Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-28-2007   #1396 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: Back in Biznass (Pg 87) - The Speedfoos' Turbo Thread!!
Yeah, I thought about it and I may just order one. I was going to run without it, but I probably shouldn't. Although I can probably just re-use my existing 2-1/2" one and just put it after the cat if I don't feel like shelling out another $40 on a flex. I'll sleep on it tonight and think about it. To remove this ad, register today for free or log in if already registered!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 10-28-2007   #1397 (permalink)
cinaibur
Senior Member
cinaibur's Avatar
cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice cinaibur is just really nice
DP is lookin good man
__________________
Rallye Red 01 Coupe
5zigen FN01R-C with Yokohama YK520's
Tokico Blues
Goldline Springs
cinaibur is offline   Reply With Quote
Old 10-28-2007   #1398 (permalink)
Buds302
Senior Member
Buds302 will become famous soon enough
looks good mang. where is the wideband going? i suggest as far down the pipe as you can. like somewhere next to the downstream O2 sensor.i fried one being k=like right at the end of the short dp. in the dezod DP there were two bungs in the short pipe. i ran the wideband in the second of the two. and i had a bung in the long pipe under the car. thats where the second 02 went. well like two months into it i noticed my sensor faulting out. so i replaced it and moved the bung for the wideband to where the second o2 was. hasnt had a hiccup yet. but just a suggestion.
Buds302 is offline   Reply With Quote
Old 10-28-2007   #1399 (permalink)
sql_civic
Super Member
sql_civic's Avatar
sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light sql_civic is a glorious beacon of light
Way to go.
Quote:
Originally Posted by Snakeeater View Post
Clint, Those welds look pretty darn good! One suggestion, when you make the last pass, use a "U" pattern. Staring on left side, go down, across and then up; then down, across and up.. Make the pattern wider than your seam by 3/32" on both sides.
Practice on a flat piece and watch how nice of a weld you can make, Will be make the joint a lot stonger and less chance of a pin hole leak.
Rep to you for having such a cool son (from one Dad to another) and secondly for being welding pro.
sql_civic is offline   Reply With Quote
Old 10-29-2007   #1400 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
It started with stock injectors!!!
so at least I know it's not wired wrong....
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 10-30-2007   #1401 (permalink)
MURDOCK
My cats breath smells like cat food.
MURDOCK's Avatar
MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned MURDOCK should not be questioned
Send a message via AIM to MURDOCK
Have you finished the exhaust yet Clint?
__________________
"I'm not sure what weapons will be used in World War III,but World War IV will be fought with sticks and stones."~Albert Einstein
Sig work by Speedfoos
MURDOCK'S youtube pick of the month...Nov
http://www.youtube.com/watch?v=030aFu6fQbI
MURDOCK is offline   Reply With Quote
Old 10-30-2007   #1402 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
BookMark for matt.
Alpha 5 is offline   Reply With Quote
Old 11-07-2007   #1403 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
/thread?
TRIZ is online now   Reply With Quote
Old 11-07-2007   #1404 (permalink)
tuningmycivic
Ultimate Member
updates??
__________________
Old 11-07-2007   #1405 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
he's MIA until thursday gentlemen... he'll be back probably thursday night if im not mistaken.. something for work or military, but i know he'll be gone till thursday.. hold ur horses..
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 11-07-2007   #1406 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Yep, exactly what Dseven said. He is away on a military gig till Thursday evening UK time.
Old 11-07-2007   #1407 (permalink)
TRIZ
TRIZ's Avatar
alright, i'm peacing out till thursday evening too then.
Old 11-09-2007   #1408 (permalink)
speedfoos
speedfoos's Avatar
Back from travel. Please no /thread or /speedfoos guys, I would like to keep this one running regardless of all of the differences and drama that has been going on.
Minor updates, more problems than progess.
The place I ordered my O2 bungs (www.voodooboost.com) appears to be out of business. I'm out $15 and some more time while I wait for the new ones to arrive from Ebay. Inshallah, they will be here on Tuesday.
I appear to have fried some of the diodes in my alternator. Prior to the one day at the track, my voltmeter was rock solid at 14.5 volts when the car was on. Now it ranges anywhere from 13.2 - 14.0 volts and occasionally kicks down to 12 and dies. Wee! It's slowly dying and I really don't feel like buying a new one just yet. Gonna run it till it blows completely and then just upgrade to a HO one. Gonna need it since I'm adding another 1200-watt RMS draw from the 2 amps sitting behind me.
Warped head is still on the car, but I don't push coolant as long as stay under 6K on the tacho. This is doable because it's still fun when I boost from 3k-6k! I took it on a fairly long drive on this trip (3 hours one way, about 140 miles) and it did just fine. I even managed to pull around 30mpg. The head will still be coming off as soon as shit out some more cash for the HG set.
Good news is that my new D/S Brembos and PBR pads are here and will be going on tomorrow!
__________________
www.7thgenhonda.com
Old 11-09-2007   #1409 (permalink)
MURDOCK
MURDOCK's Avatar
You are just a multitasking machine man!
__________________
Old 11-09-2007   #1410 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Clint, how do you know your head is warped? Plus....in the 5 years I'm been in the car business, I have never seen a car with a warped cylinder head not overheat.
My car has not pushed coolant in two weeks!!!! Strange huh I think it pushed coolant because it was so damm hot here. 14 psi cap is just not enough with the turbo heat. I need a high psi rated cap, hopefully it was raise my boiling point so my coolant will not run into the overflow. I'm gonna try a new cap & wait for summer...see what happens
oh. p.s! my car got backed into by a damn sorostitute....
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
