Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-30-2009   #3181 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
Catching up this forum.
The parts hath starteth to arrive. Eth.
75mm bore is for suckas. 102mm (aka a "30 over" SBC) coffee cans!
We're going to do a structural floor. Basically a frame of 1" square tubing is going to be the floor and firewall foundation that will be welded to the subframe, front - to back. Once we get the dimensions of the tranny tunnel done and welded in, the bottom of the floor frame is getting a nice smooth sheet metal skin welded in. I'm going to fill the tubing and cavities with foam (after running fuel, brake and power lines with bulkhead fittings) and cap it off inside with another layer of sheet metal held in with rivets and caulk. This way the floor becomes a structural member of the car. Once that's done, we'll make the X-brace to join the frames.
Oh yeah, gotta get a Mustang II front end and make the crossmember the right size for my 53" track width first so we know where the motor is going to be.
So much to do!
But here's some more motivation.
Did a little work tonight in spite of myself. Turns out there was an engine underneath all that grease!
Taking a lunch break. Got most of the cage done. Here's my start. Three pieces of 1" conduit and a piece of 3/4" angle iron.
Brackets cut and the first pipe sized up.
It doesn't have to be pretty or hold a seal so I don't care what my welds look like.
Done with x-brace.
I just need to tie in the front and rear to make doubly sure nothing flexes when the floor and bottom part of the firewall comes out.
Welding galvanized conduit gives me a headache. Something about toxicity or somesuchthing. Oh well.
Door geometry cage is done.
I tied the front braces up to where the hood hinges come through the firewall.
And used one old hood pin stud from Piggy and one D17 transmission bolt from Sugar to run my braces to.
Then I drill a hole in each fender to fit the rear braces.
Once everything was all tied it, I welded the back crossmembers together and then the front crossmembers together.
So my chassis brace is three pieces composed of the B-pillar cross brace, the front firewall brace, and the rear fender brace, all tied in and bolted together in the middle.
I think I'm safe to cut the floor and transmission tunnel out now.
And speaking of the floor coming out.........tada!
Welding in a t-shirt also beats tanning beds.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 03-30-2009   #3182 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
^HHAHAHAHHA no tanning beds needed!
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 03-30-2009   #3183 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Thats not the final engine location is it??? Seems a little high.
__________________
I click on civicDave's links no matter how broken they are!
lordhelmet is offline   Reply With Quote
Old 03-30-2009   #3184 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
I love reading this thread!
04 Honda Civic is offline   Reply With Quote
Old 03-30-2009   #3185 (permalink)
speedfoos
speedfoos's Avatar
Quote:
Yeah, quite uncomfortable today though. Plus I have a nice two-inch long burn above my elbow when I bumped into a fresh bead on the x-brace.
Quote:
LOL - no that's not the final location. It's just for motivation plus it clears a little space in the garage.
Quote:
Glad you enjoy it!
__________________
www.7thgenhonda.com
Old 05-01-2009   #3186 (permalink)
speedfoos
speedfoos's Avatar
Pulled the rest of the firewall out tonight.
Before.
Kind of before, but after some modification to get the motor out.
After.
This was followed by some rust discovery work with the abrasive disc on my grind. Not bad but there are some pieces that will need to be replaced. The car was red at one time.
After much hemming and hawing about suspension options - from custom 52" track width Mustang II, to an S10 blazer frame grafting job, I decided to just go with a Mustang II front end. It has a 55.5" track width which will push my wheels outboard by 1.75" per side. This something I can live with as cost climbs pretty rapidly when I start looking at custom bits.
And I ordered a soda blaster to make things easy on myself.
Picked up my front end this evening. Turns out the guy selling it runs a mustang junkyard. Seems to be in pretty good shape, but the first thing Mindy asked was, "How much did you pay for this rusty piece of poop?"
She has no vision.
But I paid $200 for it which is a deal. It has a power steering rack and one other key element that I was not aware of, but very pleased to discover. The length from inner frame rail to inner frame rail on the M II front end is 24" and that also happens to be the exact length of the inner frame rails on the Volvo! Color me stoked.
Yes, it needs a little love, new bushings, brakes, coilovers and so on, but it still beats a $1600 setup from Heidts.
I got 55 pounds of love today.
This thing is freaking heavy. I thought that the D17 crank was a handful, but it's got nothing on this 383 crank.
Pulled some of the Mustang II front end apart just now. After I removed the calipers, I was wailing on the rotors with my BFH (big friggin' hammer) and they would not budge. Who would have thought that the wheel bearings were inside the rotors and the spindle nuts had to come off first. Damn domestics. Makin' things complicated.
I decided to spend a little time working on the steering rack and some general organization. Aside from one tie rod end being a bit stiff, everything cleaned up really nice. I even ground down all the factory casting marks because I'm like that.
