Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-13-2007   #1441 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: How do you spell stop? B-R-E-M-B-O (Pg 95) - The Speedfoos' Turbo Thread!!
Quote:
Originally Posted by speedfoos View Post
Yeah. I usually stop on them when I'm eating and have to pick one out of my teeth.
yea, but it keeps in between ur teeth clean
btw, have u thought to check ur alternator fuse?? mine did that for a while, and i just replaced the fuse, it was like half blown...
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Sponsored Links
Old 11-14-2007   #1442 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Good point Adam. I'll check it today. Thanks man.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 11-14-2007   #1443 (permalink)
speedfoos
speedfoos's Avatar
Well my oxygen sensor bungs came in today. Hooray!
But it's too fucking cold to spend all night welding and crawling under my car tonight. Especially since I can't drink to stay warm due to work tomorrow morning. Ergo, exhaust work gets finished on Friday night.
That being said, I needed some gaskets in preps for this. Now I could have bought gaskets like most normal people, but where's the fun in that? Instead I spent $12 on a sheet of reinforced gasket material (thanks Uncle Summit!) and made my own instead! I was able to get three 3-hole gaskets (would have been four, but I dorked one up) and one 4-hole gasket for my exhaust joints and downpipe.
Materials needed:
- one 12"x15" piece of Mr. Gasket steel-reicforced gasket material
- one Sharpie
- some exhaust flanges for templates
- one hole saw kit
- one pair of tin snips
- one box cutter
- one metal step bit
Too easy.
You've seen this. Draw the gaskets out with a Sharpie. Get them fairly close together for minimal material waste.
Like so.
Draw some simple intersection lines with a straight edge to find the center point of the main opening. Mark it with the aforementioned Sharpie. Clamp the bitch down to your work bench and put the appropriate sized hole saw...
...on to the arbor provided and attach it to your electric drill.
You can use a hand powered drill if you like, but it will take you a very long time to cut through the material, you probably won't get a clean cut, and you will more than likely give up before you finish the first gasket. I used a power drill.
Now cut the holes. Ensure you've put a wood backing down so you don't drill a hole through your Workmate. I weld on mine so I really don't care. The wood is just there since the surface is all crappified and uneven.
Hold the drill with one hand and press down on the gasket material with the other. This will prevent the material from twisting and being a general pain in the ass. Wind the drill out to high speed, but don't apply very much pressure - let the hole saw do the work, you'll end up with a cleaner hole.
As you can see, I drilled all the holes for the first batch at one time. If you can't see that, you're a blind moron and should go get your head checked.
Take your step bit and drill the bolt holes out. You can probably use a twist bit, but the holes may not be as clean. Once you've drilled all the holes. Cut the gasket out with your tin snips.
Too easy. It took me 20 minutes to make three gaskets. Like so
And you can see, they're pretty much spot on. Like I said, I had enough material to make five gaskets, but I fucked up the fourth one, so I only have four now. No big deal, I only needed three. Did I save a lot of money here? Well, a decent 3" ID gasket runs about $5 and I could have made 5 of them for $12, for a possible savings of $13. Chump change. But I made them myself and it adds another special Speefoos' touch to my car.
__________________
www.7thgenhonda.com
Old 11-14-2007   #1444 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Re: Hey Foos! Make me a Sammich! (Pg 97) - The Speedfoos' Turbo Thread!!
Looks good Foos... 13 bucks is a lot... Thats three double doubles with fries, a drink and change left over... or a hell of a lot of tacos at taco bell....
lordhelmet is offline   Reply With Quote
Old 11-14-2007   #1445 (permalink)
speedfoos
speedfoos's Avatar
Jesus man. Where'd you get all the rep?! $13 doesn't even cover lunch out on the town here...
__________________
www.7thgenhonda.com
Old 11-14-2007   #1446 (permalink)
01civicriderex
The Random King of the Posts
01civicriderex's Avatar
01civicriderex is a glorious beacon of light 01civicriderex is a glorious beacon of light 01civicriderex is a glorious beacon of light 01civicriderex is a glorious beacon of light 01civicriderex is a glorious beacon of light
no joke how did you get so many reps...you can get a double cheese and fries for 2.99.. wow thats off f&f
__________________
" Are you going to listen to him? He's wearing socks with sandals. Whats that got to do with him having a fast car? " 2006 C-ville,ky supra vs mustang debate
01civicriderex is offline   Reply With Quote
Old 11-14-2007   #1447 (permalink)
boosted01vic
boosted01vic has a spectacular aura about boosted01vic has a spectacular aura about boosted01vic has a spectacular aura about
chris had me get iridiums, part # 2668. they seem to be doing better. got them stock gapped at .030, although chris said to gap em to .032, i didnt want to mess up the iridium element as its so damn small and thin...
boosted01vic is offline   Reply With Quote
Old 11-14-2007   #1448 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Quote:
Good old In n Out... The rep came from lots of people but it jumped up a bunch with triz's rep.
Old 11-14-2007   #1449 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
i want some rep..
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 11-15-2007   #1450 (permalink)
speedfoos
speedfoos's Avatar
There you go. Another jujube courtesy of foos.
__________________
www.7thgenhonda.com
Old 11-15-2007   #1451 (permalink)
cinaibur
Senior Member
cinaibur's Avatar
cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice
gaskets looking good man. You guys have retarded amounts of rep. Spread the love! lol
__________________
Rallye Red 01 Coupe
5zigen FN01R-C with Yokohama YK520's
Tokico Blues
Goldline Springs
cinaibur is offline   Reply With Quote
Old 11-15-2007   #1452 (permalink)
boosted01vic
yeah, spread the love =D
Old 11-15-2007   #1453 (permalink)
speedfoos
speedfoos's Avatar
Ho ho ho bitches.
__________________
www.7thgenhonda.com
Old 11-15-2007   #1454 (permalink)
01civicriderex
yea you done spread the love to me..so are you going to strap a deer grunt call to your b.o.v. to make the sound of a reindeer?
__________________
Old 11-15-2007   #1455 (permalink)
HonCiv02
Super Member
HonCiv02's Avatar
HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned
^ that would be awesome for christmas. gaskets look good foos, i might have to give that a shot the next time i need some.
__________________
eat.sleep.honda.
HonCiv02 is offline   Reply With Quote
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
