Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-21-2009   #3031 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Re: Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
Quote:
Originally Posted by speedfoos View Post
Well considering I'm $10K into this motor, I need to focus a little more on putting that power to the ground instead of making more power going spinning .5mm above the pavement.
As I said, I don't doubt your PnP head makes power. But I don't think you and I have ever gotten in an online pissing contest and I don't think we need to start now.
No Clint. No harm was intended man. Traction is def an issue when you make above 200whp on these D17s. They are too light and there are not enough things you can do stop the wheel spin other than run some fatties and/or really sticky compound.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Sponsored Links
Old 01-21-2009   #3032 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
You spent $10k into the motor build alone? What did you buy?
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 01-21-2009   #3033 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Sorry, the complete motor build and turbo setup (kpro, IM, turbo goodies, return setup, clutch, etc...) puts me right around 10 large. Considering there are 3 goodies on there that cost over $1000 each, plus everything else (rods, pistons, rings, bearings, another cam, etc), it adds up quickly.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 01-21-2009   #3034 (permalink)
speedfoos
speedfoos's Avatar
To catch up you folks who don't frequent 7GH....
More work. All work and no play makes Foos a broke boy.
My mani was not right.
Now it's right. Last thing I need is that fucker warping when it gets hot. Gotta give her a little wiggle room. Die grinder style.
My new fuel rail didn't fit exactly right either. Had to figure out how to get the rail to cinch down on the injector plate a little tighter.
Hmmm....
I have a big orange vise....
and a little orange die grinder.....
and a big blue bench grinder....
So strap that in there and start cuttin' and grindin'. I got rid of some superfluous aluminum while I was at it as well.
Much better. And while I was cleaning things up, I pulled the evap valve off the TB and stuck it on the firewall so it makes the IM a little more presentable.
Almost done. Just need to futz with some wiring, wait for my injector clips and strap the head back on and then it's time for a tune at the end of the month!
Next Day.....
So everything was going along smoothly. Wiring done. Gauges done. Kpro installed. MAP sensor wired in, IAT sensor wired in. Installed the IM on to the head. New gasket on to the block. Plopped the head on to it. Started my torque sequence.
20 lbs - OK.
40 lbs - OK.
60 lbs - OK.
80 lbs - 1 good, 2 good, 3 goo....hmm still going, must not have seated all the way, I'll come back to it. 4 good, 5 good, 6 good, 7 good, 8 good, 9 good, 10 good. Let's go back to 3 now.
Turn some more on the 3, still not clicking. back the wrench to 75 lbs, good. Hmm. Stock bolts I'd stop, but these are ARPs. Another 1/4-turn and no click. Switch to my other torque wrench. Another 1/4- tur......BANG!!!
Fucking piece of shit. I guess 5 torque cycles (as many times as I've had the head off) is too much for a set of ARPs at 80 ft. lbs. Now I need to order a new set of studs and another head gasket. Yay.
Here's my fucking gauges. I like them. Go fuck yourself if you don't. I don't want to hear about it.
Long day today and I'm still not done. Oh well. I'm taking my time with so I get everything the way I want it. I came home yesterday (doing some training in Georgia for 4 weeks) and my new head studs, head gasket and injector clips were here. Hooray. I'm tired now but I was a lot more excited when I saw them.
New studs installed.
And torqued to 75 ft/lbs. Since the last one was fine at 75 and snapped at 80, I'm no longer torquing to 80 ft/lbs.
After all this I went out to eat with my family and shit around at the mall area for a little bit. Pulled me away from the garage for a bit but I picked up a new soldering iron and some reference material for my next project; "How to Build Max Performance Chevy Small Blocks on a Budget" by Dave Vizard. Good book so far. I'm not going to break the bank with my next project like I have with this one.
Anywho, got some more work done. Finished up the return setup by installing my lines and inline Trickflow filter. Feed is on the right, return is on the left so I wouldn't have lines running all over the bay. Then I put the mani on. I apologize for the blurry pic on this one but it appears my camera may be showing it's age finally.
Since necessity is the mother of invention, I remember I need a heat shield for my alternator. even though the DP is wrapped, the alternator is still getting some pretty bad heat soak which will only get worse with more boost.
Enter the old cookie sheet!
I cut it in half, put a couple bends in it, and then drilled and tapped a few holes to attach it to the AC bracket. A little paint and she's done! More pics tomorrow once it's dry and I install it.
Continueing on I re-installed the DP and plumbed in all the lines for the turbo, fed the vac mani and brake booster their lines and re-installed the water neck. At this point it was 1130 pm and I was tired so I took this picture and quit.
