Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-10-2007   #691 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: IT'S RUNNING!!!! Page 40 Video - Speedfoos' Turbo Install
OK. Pretty gunky. Cleaned them off with a wire brush and carb cleaner so they're much better now. These are the colder NGK plugs you recommended. I'll datalog off these now.
Plug 1
Plug 2
Plug 3
Plug 4
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 09-10-2007   #692 (permalink)
speedfoos
speedfoos's Avatar
Seems to like those a lot better, although the AF ration is fluctuating a bit. You'll see it once the log is done. It may be the old gas in the tank, although that should be offset by the octane booster. I'm going to fill it up with premium tomorrow. Its 2230 here and I'm not paying in pounds (literally quadruple, $2/liter) to get gas out in town.
AF is stable now though, and no misfiring. Good call Chris!
Gonna check on the fans. Even when gauge was hot, they didn't come on.
__________________
www.7thgenhonda.com
Old 09-10-2007   #693 (permalink)
speedfoos
speedfoos's Avatar
Idle is nice and smooth!
__________________
www.7thgenhonda.com
Old 09-10-2007   #694 (permalink)
Buds302
Senior Member
Buds302 will become famous soon enough
the random misfires is normal.i get that code atleast once a week on startup. you will prolly see a o2 sensor code more than anything. i ran around for 4 months withthe scanner hooked to my car all the time. just to be sure. checked every single code that came up. most of them were random misfires and o2 sensor. then did the o2 sensor simulator using the spark plug non foulers and i get one code a week. somtimes its random misfires and sometimes it o2 sensor. im not bothered by it. the whole time my car was on the dyno i never once threw a code tho.
Buds302 is offline   Reply With Quote
Old 09-10-2007   #695 (permalink)
WilmncChris
Senior Member
WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light
Random misfire is not normal. It is either one of two things a tuning issue or plugs
WilmncChris is offline   Reply With Quote
Old 09-10-2007   #696 (permalink)
speedfoos
speedfoos's Avatar
Well I can do one of them Chris, as long you can do the other!
I'm done for the night. I hacked up my bumper cover the rest of the way and put it on. Chris, I'm emailing the zipped datalog to right now for you to look at it. I'm exhausted. It's midnight and I've work (as usual) bright and early. Need some food too.
__________________
www.7thgenhonda.com
Old 09-10-2007   #697 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
I also get random misfire codes and baro sensor codes on a regular basis running emanage Joys of turbo!
and yes skip...I'm pushing coolant. The odd thing is it's not consistant! 2 days it might run fine and then all of a sudden it pushes....It passes all tests to inspect for headgskt problems aswell. Oddly enough it also does it when I am not into boost. It actually works backwards. You would think headlift would do it more?
I'm just gonna throw my new transmission in, worry about a better computer, & build a motor!
Worst that can happen is she blows up right? Just nuts and bolts guys, anything can be fixed!
(I just don't wanna fix it half the time, not really top priority after working on other peoples cars all day)
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 09-10-2007   #698 (permalink)
speedfoos
speedfoos's Avatar
Here you go folks. Two pictures sum up my day. I'm dead on my feet and am going to bed.
__________________
www.7thgenhonda.com
Old 09-10-2007   #699 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
yay, its back together, congrats Clint
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 09-10-2007   #700 (permalink)
civicfan1203
Look at me im a supporting member
civicfan1203's Avatar
civicfan1203 is just really nice civicfan1203 is just really nice civicfan1203 is just really nice civicfan1203 is just really nice
Re: Postpartum Depression on Page 48 - Speedfoos' Turbo Install
good job
__________________
2003 HONDA CIVIC EX
civicfan1203 is offline   Reply With Quote
Old 09-10-2007   #701 (permalink)
7thgen.nick
7thgen.nick has a spectacular aura about 7thgen.nick has a spectacular aura about
nice. very nice.
you gonna street tune it, or bring it in?
7thgen.nick is offline   Reply With Quote
Old 09-10-2007   #702 (permalink)
WilmncChris
Senior Member
A baro code on emage is a simple fix of adding a % to your air mixture table.
You should honestly have no codes on a turboed car.
Old 09-10-2007   #703 (permalink)
MarchMadnessisM
Member
MarchMadnessisM's Avatar
MarchMadnessisM has a spectacular aura about MarchMadnessisM has a spectacular aura about MarchMadnessisM has a spectacular aura about
Send a message via AIM to MarchMadnessisM
so how does it feel to have it out the garage under its on power
MarchMadnessisM is offline   Reply With Quote
Old 09-10-2007   #704 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
man ur garage is alot smaller than i thought...
no were not getting any responses from him till the mornin.. but its nice to see that thing out of the hole.. good job foos..
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 09-11-2007   #705 (permalink)
speedfoos
speedfoos's Avatar
It felt damn good. Although I'm fucking exhausted. I'm driving it to work this morning. Got the new map Chris, thanks!
I can't bring it in, I live in the UK where no one has heard of the PCS, and only 3 people have ever seen a D17A2.
We're doing a street tune by email. Chris (of BNT Performance, WilmncChris) is adjusting the maps off the datalogs I send him. Working very well so far I might add.
__________________
www.7thgenhonda.com
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
