Honda Civic Member's RidesHonda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Re: Rebuild Time - First Startup Vid on Page 167!!! - The Speedfoos' Turbo Thread!!
Gettin there Jay! Rear main oil seal is leaking though so I have to pop the tranny off today and replace it. I'm also going to order new axle seals because I think the driver's side one is leaking too. May as well replace them both, as many times as I've had the axles in and out.
But, I pulled a bunch of parts off a UKDM Civic on Friday and Saturday for Andy and got this for myself for a good price. It's going on at some point in the near future.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
They weren't bad Scott. I got the lip for £25 because of all the other stuff I pulled off for Andy. These guys seemed pretty decent and they are close - just outside of Raunds. It's off the B663 right before you get to the A45 heading west on the A14. If you search "1668cc" on Ebay.co.uk you'll see the donor car.
Made some progress today. Tranny is out, rear main replaced and I'm about to put everything back together. I'm starving so no witty commentary this time.
Yep, definitely the rear main leaking. Blech.
Buh-bye. Nope, buh-bye.
Much gooder!
__________________
I think the ends of it got a little bit on them Carl. I doused the clutch in acetone and scrubbed it, so it's as good as its going to get. She's slipping under full boost anyway because it's not strong enough so it's not that big of a deal if it did get contaminated since I need a new one. Hope that bracket gets here soon, my alternator bolt was almost all the way backed out!
__________________
hey clint they got the ep3 steering wheel out there... i can't find a damn junk yard out here for shyt... but at the same time i'm not looking that hard right now, with the wedding and all coming up.
Did you lube that rear main seal before you put it on the crank? Make sure there is plenty of oil on it before you install it. The initial start will often kill a dry seal. You probably already know this but I figure I'd toss it out there incase others need to change out any seals.
BTW I have piggybacked all kinds of different manifolds and never had one CEL. The only way one would cause idle problems is if it were broken somewhere.
Yeah Gerry, it had a vac leak that I found and fixed, so it's good. Good looking out on the rear main, but Honda actually lubes them from the factory! Surprised me when I took it out of the package that there was already a nice little bead of grease around the inside of the seal.
I'll look Jay and see what I can find. They do wreck them all the time. Once I find one, I'll get you a price.
__________________
Quote:
Ya I know! I put some custom lube on it for you before it left Honda
__________________ Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
Thanks Avery it was delicious.
I think I figured out the actual cause of my problems though. MAP sensor just went tits up. Threw a P0107 yesterday while I was adjusting the idle of the JDMFIM and died. I thought it was just a random code associated with my piggyback. Well......when I can get the car started it runs like absolute shit. This kind of makes sense with all the idle/vac/pressure issues I've been having for the MAP sensor to going going gone. Gonna pick one up tomorrow and see if that works.
Car is back together though so that's at least something.
__________________
What map sensor you running? Hondata has a plug & plag 4 bar but it's $140 bucks!!
75mm Throttle Body
75mm Throttle Body
