Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Reload this Page
Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
LinkBack Thread Tools
Old 01-07-2008   #1846 (permalink)
Jza
Senior Member
Jza is just really niceJza is just really niceJza is just really niceJza is just really nice
Re: Where the F*$% is the Oil Coming From?! - (Pg. 122) - The Speedfoos' Turbo Thread
I'm sure this question has already been asked, but 124 pages of thread is a lot to remember, and even more to look back on. How much HP are you expecting at the wheels here? Would you rather not have done this setup on a RWD or AWD car?
Jza is offline   Reply With Quote
Old 01-07-2008   #1847 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Well, I'm building what I have. Since it's a FWD Honda Civic then that's what I'm working on. Honestly, it's six of one, half dozen of the other as far as what I'm working on. I love the Honda (most of the time) so I don't mind that it's FWD and can't put power to the ground unless you have tires made out of glue.
At this point, I'd be happy with about 220-230 on the dyno with my current setup. If I can ever get this voltage gremlin figured out, I'll dyno it.
speedfoos is offline   Reply With Quote
Old 01-07-2008   #1848 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Nothing like haulin ass in a 1.7 SOHC FWD Honda...especially when you wax a 5.7l v8
Well I now have a small amount of coolant on the plugs.......still no leaking headgasket...holds pressure, no overheats, & no coolant in cylinder. Even after being on plugs. I cannot find anything. Since you had all of the same issues and only a new head fixed, I believe I'm in the same boat.
I believe car heats up expanding a hairline facture in cylinder head causing coolant push. Only thing I can think of. Probably happened at tuner......didn't have these problems before turbo...and I have never overheated it at all!
Just a little update on my ride.......You got DVOM yet clint? Multimeter? Go buy a cheapy at the parts store. All ya need to start electrical testing! I can get ya any schematic ya need. It's just 2 clicks away on my desktop at work
FoSho is offline   Reply With Quote
Old 01-07-2008   #1849 (permalink)
Jza
Senior Member
Old 01-07-2008   #1850 (permalink)
speedfoos
speedfoos's Avatar
My multimeter broke last week and I haven't gotten a replacement yet. Gonna pick one up again tomorrow. First one was a $6 Harbor Freight cheapie, but it lasted for 4 years, so I got my money out of it. And yeah, I've got a Mitchell login and password to pull the diagrams here at home as well. Gonna start with those and see what I can find. I just hate dealing with electronics. I made a thread about it, but there are only 2-3 hardcore circuit heads on the site and they're not around much.
Foos Flaky Voltage Thread
The problem there Jza, is I fed that little bastard some boost after midnight and now I'm left dealing with this.
Old 01-07-2008   #1851 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
thats a badass gremlin.
Well since everyone is stating there problems.. might as well post mine from school.
I had to do an R&R on a little Mercury 2-stroke 8 horse. The little bastard had 5 destroyed gaskets. Then i had some continuous backfire coming from one of the intake port side gaskets. I replaced that, and it kept on backfiring from the same place. It seems that someone had tried re-threading the center hole of that plate cover thing, and did a terrible job on it. So i have to re-fill it, and re-thread it. Also, the engine wont idle, without it being 1/4 WOT, it just sputters and dies after about 2 seconds...
Marine Tech ftw!!... soon ill have threads like the great Foos once made.. or is still making.
DsevenEm2 is offline   Reply With Quote
Old 01-14-2008   #1852 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
hey Clint, damn shipping company bent one of the IM studs in the block, i should be able to straighten it, or replace it at least, im not worried, but since u insured it i just wanted to let u know, in case u want to claim anything, and yes, it got here already, thanks a lot man, good luck on ur trip
and the bent one... not Clint's fault, shipping companies lack of care
greeen01civic4d is offline   Reply With Quote
Old 01-14-2008   #1853 (permalink)
greeen01civic4d
balls in ur mouth
ok, heres the lowdown on ur old head Clint, its .005 out from being true, with an allowance of .002, so i just need to find if having .003 shaved off will be possible, just for when i get ready to boost in a year or so.
btw Clint, here is how "well" UPS handled the package...
note the three holes in the side where the IM studs passed through
anyway, i got a new bolt for a dollar, so no sweat, and i got the old bolt out in a jiffy, good old two bolt trick worked like a charm(yes Clint, u were right again) good luck on ur trip! later
Old 01-15-2008   #1854 (permalink)
LogicWavelength
7th Gen Photographer
LogicWavelength's Avatar
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
I switched all my EM studs to bolts to make it easier to get the manifold off with the turbo and everything. Just figured I'd share.
LogicWavelength is offline   Reply With Quote
Old 01-15-2008   #1855 (permalink)
speedfoos
speedfoos's Avatar
Glad everything is working out Adam. I should think that the head will be fine with that amount shaved off of it. You could clay the pistons to be sure though.
Ben, wouldn't that make it harder to mess with the mani and whatnot? I need the studs to hold that fucker on there during de-installs and all my numerous repairs.
Old 01-15-2008   #1856 (permalink)
greeen01civic4d
balls in ur mouth
yea, i checked, and that much off is fine, its very minimal, all i have to remove is .003", so that is good news, thanks again Clint, u ever need anything, just hollar
Old 01-22-2008   #1857 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
uh...so has the site been down? i thought it was just me..
Old 01-23-2008   #1858 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
I haven't been able to get on for the past week
bomerman19 is offline   Reply With Quote
Old 01-23-2008   #1859 (permalink)
LogicWavelength
Neither have I... ˇViva la revolución!
Old 01-23-2008   #1860 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
same here.....
DaRk_MauL is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
Varnerr88 new jdm thread pictures and talk come on in..
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Lets see those BLACK Civics!!!!!
The Silver Coupes thread!!
Site Supporters
aluminum radiator
Honda car spoilers