Before:
After.
And then I organized all my go-fast parts.
Did some more work today since the shipping company doesn't work on Saturdays and I couldn't go get my motor. I starting looking at the car and realized I needed to get the hood off and the glass out. So I did. And without breaking it!
After that was done, I pulled out the headliner and cleaned up all the mouse turds and shredded foam. Lord knows when that little bastard was in there, but I'm sure he contributed to aroma that the car had. No pics, but take my word for it, it's out.
Hmm.....still lots of daylight left and energy to burn.
I had a half a can of aircraft stripper left so I sloshed some on the passenger fender well. That poop burns kiddies. I have a couple scars on my arms from it and it's not something I care to repeat.
Slosh, slosh.
You can see the spot that I worked at with a chisel before putting the stripper on. Well, the stripper didn't make it much easier. This took me a good 2.5 hours. I still have the other side to do. Thank God I'm going to cut the rear fenders out when I tub it otherwise I'd only be a quarter of the way done.
Undercoating FTL.
Oh, I also degreased the passenger front spindle and lower A-arm. No pics of that though.
Motor = sourced.
My buddy has 4-bolt 350 from an '88 Chevy that we will use as the foundation for the build. Best of all it's going to cost me an engine hoist to get it from him. He wanted to give to me, but I don't roll like that.
Transmission = bought.
Just bought a WC T5 off a guy in Ohio on Ebay. Comes with a brand-new Centerforce DFX 6-puck sprung clutch, a new Hayes FW, a Hurst shifter and a couple other goodies. Scored for $750+shipping. Not bad at all. Hell, the clutch alone is worth that.
Tron gets the door prize for showing me those Diamond wheels. I'm just waiting on them to call me back and I'm going to order a set 15x10s for the rear and a set of 15x8s for the front, both in 4-inch back spacing. The pro/challenger series d-windows in chrome.
I just check-booked the heads this morning. Couldn't help it. After running down the cost of valves, valve springs, getting new seats cut, hot tank, fly cut, lifters and then all the work I would have needed to do on the ports, and I still had iron heads, it became more economical to just get a set of aluminum roller rocker heads with all that already done from Skip White. 2.02/1.6 valves with 210 runners and 64cc chambers all for just under $700 for the pair + shipping. He's shipping them out today. Wee!!!!
I also picked up a couple goodies yesterday. Spare bellhousing, a set of cast Chevy ramhorn manis for Donovan and an air cleaner for me. I'm not sure if it needs a taller filter yet or not. We'll see once it gets in the bay. But I threw some stuff on the plastic block just because I wanted to see it.
The motor is a greasy mess but I don't care. It's also a 2-bolt main, which is also OK because I'm not building a motor that is going to top 500 hp. If I was, I would have to change a lot more than just the block. Not on this build.
My daughter and I worked on the block a little bit tonight. Main thing we did was get it out of the truck and on the engine stand. This was followed by removing the AC bracket, crank pulley and damper, soaking everything in PB blaster and attempting to remove the PS pump and bracket. Turns out I need a bigass puller for that which I will pick up tomorrow.
For those that were wondering, this is why I am not re-building the stock motor. Size does matter.
Then we unpacked my other goodies. WC T5 tranny with a B&M shifter....
Centerforce DFX 6-puck sprung clutch.....
.....plus the new FW, tranny mount, and another bellhousing:
That's that for now. We'll be taking the heads off tomorrow night and possibly pulling the rotating assembly. We'll see how much time I have after work.
And for some motivation, a jet truck and Grave Digger that ran the strip right before the final round of IHRA Nationals on Sunday. What a fun day! Frickin' Grave Digger ran a low 9-second pass, unbelievable!! And everyone likes jet trucks. Stick that in your global warming.
Quote:
Originally Posted by 850DegreesF View Post
You're like the young upstart champion right now! In the first bout in the ring, you came out swinging & scored a vicious knockout! Holy s**t! You came on here strong as all hell! I will most certainly be watching this one! Man, dude!
Well, I've got a few more rounds to go and as far as being young, well, it's all in my head!
Quote:
Originally Posted by Tick View Post
That thing is going to be sick. Really interested to see how the rustang x-member works out.
Should work out nicely, I just need to get the motor prepped for the machine shop and the front end will be next on the to-do list.
Work work work. Most of the motor is torn down. I bought my pulley jaws and attempted to get the PS pulley off after work yesterday.
Hmm......something seems to be stuck...
Although I run my garage like the Amish and shun air tools, I don't mind using a power tool every once in a while.
Bitch, you're coming off! Had to break out the BFH and a cold chisel as well but managed to remove it without scarring up the arbor too much.
Moving right along.