Tomorrow is another day.
Just about done. I had to nip inside to make sure I'm wiring up the boost solenoid correctly and figured I would bounce up the pictures so far.
Here's the physical layout of the return fuel setup.
FPR is up next to the power steering control unit and this insures a short run between rail and FPR.
Here's the actual rail. I've run return on the left and feed on the right.
Underneath looking up. You can see the brake proportioning valve there below the filter and the bottom of the IM on the right.
My fuel lines running at down the stock location. I'll need to snip my zips before I'm done.
And that's that. I've already taken pics of the pump assembly plus the interior is all buttoned up anyway, so use the search button in this thread if you want to see how that's done.
Like I promised, finished pics of my cookie sheet heat shield for the alternator.
As seen from the front:
And from the DP side. Simple but effective IMO.
Time for solderin'! First off I had to make a third hand. It's hard enough to type, watch porn and solder at the same time so this will come in handy.....hyuck hyuck hyuck!!!
Just a simple piece of aluminum rod with some alligator clips JB Welded to it.
Here it is in action:
How to solder stuff on your car. I make a mess so you probably shouldn't follow my example.
But the clips are all soldered up and installled!
Finished installing the WG and the power steering pump. Since I'm using the EBCS (electronic boost control solenoid), I have to use the top port on my WG. It barely clears the power steering pump.
See? In engineering jargon, the distance between my PS pump and WG vac port is one cunt hair.
Speaking of EBCS's. Here's where I put it:
A shot of my Gate's flexi hose. I need to relocate that coolant port on the thermo housing. As you can see, Honda put it in the wrong place.
That's that! I'm back out to the garage to finish up!
And then I finished up and things aren't right.
Symptoms first.
Rough start and has a hard time getting to idle. When it does idle, it's sitting rich (around 12 on the AFR) and as soon as I open the throttle plate a little, it leans out and dies. If I start it with the pedal to the floor it will run like shit, seesawing on the RPMs and is unable to settle down to an idle. The only time I can get it to idle is by starting it without touching the throttle and then its a crapshoot as to whether it will idle or not. When it does, it idles like stock - as much as that is possible with my car. No valve train noise (that isn't expected) no stuttering, no missing.
What I've checked.
There are no vacuum leaks.
The valve lash is spot on.
The motor responds to changes in the fuel tables in kpro. In otherwords I can lean out the idle, but that doesn't change anything once I open the throttle.
TPS is reading fine and accurate.
The return setup is solid. It's not leaking, the FPR is functioning and responds to adjustment when I can get the car to idle. In otherwords, I am able to increase and decrease the fuel pressure via the adjustment screw and it also ups the fuel pressure as per the boost reference port. One nice note is that I'm building boost with no engine load. The MAP reads about .4 psi of positive pressure at around 3500 RPMs. That makes me happy.
I checked the pump this morning to see if a line was kinked and replaced the SS line in there for a piece of Gates submersible hose. This gives the pump assembly flex like stock where it didn't have that before. So the pump is good. The fittings don't leak, and the lines aren't kinked.
One thing that may be is that I have the fuel filter backwards. It's a Trickflow filter and it doesn't have a flow arrow so that may be it. I will pull it apart this weekend to take a look at it.
The rail is solid. It doesn't leak and I don't get a pressure drop when I am able to raise the RPMs.
I am getting fuel to all four cylinders and I'm getting spark to all four cylinders as well. Air is not an issue nor is timing.
MAP sensor is good, cam and crank position sensors appear to be fine but I haven't checked them with a multimeter yet, but I'm not throwing any codes for them.
Possiblilities.
Stock evap solenoid is removed and the signal wire is wired to my EBCS for kpro to control the boost-by-gear. The evap vacuum line is plumbed into vacuum system of the car. The stock check valve is unmolested. I don't think this is it, but I don't know.
My fuel filter is backwards and causing a blockage. I don't think so because I would see this on my fuel pressure gauge.
I miswired an injector. Injectors don't care which way you wire them, and as far as I know they only have to be wired the same polarity for all four. I double-checked when I soldered in the new clips, but I'll check again.
One, some, or all of the injectors aren't behaving. I did not get them cleaned and flow tested after I got them from Andy, but they should be fine. It's an unknown right now because I didn't have them checked. I am going to swap them for my SRT-4s this weekend to rule them in or out.
__________________
www.7thgenhonda.com
Old 01-21-2009   #3035 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
sounds like a MAP problem, whats your vacuum reading at idle? does it match the figures in the kmanager?
