Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-10-2007   #676 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: IT'S RUNNING!!!! Page 40 Video - Speedfoos' Turbo Install
Hey man, hose elbow works like a charm. Isn't kinked and where it does touch the IC pipe is where the metal joiner is. No danger of gettin' kinky there. Other parts of the car.....well Civic back seats are too small too.
I was thinking about a new DP while mowing the lawn. What about studding it? Put studs on the discharge side, sure would be easier to hang the DP and not have worry about things lining up. Are you torqueing the bolts down like lug nuts? Up -> Down, then left->Right? That way it seats properly? If all else fails, switch to a V-band.
So your can setup doesn't go into the intake tube at all? Just from block -> can -> valve cover? I suppose that would work even though your head doesn't get fresh air, just the fumey (technical term) stuff from the PCV chamber via the catch can. As long as the air goes out from the PCV chamber and into the VC, it probably doesn't matter.
Anyway, lawn is done I'm headed to the garage!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 09-10-2007   #677 (permalink)
speedfoos
speedfoos's Avatar
Sittin' in the car, about to clear any CELs (new scanner) and upload the new map....
__________________
www.7thgenhonda.com
Old 09-10-2007   #678 (permalink)
speedfoos
speedfoos's Avatar
Hmmm..... Something must crossed in the gauges itself. It did that "No tach, scanner error" thing again even when i changed the ACC feed. Gonna have to troubleshoot the gauge wiring one at a time. Oh well. Boost gauge works. That's all that matters. OK. Gonna start it for sure this time.
__________________
www.7thgenhonda.com
Old 09-10-2007   #679 (permalink)
boosted.es2
Diamond Member
boosted.es2's Avatar
boosted.es2 is a jewel in the rough boosted.es2 is a jewel in the rough boosted.es2 is a jewel in the rough
Send a message via AIM to boosted.es2
foos. what rod bolts did you use? and what did you torque them to? i was looking to buy a set.
boosted.es2 is offline   Reply With Quote
Old 09-10-2007   #680 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
fosho, you're pushing coolant? thats a head gasket my friend.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 09-10-2007   #681 (permalink)
skipbarber
skipbarber's Avatar
Quote:
Originally Posted by SuJaK.3 View Post
oil/water cooled turbos do not need a turbo timer or cool down time, oil cooled turbos however do.
are you sure your t3 super60 doesn't have water cooling lines? I swear they came with it...
am i sure? im on my second one. t3 soup 60's are not water cooled. they have ports for oil feed and oil drain and the rest of the center section is solid. it doesnt even have freeze plugs where water lines 'might' go.
__________________
sig by speedfoos
Old 09-10-2007   #682 (permalink)
speedfoos
speedfoos's Avatar
Had to put some octane booster in. Idling like crap on both maps.
My car has been in the garage for too long. Dex's crack spider has moved in:
While I was watching, he made a crane fly his bitch.
OK, octane booster should have mixed by now. Gonna datalog both maps again. Car is running with NO CELs though!
__________________
www.7thgenhonda.com
Old 09-10-2007   #683 (permalink)
speedfoos
speedfoos's Avatar
I'm on completely stock internals right now man.
__________________
www.7thgenhonda.com
Old 09-10-2007   #684 (permalink)
Jza
Senior Member
Jza is a jewel in the rough Jza is a jewel in the rough Jza is a jewel in the rough Jza is a jewel in the rough
Send a message via MSN to Jza
Quick question about turbos. So the air that comes out of the exaust manifold and would be headed out of the exaust is interupted or redirect towards the weird snail turbo compressor? Right? What exactly does this weird snail turbo compressor do? Why can't the air be put directly in the motor?
__________________
Jza is offline   Reply With Quote
Old 09-10-2007   #685 (permalink)
speedfoos
speedfoos's Avatar
Hmmmm. CEL after the octane booster. Better check what it is.
__________________
www.7thgenhonda.com
Old 09-10-2007   #686 (permalink)
speedfoos
speedfoos's Avatar
Hmmm. Random misfires 300-304. That's not good.
__________________
www.7thgenhonda.com
Old 09-10-2007   #687 (permalink)
speedfoos
speedfoos's Avatar
Codes erased, didn't come back.
Turbo in a nutshell. Exhaust from the engine enters hot side of turbo, spinning blades of turbine as it goes by on it's way out the ass of the car. On the compressor side there is another set of blades attached to the turbine which - spun by the force of the air going through the hot side - suck air in, compressing it and forcing into down the gullet of the TB and IM through the intercooler.
__________________
www.7thgenhonda.com
Old 09-10-2007   #688 (permalink)
speedfoos
speedfoos's Avatar
Strange. Can't get the coolant fans to kick on. May have to run a manual switch until I figure it out.
__________________
www.7thgenhonda.com
Old 09-10-2007   #689 (permalink)
WilmncChris
Senior Member
WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light
Check your plugs, if your fans are not turning on you will need to see if you have air in the lines from tapping into the coolent system. Your Misfire codes are more than likely from your plugs
WilmncChris is offline   Reply With Quote
Old 09-10-2007   #690 (permalink)
speedfoos
speedfoos's Avatar
Rgr.
__________________
www.7thgenhonda.com
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
