Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-04-2008   #2656 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
Re: Leaking IM, But Rear Discs Installed (Page 177)! - The Speedfoos' Turbo Thread!!
Just emailed you Clint. I dont know what it could be but I'll do what it takes to make it right. To remove this ad, register today for free or log in if already registered!
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Sponsored Links
Old 08-04-2008   #2657 (permalink)
02fpcivic
Diamond Member
I had a though. Maybe the map sensor port is leaking by. Check the port to make sure its not scratched or the o ring is pinched. Also if they didnt mask that port off when it was powder coated that may have an effect on the seal. The hole size is very tempermental. I'd be willing to bet its something like that. Its not likely that it fractured anywhere and even if it did it would be super obvious. The design is pretty solid as far as structure so I can't imagine it breaking like that.
__________________
JDM Fabtech
Old 08-04-2008   #2658 (permalink)
02fpcivic
Diamond Member
If you have it off, check the welds to the head flange. Look real close for hairline cracks, maybe the powdercoating is masking a fracture. Of all the places, that would be the most prone to breakage.
__________________
JDM Fabtech
Old 08-04-2008   #2659 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
That was one of the things I was thinking, Gery. I thought there may've been a map leak issue. My first thought was a crack at the runners but like you said, it should've been obvious.
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 08-04-2008   #2660 (permalink)
02fpcivic
Diamond Member
Yeah Andy. The runners are .130" thick so there is plenty of meat there for strength. Virtually nobody braces runners that thick. The only reason we had problems with yours was due to the fact that they were .050 annealed hand spun runners, a lot more fragile than 6061-t6.
__________________
JDM Fabtech
Old 08-04-2008   #2661 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light
Send a message via AIM to filipinop1405 Send a message via MSN to filipinop1405 Send a message via Yahoo to filipinop1405
at least you're narrowing it down bro...the rear conversion is looking good!! i'm so jealous!!!
__________________
Buy my stuff... Side skirts, EX ECU, and more....
http://www.civicforums.com/forums/19...irts-more.html
Sister-in-Law
my car <----click on me
US Army Special Forces Suppport
sig by clint "the man" speedfoos!!!
filipinop1405 is offline   Reply With Quote
Old 08-05-2008   #2662 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
I thought it might be that at first too Gerry so I made sure there was no PC on the map plate and when it still gave me issues, I sealed the MAP sensor in there (not on the o-ring nipple, but around the base) with RTV - still no change.
Like I said, I pull the PC off tonight after work and and see what's what.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 08-05-2008   #2663 (permalink)
02fpcivic
Diamond Member
Ok, well I just emailed ya my shipping adress. If you RTV-ed the MAP that should have definetely sealed it. As long as the injectors were sealing it sounds like you checked everything else it could be.
__________________
JDM Fabtech
Old 08-05-2008   #2664 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Clint, check out the IACV on it, too, that's another potential spot for a leak...
__________________
-or-
Old 08-05-2008   #2665 (permalink)
speedfoos
speedfoos's Avatar
Thought about that Andy, but it would still give me the same issue on the stock IM if it was the IACV (since it's on the TB), but it's not. Same thing is true on the injectors since I'm using the same injector plate, ditto for all the little blue o-rings on the runners and the biggun on the TB. I've troubleshot until I'm shooting blanks, so it's gotta be somewhere in the IM.
Once I get it to you Gerry, no hurry on it. I'm shipping my car back to the states during the week of 20 August and it will take about 45 days to get there.
__________________
www.7thgenhonda.com
Old 08-05-2008   #2666 (permalink)
02fpcivic
Diamond Member
Well I do want to get to the bottom of it and if its a bracing issue I want to make sure steve's gets taken care of promptly too. You'll definetely have it in reasonable time.
__________________
JDM Fabtech
Old 08-05-2008   #2667 (permalink)
filipinop1405
Diamond Member
man gerry you are such a top notch guy.. i'm so glad that i'm going to order one from you when i get ready for it.... oh yea i already know that you are just felt like i needed to put that out there!!!
__________________
Sister-in-Law
Old 08-07-2008   #2668 (permalink)
speedfoos
speedfoos's Avatar
Gerry, looks like the IM is fine, but I fucking quit. Was on the way to get my emissions re-inspected, car felt a littl funny after a couple miles. So I turn around, get home, and my idle is back to this again.
YouTube Video
If you are able to see this message it means that you don't have flash installed or that the video server is down.
Was hearing an odd tapping in the head under any acceleration so i figure it has to be the valves from when that tensioner let loose. My new head better get here fucking soon. I'm guessing the exhaust valves on #3 or #4 are slightly bent because that's where the tapping sound comes from and that blowback would cause the fuel/air mixture to get contaminated on the compression stroke, causing my idle issues. She behaves fine under acceleration and load, it's just the idle.
__________________
www.7thgenhonda.com
Old 08-07-2008   #2669 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
leak down test Clint.....check that before you pull the head again. She'll hiss at ya through the intake or exhaust, depending on what is bent. Aren't cars fun! Just take the radiator cap off, drive another car under it, install, & bam! Problem fixed
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 08-07-2008   #2670 (permalink)
speedfoos
speedfoos's Avatar
Yeah no kidding Avery. I'm swapping the head as soon as it gets here, I don't like the port job on this one anyway. Plus my buddy with his leakdown tester is deployed. The head better get here soon because all my shit get's packed out on 18 August. Just pisses me off is all.
__________________
www.7thgenhonda.com
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
