Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 01-26-2008   #1876 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Re: I Hacked the Site and some Pipe - (Pg. 125) - The Speedfoos' Turbo Thread!!
You especially don't want to have a leaky bung hole if you're going to use it as a drain.
speedfoos is offline   Reply With Quote
Old 01-28-2008   #1877 (permalink)
speedfoos
speedfoos's Avatar
I didn't get much done today. I had to take about 2 hours to clean the garage though. The thing is so small it gets wrecked pretty quick and I couldn't find any of freaking tools because I scatter them as I work. But it's clean and I'm back on track. Things I managed to do today was get the 3" flange welded on to my cat pipe - it had a 3" to 2-1/2" reducer pipe on there which is now gone.
Got my secondary O2 sensor bung put in. Funny story. Drilled out the pipe with my step bit, which requires you to use oil. No problem, drill it out, sprayed the pipe down with carb cleaner to get rid of the oil in preps to weld the bung on. Sat down, struck my arc and I'm welding away until I smell something. I stop the MIG stinger and look to my left and don't see anything through my helmet but the smell is worse. Lift the helmet and notice that both my arm and my Black and Decker Workmate are on fire! Too funny! The carb cleaner that was on the surface of my (wooden) Workmate caught fire from the spatter and subsequently caught my jacket on fire, but the flames weren't bright enough to see through the welding mask. I gotta get a better welding table!
Anyway, so the O2 bung is in and I also welded in the slash cut pipe for the new PCV system. All that's left on the exhaust is to get the length of the zig-zag frame transition piece figured out, weld the flange on to it, finish the three welds (just tack-welded now) on it, and weld it the rest of the exhaust. Then it's just a matter of cutting the rest of the SS line for the PCV setup and putting the T-fitting into the brake booster line.
Here are a couple pics. I had forgotten to take the O2 sensors into account when putting in the new drain bung on the pan, but thank the Great Wolf Spirit that it worked out!
And here's my slash cut for the exhaust vacuum source of the new PCV system. And of course, my pimpin' olive drab oil pan!
Old 01-28-2008   #1878 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
Looking good clint!! cant wait to see it in person!!!
filipinop1405 is offline   Reply With Quote
Old 01-28-2008   #1879 (permalink)
speedfoos
speedfoos's Avatar
Thanks man. I'm pretty excited to move back to the states, even if it isn't until September. Because then I get to fix my bodywork for good and get an actual paint job instead of this bondo, flat silver thing I've got going on.
Old 01-28-2008   #1880 (permalink)
Civicman1988
Ultimate Member
Civicman1988's Avatar
speedfoos i need to get going on my project but funds are real low
Civicman1988 is offline   Reply With Quote
Old 01-28-2008   #1881 (permalink)
speedfoos
speedfoos's Avatar
Thank god it's tax season, right?
Old 01-28-2008   #1882 (permalink)
ryox82
Super Member
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Quote:
i understand the feeling! I have a head and a block on the way. Now I was looking at pistons and rods....ugh...700 for fucking rods lol. Tryin to build a motor before I even get a kit. Means it is going to take a bit longer for me to get going.
ryox82 is offline   Reply With Quote
Old 01-28-2008   #1883 (permalink)
speedfoos
speedfoos's Avatar
Supposedly the $400 Carillo F/I rods come out in a couple weeks. I've had Paul reserve me a set. Or Bob is selling his Crowers on Ebay for $415 shipped.
Old 01-28-2008   #1884 (permalink)
ryox82
Super Member
ryox82's Avatar
Is Dezod putting them out on the website?
Old 01-28-2008   #1885 (permalink)
speedfoos
speedfoos's Avatar
Yep, he will be. I think he said he's getting like 5 sets in the first shipment, but it will be regularly stocked item.
Good news is the exhaust is done! It's welded, de-slagged, painted, hung, and bolted in! I don't have any pics because it's really late on a work night, but I'll post pics and a small vid tomorrow night. I just need to finish routing the rest of the PCV lines and put the car back together. Two hours max as long things go well.
Old 01-29-2008   #1886 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
in for pics and vid
tuningmycivic is offline   Reply With Quote
Old 01-29-2008   #1887 (permalink)
speedfoos
speedfoos's Avatar
Fuck it. Exhaust has two pin hole leaks, lower rad hose won't stop leaking (shitty fucking OBX hoses), and my drain line is leaking somewhere. I can fix it, I just wish I lived in a real country, and I am tired of not driving it anymore.
Here's your fucking vid.
YouTube - Happy New Year car explosion
If you are able to see this message it means that you don't have flash installed or that the video server is down.
Old 01-29-2008   #1888 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
bomerman19 is offline   Reply With Quote
Old 01-29-2008   #1889 (permalink)
speedfoos
speedfoos's Avatar
Yeah yeah. I'll bet you were looking for the TNT and det caps when your cam gear fell off.
Old 01-29-2008   #1890 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questionedAlpha 5 should not be questioned
Nice vid. We have all been there.
Alpha 5 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