As soon as pulled the VC bolts out there was an awful smell, and I had a feeling what I was going to find. Change your fracking oil kiddies or this can happen. I would imagine this takes about 3 years of just topping off the crankcase but my God.
I hate people who don't take care of their cars.
Anywho, pulled the heads off and the pistons looked like **** of course.
Nothing too surprising there. Time to flip it over and work on the rotating assembly. I think it got motion sickness or dizzy or something because it puked on the engine diaper.
More coke anyone?
Then all the pistons magically fell out on to the floor. Oh wait. That only happens when you pay someone else to do the work for you. Not in my garage.
Surprisingly enough all of the rod bearings looked good and so did the crank journals. It's not really relevant since I'm replacing the crank, but it is nice to see despite the poor maintenance on the motor.
Back to the top and down the bores. Everything looks good still, no scoring or pitting. They are getting bored .030 over anyway, but again nice to see. Pulled the timing cover and timing gear and chain of as well. The cam seems to be stuck probably because of the lifters, but I'll worry about that tomorrow.
And that's it for yesterday's bout. Three of the flex plate bolts are rounded off so I will have cut those off tomorrow otherwise the crank would be out of the block already as well. Today is another day.
Much better. The shop didn't take out the front cam buttons but 95% of the sludge is gone. Looks almost like a new motor.
Time to get to work though. I chamfered out the oil return holes in the back of the block to help the oil get back down into the pan where it should be so it can cool, get filtered and then come back upstairs and do it's business.
After that I dressed the head surface with some 120 grit sandpaper....
....and got out my grinder and took off all the rough casting edges that were all over the block. This is just an example on the oil filter housing.
I still need to get one freeze plug out of the top of the block. It's bent my 1/4" extension so I drilled it out and will hit it with PB Blaster over the next couple days to get it ready for extraction. Once my rod balancer gets here I'll balance my rods (still need to buy a scale too), and take the rods and pistons to shop to get the pins pushed in, the block bored out, dipped again, cam bearing and press in freeze plugs installed and that will make it ready to completely assemble!
__________________
www.7thgenhonda.com
Old 05-01-2009   #3187 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
wow man looking good so far
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 05-01-2009   #3188 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light
Send a message via AIM to filipinop1405 Send a message via MSN to filipinop1405 Send a message via Yahoo to filipinop1405
new project is looking good clint!!
__________________
Buy my stuff... Side skirts, EX ECU, and more....
http://www.civicforums.com/forums/19...irts-more.html
Sister-in-Law
my car <----click on me
US Army Special Forces Suppport
sig by clint "the man" speedfoos!!!
filipinop1405 is offline   Reply With Quote
Old 05-01-2009   #3189 (permalink)
bakertime
Senior Member
bakertime's Avatar
bakertime is a jewel in the rough bakertime is a jewel in the rough bakertime is a jewel in the rough
Not wasting any time...
__________________
1997 Integra, Built N/A B18C1, 11.6:1 CR, tuned on a Hondata S200/ P28
2001 Civic EX, Ksports, Magnaflow Exh., SRI, SS - SOLD
bakertime is offline   Reply With Quote
Old 05-01-2009   #3190 (permalink)
speedfoos
speedfoos's Avatar
Thanks fellas, and I think we all have come to realize that I'm not much for wasting time.
After re-reading Dave Vizard's chapter on block preparation I realized I hadn't opened that rear oil return port out enough. The reason for this procedure is that are catches a lot of sand during the casting process which could break loose and cause problems and also causes cavitation. Once I stuck my pinky finger in there, man he was right. All kinds of bad casting slag in that hole. Not anymore on this block!
__________________
www.7thgenhonda.com
Old 05-02-2009   #3191 (permalink)
Wolfgang5884
Platinum Member
Wolfgang5884's Avatar
Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about
Send a message via AIM to Wolfgang5884
Damn Clint! Things are looking nice! I can't believe how bad the engine was maintained.
__________________
2001 Civic Ex/Sedan/5 Speed
16.258@86.5MPH
Wolfgang5884 is offline   Reply With Quote
Old 05-02-2009   #3192 (permalink)
CiViCPrAnInG2k1
CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned CiViCPrAnInG2k1 should not be questioned
Send a message via AIM to CiViCPrAnInG2k1
Amazinggggggggggggggggggggggg!!!!!
CiViCPrAnInG2k1 is offline   Reply With Quote
Old 05-02-2009   #3193 (permalink)
speedfoos
speedfoos's Avatar
Quote:
Thanks Scott! Yeah it was in pretty rough shape, that's for sure. It will need to be hot-tanked again after they bore it .030 over to ensure that all of the rest of the sludge that didn't get out the first time goes away. The last thing I need is for that crap to lodge against the pickup screen, clog it and starve the motor!
__________________
www.7thgenhonda.com
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
