Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-19-2007   #241 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Re: Install Day 13 (Pg 17) Almost Done! - Speedfoos' Turbo Install
I got a question....so I am assuming you went with slim fans with that turbo. I used 2x12in slim fans aswell. My only problem now is that I don't have a proper coolant overflow bottle. I have a plastic dasani bottle with a hole in the cap Just curious what you did with yours? I still can;t find a small enough reservoir to fit. I have about 3 different ones I bought sitting in my garage.
Also, I keep loosing coolant badly. It all goes into my reservoir. It doesn't overheat and it doesn't burn any coolant. I have to add coolant after letting the car cool down because it all goes into the reservoir (expanison of heat) So I ordered a new radiator cap(assuming drain back valve is inop) we shall see if that fixs my problem. My worst fear is the headgasket is starting to leak combustion chamber pressures into my cooling system causing excess pressure to vent coolant into my resevoir!!!
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Sponsored Links
Old 08-20-2007   #242 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
The stock one still fits brother! You just gotta use zip ties to hold it in place since it doesn't bolt up. Once I put it back in I'll snap some pics. Are you still running a stock radiator? I was going to suggest a new cap as well since things are a touch hotter now.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 08-20-2007   #243 (permalink)
speedfoos
speedfoos's Avatar
No real update today, belt still isn't here and the exhaust still isn't done.. Just did some puttering around. Cleaned the garage, reinstalled the oil adapter and feed line (it was off while I dicked around with the turbo), mounted the alternator back on and repainted the PS mount and driver's side engine mount bracket.
I tried to put my Megan strut bar back on again, but it definitely is not going t fit. Oh well, it will go in the post-turbo sale box. So I pulled the strut bar completely off. While I had everything apart, I rubberized the bottom of my Ingall's stiffy mounting plate to help absorb some of the vibration. I'll hit it with a couple more coats tomorrow.
That's about it. I may tinker tomorrow, I may not. I still need to cut the hood to clear the WG, but I have a coach's meeting for my daughter's soccer season tomorrow night, so we'll see if I have time to monkey with it.
__________________
www.7thgenhonda.com
Old 08-20-2007   #244 (permalink)
xRiCeBoYx
Your neighborhood friendly RiCeBoY!
Location: Las Vegas, NV (Stationed in Bremerton, WA [CVN 74])
xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all
Send a message via AIM to xRiCeBoYx
BOOO for no updates! :-P haha.. jk man.. I'm just really curious on what it's gonna look like when I get back with my ship.. I fly out to Hawaii to meet up with them tomorrow
__________________
PLEASE BUY MY STUFF!!
...Slowly going back to N/A for now...
..I'm a sad panda..
.my car is crying on the inside.
T.E.A.R.S. Crew Member #3
LETS GET THE TIRE CALCULATOR BACK!
S370HSSV-0773H
xRiCeBoYx is offline   Reply With Quote
Old 08-20-2007   #245 (permalink)
speedfoos
speedfoos's Avatar
Nice! Back to hot-rackin', p-ways, bulkheads, decks and the ever popular "If you can't eat it or fuck it, then paint it!" Have a safe trip brother!
__________________
www.7thgenhonda.com
Old 08-20-2007   #246 (permalink)
xRiCeBoYx
Quote:
haha.. not so much the hot racking.. see, on aircraft carriers, we get our own shit. and yes, the damn bulkheads and decks and (no offense) douchebag officers that think they run the damn joint.. and can't forget about going down to the nuclear plant where I work getting hit by radioactive zoomies that are by-products of a nuclear reactor..
But I got a question for ya, since you're a.. *ahem* older-ish (well older than me.. hehe) military guy: what do you do with the shit they serve in the galley that you can't really eat, fuck, or paint? haha..
__________________
..I'm a sad panda..
S370HSSV-0773H
Old 08-20-2007   #247 (permalink)
speedfoos
speedfoos's Avatar
What's a galley?
If it fits on a spoon without falling off, we eat it in the Army.
__________________
www.7thgenhonda.com
Old 08-20-2007   #248 (permalink)
xRiCeBoYx
sorry.. forgot to translate to Army terminology: Galley (read: Mess Hall)
And I don't know man.. some of that shit that fits on a spoon I don't even think a starving dog would eat..
Then again, you are officer-type, so you guys get better food.. haha..
/threadjack
__________________
..I'm a sad panda..
S370HSSV-0773H
Old 08-20-2007   #249 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
serious thread jack stuff us civilian people cant laugh at
hey foos i thought u were in the UK....is the word soccer..tolerated?? lol i thought it was futbol or whatever
and hey when did u change ur avatar???? its ..not the speedfoos we've came to know lol..its sum other dude that took ur thread over.
updates will come tho im sure.. u sure do love painting.
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 08-20-2007   #250 (permalink)
xRiCeBoYx
at the civilian thingy
and as for your avatar, I thought something was weird.. lol.. Buddy Christ is cool and all, but GIR is the shit.. just thought I'd let you kno Clint..
__________________
..I'm a sad panda..
S370HSSV-0773H
Old 08-20-2007   #251 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
heres my update for the day...
nothing taken, i have my alarm to thank for that...just a shitty way to start my day.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 08-20-2007   #252 (permalink)
marcuse
Senior Member
marcuse's Avatar
marcuse will become famous soon enough
Send a message via AIM to marcuse
whhhataatt?
__________________
Blacked out OEM Healights
8000k HID Conversion
Password JDM foglights
04 Coupe Taillight conversion
Type R Grille
16" Konig Wheels --FOR SALE!
Injen SR Intake
Custom catback w/ HKS Axleback Exhuast
H&R Suspension
Progress rear antisway bar
marcuse is offline   Reply With Quote
Old 08-20-2007   #253 (permalink)
12345678910
Member
12345678910 is an unknown quantity at this point
looks good!@ been interesting watching progress!
those assholes though.... too bad about that window...
12345678910 is offline   Reply With Quote
Old 08-20-2007   #254 (permalink)
xRiCeBoYx
daaaaaammmmn skip.. that sucks.. at least its only glass damage, right?
__________________
..I'm a sad panda..
S370HSSV-0773H
Old 08-20-2007   #255 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
only glass damage, glass isnt cheap, what jackasses, i hate theives, just get the friggin money, get a job, and buy it yourself like we all do, sorry bout the glass man.... foos, u need to finish man, we are all dying to see the finished product...
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
