Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-08-2008   #2986 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Re: Rock-a-bye Sugar - Page 193 - The Speedfoos' Turbo Thread!!
That conversion looks so sick!
I love the skid plate, I hated having to cut the stock one all the way out
So you're built, big turbo, k-pro(soon right?), equal length, intake mani, suspension, & a front end conversion.
What else do you have to do but paint that beast and drive? You've messed with it soo much I think you've finally worked all the bugs out. Your ready to boost with reliability!
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Sponsored Links
Old 12-08-2008   #2987 (permalink)
supafil25
Senior Member
supafil25's Avatar
supafil25 will become famous soon enough
how much and where did you get those hood pins
supafil25 is offline   Reply With Quote
Old 12-09-2008   #2988 (permalink)
HwNpRyDe_CiViC
Ultimate Member
HwNpRyDe_CiViC's Avatar
HwNpRyDe_CiViC has a spectacular aura about HwNpRyDe_CiViC has a spectacular aura about HwNpRyDe_CiViC has a spectacular aura about
no pics yet for me clint??? heheh
__________________
12.9 1/4 MILE ON PUMP GAS 91!!!!!!!
HwNpRyDe_CiViC is offline   Reply With Quote
Old 12-09-2008   #2989 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
As far as things I still have to do.....
- return fuel conversion, have all the parts (except the rail I want) just need to install
- sell PCS and get a Stage 3 cam
- budget in an LSD
- paint
- drive!
Quote:
www.aerocatch.net and they cost me $100 with the anti-tamper screws
Quote:
Sorry man, been busy and haven't installed it yet. Replaced Josh's rear main on Sunday and was dog tired last night so I didn't work on the car at all. My daughter has an orchestra concert tonight so I may finish up the install on the catchcan after that. It's ready to go, all hoses are run, fittings plumbed in everywhere, I just need to connect it up and it's done.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 12-09-2008   #2990 (permalink)
speedfoos
speedfoos's Avatar
Here's how I did my catchcan setup. I took a female brass 1/2" nipple and ground the threads down on the inside. I slathered a little JB Weld inside of it and installed it on the valve cover vent. Boom. Instant hose fitting because that stock fitting is too big for most hose.
I ran a 3/8" to 1/2" NPT nipple on the stock PCV box - FYI, the stock PCV valve has 3/8" NPT threads - and run it and the VC vent into one side of catch can like so:
Then I tapped another 1/2" fitting into my turbo intake tube and did a modified slash cut on the threaded side. Basically, I drilled a small hole of the filter side of the fitting and a larger one on the compressor side of it allows air across the bottom to create a small amount of vacuum out of the catchcan sucking the vapors into the intake charge.
And here everything is installed. I apologize for the bad camera phone pics. My wife took my camera again.
Oh. I also re-installed my washers....
For that mad-JDM hood tilt.
Sugar misbehaved a little bit and flooded out after the orchestra concert. The joys of a piggyback, 2-step colder plugs and big injectors. So I beat on her a little bit as punishment. Here's a sound clip of what the exhaust sounds like with just a glasspack and nothing from the axle back.
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
__________________
www.7thgenhonda.com
Old 12-09-2008   #2991 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light
Send a message via AIM to filipinop1405 Send a message via MSN to filipinop1405 Send a message via Yahoo to filipinop1405
Re: Page 200 = New Video! - Page 200 - The Speedfoos' Turbo Thread!!
sounds good clint!!
__________________
Buy my stuff... Side skirts, EX ECU, and more....
http://www.civicforums.com/forums/19...irts-more.html
Sister-in-Law
my car <----click on me
US Army Special Forces Suppport
sig by clint "the man" speedfoos!!!
filipinop1405 is offline   Reply With Quote
Old 12-09-2008   #2992 (permalink)
supafil25
Senior Member
supafil25's Avatar
i like those hood pins =)
maybe when i get a cf hood ill eliminate my hood latch and get those
Old 12-10-2008   #2993 (permalink)
Wolfgang5884
Platinum Member
Wolfgang5884's Avatar
Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about
Send a message via AIM to Wolfgang5884
ooooo, baby! She sounds mighty nice and that's a clever way on how to reuse a your carbon-fiber hood.
__________________
2001 Civic Ex/Sedan/5 Speed
16.258@86.5MPH
Wolfgang5884 is offline   Reply With Quote
Old 12-10-2008   #2994 (permalink)
speedfoos
speedfoos's Avatar
Yeah, hopefully they get here soon!
Quote:
Thanks Scott!
Still misfiring under boost, the stock head is choking her, and my flaky voltage issue is back.
So I made her sit outside tonight.
Actually, there is a reason I made here sit outside but I'll get to that in a second. The new half raddy is really efficient. It was 70 degrees today and I stayed between 183-187 °F on the way into work and during an hour-long traffic SNAFU at the back gate. I would be 195-197 with my old Koyo full raddy. That's a good thing. I will probably have to heatshield my alternator again or I may just get a new one along with a new ELD as I'm tired of guessing. The head is just a matter of me swapping it out.
As far as the misfires go, well, it was Christmas today.
But from Andy Claus!
That's my keychain though. Heheh. It will go on soon. Which means my PCS and my extra EP3 ECU will be up for sale.
But I spent all night working on Piggy. She says, "Oink!"
I'm pulling the tranny to replace the clutch. I'm almost done - just two more bolts holding the bell housing on - so she gets her new friction bits tomorrow, as long as the flywheel doesn't need to be resurfaced. We'll see tomorrow once I pop the tranny off.
__________________
www.7thgenhonda.com
Old 12-10-2008   #2995 (permalink)
supafil25
Senior Member
supafil25's Avatar
i wish i had that kind of christmas
and love that key chain hook me up with one
Old 12-10-2008   #2996 (permalink)
sniperscout
You VTEC...I-VTEC
sniperscout's Avatar
sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light sniperscout is a glorious beacon of light
andy clause screwed me this year by selling his rhd clip...i dont care if he didnt know i wanted it
__________________
04 NHBP EM2
K24 Frankenstein Swap
212HP/178TQ
sniperscout is offline   Reply With Quote
Old 12-11-2008   #2997 (permalink)
speedfoos
speedfoos's Avatar
I got it on Ebay last year and only have the one, sorry!
Quote:
LOL - we're still trying to acquire the firewall for it!
__________________
www.7thgenhonda.com
Old 12-11-2008   #2998 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Andy Clause is awesome!!! He brought me a carbon fiber Hood and Trunk and RHD!
LoL he didn't realize I wanted it either even when I told him his girl had to tell him.
bomerman19 is offline   Reply With Quote
Old 12-11-2008   #2999 (permalink)
speedfoos
speedfoos's Avatar
Jolie is the bomb. She keeps Andy Clause in check.
Piggy sucks, but the clutch is done. Definitely a two-man job, but it only took one Clint and a lot of swearing.
Here is why I needed a new clutch.
The new Advance Auto hotness. Quite a difference.
And a shot of the big hunk of aluminum that almost killed me several times tonight. Piece of shit. I hate you Piggy tranny.
It was very dirty. Cuz the tailshaft seal is still leaking.
But I don't care. I also didn't machine the flywheel, nor did I replace the pilot "bearing", which is nothing more than a metal sleeve. I really don't care because this clutch will probably outlast the body of the truck. Plus the FW was still in really good shape.
I am fucking beat. Night folks.
__________________
www.7thgenhonda.com
Old 12-11-2008   #3000 (permalink)
supafil25
Senior Member
supafil25's Avatar
you should of replaced the seal while the trans was out foos.
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
