donor ecu and have it kpro'd for the d17 specifically... there's no fukin point in piking up the rsx kpro tonight for 1000, i was gona meet him thinking it would work lol but to flash it for d17 .. thats jus extra headache
Old 06-16-2008   #2275 (permalink)
dopes6070
dopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioneddopes6070 should not be questioned
you can buy a RSX kpro and use it with the d17. Thats what I did. I just had to find a place willing to get me the cam gear. Thats the only difference between the RSX one and the D17 one... Well the gear and programming.
dopes6070 is offline   Reply With Quote
Old 06-16-2008   #2276 (permalink)
emjay
Super Member
what do u mean by the programming dopes ... rufus said i'd have to flash and use it with the d17 ... if the programming is different then how can u use it ?? how much is this "flash" i can jus order the cam gear str8 from hondata .. its not a problem .. but wat is this programming ur talking about?
Old 06-16-2008   #2277 (permalink)
emjay
Super Member
http://forums.clubrsx.com/showthread.php?t=577652
Old 06-16-2008   #2278 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questionedandyman97 should not be questioned
Understand. All the ECU's do the exact same thing. Regardless if it's out of a type s or an ep3, the changes are only based on the maps. Basically, hondata, or any tuner, for that matter, takes the base cam angle, ignition, and fuel maps and tweaks them, creating new maps. That's it. Certain maps have certain functions that others may not, but that's why it's important to select the map for your setup straight off when you tune it for the first time.
I ran a k20a2 turbo map for about 2 1/2 hours before my first tuning session and other than being a little rich, the car ran fine.
There is no specific "flash" to the d17. When you have kpro, it's fully programmable. You set up EVERYTHING!!!!!!!! Hondata just offers different maps for different setups that you can load for a closer starting point to fine tune off of. All you do is plug your laptop in and sen the calibration (map) you choose to the ecu and it runs the car.
andyman97 is offline   Reply With Quote
Old 06-16-2008   #2279 (permalink)
emjay
Super Member
andyman ur fukin the angel of boost u make everything so good .. so with that said and done ... i SHOULD go buy that kpro tonight for 1000 dollars rite???? rather then shop around for a donor, send it in blah blahh blah ... i called the guy he told me that he can plug the ecu into my car and show me that it works ... or that he will plug it in his and show it will work ... what do i look for ... i am 100% newb at kpro .. what should i look for to know that the ecu and kpro is fully functionable ... im meeting him at 7:30 guys !! KPRO HERE I COME wooohoooo ... hmm jus a thought, aren't the pins different for the rsx-s ecu and the d17 .. how would it fit be compatible?
Old 06-16-2008   #2280 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
You can't run it in your car without the cam gear, period. What to look for? That it runs his car. Have him take you for a ride and make sure it runs smooth. At least this way, you know the injector and ignition drivers are good and not fried and it reads all of the sensors necessary to run the car. Also, check for CEL's on his dash. If he has any, look at the software and see what they're for.
You're still prolly gonna spend about 150-200 or so for the cam gear, depending on if you can find a hondata dealer that will sell you one individually. If not, you're kinda screwed. I dono tho, I got all of my shit at once when it was brand new.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