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 01-21-2009   #3036 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
do you have the boxed checked for "Use secondary input for closed loop operation" cause if you don't it will tend to run the way you are describing.
bomerman19 is offline   Reply With Quote
Old 01-21-2009   #3037 (permalink)
speedfoos
speedfoos's Avatar
Quote:
Gauge reads -23 in/Hg of vacuum and so does kmanager. This is the same whether I'm running the AEM 3.5BAR or the stock one (with the parameters changed accordingly in kmanager).
Quote:
But I'm running the car in open loop since I haven't done Edwin's nifty closed loop conversion.
That brings something up.....since I'm running open loop, should I have wired in the output from my wideband to kpro via the ELD input? It can't read the signal anyway right, because of the stock narrowband sensors? Is it getting messed up between the wideband input coming in via the old ELD 5V line, and the stock signals coming in from the narrowbands?
__________________
www.7thgenhonda.com
Old 01-21-2009   #3038 (permalink)
bomerman19
Super Member
bomerman19's Avatar
^ even if your running the car in open loop that box still needs to be checked. I can't really explain why, I think it has to do with the fact that the k-pro just needs the option. and if you have it in open loop like my car and watch the status there is slight occurrence's when it hops over to closed loop I think when your off the throttle in decel. so just check and see what happens I bet it fixes your problem.
as for your wideband you can wire it to the k-pro via the ELD but it will only will act for data logging purpose plus you are going to have to calibrate the setting in the k-pro so your readings are right. the car can't run off the wide band though like the rsx's.
By the way jeff evans does not need the wide band wired in to do your tunning but it helps, mine is not wired in.
Good luck with everything clint and keep me up to date on how your k-pro is acting
Old 01-21-2009   #3039 (permalink)
speedfoos
speedfoos's Avatar
That box is grayed out so I can't check it when I'm running in open loop. So much for that idea. Since I'm running Andy's map from Jeff, it has to run in open loop. I haven't figured out where to configure it in kpro though. It's not an option in the general parameters box.
__________________
www.7thgenhonda.com
Old 01-21-2009   #3040 (permalink)
speedfoos
speedfoos's Avatar
Hmm.....in the settings of kmanager, it was set to use a built-in wideband and not my external wideband for datalogging purposes. I changed this. Maybe it was my problem. We'll find out on Friday.
__________________
www.7thgenhonda.com
Old 01-21-2009   #3041 (permalink)
01_EM2
Member
01_EM2's Avatar
01_EM2 can only hope to improve
quick question foos.... you seem to be the better qualified turbo person. what would be a good size turbo to start off with. i have 310 rsx-s injectors and my turbo mani is for a turbo with internal waste gate. im not shooting to high for power yet just something around 200-230hp
01_EM2 is offline   Reply With Quote
Old 01-21-2009   #3042 (permalink)
bomerman19
Super Member
bomerman19's Avatar
that's probably it we did have andy's wide band wired in.hmmm damm I don't think I have andys map anymore other wise I could look over it It's been so long since I looked at that map. If it is engaged try turning obd2 off, it shouldn't change anything at all on the way the car runs but it might
that would explain why andy told you not to relocate those wires.
Old 01-21-2009   #3043 (permalink)
speedfoos
speedfoos's Avatar
Quote:
310cc injectors won't flow enough for a 200hp build. To hit that kind of power on a T25 turbo you're to need to run around 13 pounds of boost. As far as what size turbo....IDK. Get as big as you can that isn't going to be laggy. A 57 trim turbo with .63 A/R will have the lungs to roll high numbers, but you'll be hard pressed to find one of those in a T25 snail. Look at your budget, and buy the highest quality turbo you can afford.
Yeah we chatted about it and since it's running in open loop with OBD-2 disabled, the O2 sensors could be whistling Dixie for all kpro cares. It's just going to run off the fuel map.
__________________
www.7thgenhonda.com
Old 01-21-2009   #3044 (permalink)
01_EM2
Member
01_EM2's Avatar
god info to know. i wanna get the best turbo i can something moddest. the mani i got is for a t3/t4 turbo
Old 01-21-2009   #3045 (permalink)
skipbarber
skipbarber's Avatar
i ran a t3 super 60 with rsx-s injectors at 7psi on a non-vtec motor and put down 160hp to the wheels. I was maxing my injectors out close to redline and it was consistently harder to make it run right towards the top of the rpm range.
going back to the topic. the box is greyed out because you loaded a pre-existing map. instead of loading the map through FILE>NEW, you load it from FILE>OPEN. for some reason when you load an existing calibration, some options dont show up, or cant be changed. boilermaker and i figured this out a while back.
__________________
sig by speedfoos
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
