Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-28-2008   #2371 (permalink)
_Viper_
_Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of _Viper_ has much to be proud of
Re: It's Rebuild Time- Motor is Out (Pg. 157) - The Speedfoos' Turbo Thread!!
A trick I do before pulling any motor out
Right away i slack the Damper pulley bolt..
With great success over the years Ive done like 50 times at least..I take the #1 plug out and i make sure the piston is at the bottom then i fill the hole with a nilon rope(yellow shitty rope) the i crank it til the rope compresses and voila their is no more bungee effect on the damper pulley bolt.. the breaker bar is used to its full effect and clack is comes off like butter.....
I do this with all other belts on you know alt, power steering etc etc...
Doing this right at the beginnng saves alot of BS....
Good luck speed ...
cant wait to see it done..
Viper from Canada
_Viper_ is offline   Reply With Quote
Sponsored Links
Old 06-28-2008   #2372 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Good tip man, will have to do that next time.
Just fucked up a gas ring on piston number 1 and scored the cylinder wall. Yay. Looks like I'm taking the block to the machine shop for a hone, tank, and notch. May as well have them install the Crowers and Wisecos since I don't have any new rings for my old pistons.
I hate this fucking country. I could just find a set of rings in the states in like a 1/2 hour. Not here. Oh well. At least the bottom end will be built now. Still pisses me off though.
Pics later.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 06-28-2008   #2373 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
Quote:
Originally Posted by speedfoos View Post
That sexy manifold goes on as soon as it get in my grubby mitts Michael!
Woot! Crank pulley is off! Impact didn't work, breaker bars did. Never listen to Edwin either. ASE my ass...
lolz dont forget that if you need parts just hit me up and i'll go get them and ship them to you.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 06-28-2008   #2374 (permalink)
speedfoos
speedfoos's Avatar
LOL - thanks Edwin. I'm good at this point (I think). Since Honda decided to stop making the Green crank bearings, I am going to have to re-use one half of a crank bearing, but that's all right, they were all in pretty good shape so I just picked the best out of the 4 I had to choose from. I'll post up the rest of the pics from today's shenanigans in a little bit.
__________________
www.7thgenhonda.com
Old 06-28-2008   #2375 (permalink)
speedfoos
speedfoos's Avatar
I threw the engine in the back of my truck and went for a ride with it. I stopped at the service station just down the road and had grandpa try a whack at it with his impact. No dice. He suggested I try a tire shop - well, tyre shop since this is the UK - because they would have better impacts than he did. We all know how well I listen to advice, so I went to the base hobby shop and tried a slightly stronger impact wrench. Yeah that still didn't work. Moving on.
Went to a tyre shop in town and they tried with multiple impacts to no avail. In the end it to took three of us with two bigass breaker bars to pop it loose - which took all of 2 minutes! Needless to say I was happy, everything was going my way, and I was on schedule to change out all the bearings today and have the bottom end re-assemble before dinner.
Here's the crank end of the block without the crapastic crank pulley and bolt on it.
And for folks who have never seen what the timing assembly of a D17 looks like, here is the same shot with the cover removed. Water pump is the upper right sprocket and the oil pump also functions as an end cap around the snout of the crank.
Heheh, he said "Snout." Same shot but with the oil and water pumps removed and the engine flipped upside down. I love my engine stand. $30 at Harbor Freight.
Once I popped the girdle off, I checked out the main bearings again and they looked all right. There was a little scoring on some of them, but nothing bad enough to be catastrophic to the motor. Have a look.
Moving on then. The crank looks pretty good too. No scoring at on any of the lobes. Those little blue things you see there are Clevite rod bolt sleeves, They help prevent scarring the crankshaft when you wrest it from the engine with your extra-large meat hooks. They also help protect the cylinder walls when you are removing and replacing the pistons. Uncle Summit sells them for like $1.50 a pair.
Mmmmmm. Symmetry,
The rod bearings look really good, so my rods definitely weren't knocking.
Here's the water pump. If it has been making the squealing noise, then it's hiding it very well. I don't care enough to take it apart and see what the problem was. I've got a new one so I'll just replace it. Same thing with the oil pump.
Time to give this greasy baby a bath. Folks out there audience land raise your hand if you have this heard statement from your spouse. Damn it's hard to type one-handed....
Scrub, scrub, scrub, wash wash wash, and ta-da!!
Whoops. That was a picture of a gay man.
Ta-da! Clean engine!!
So nice and clean. Not shiny, but at least nice and clean. Oh, here's a good pic. I pulled out the rods and pistons (obviously) and want to show you the difference between stock rods and Crower F/I rods. Now I see why they call the stockers "toothpicks".
Now is when disaster struck. I got out my handy dandy Ebay-special ring compressor to reinstall the pistons. Tap tap tap goes the hammer on the wooden block to the piston #1. Tap, tap, TAP.
Hmm. That didn't feel right. Uhoh. Piston doesn't want to come out.
Shit.
Cheap ass $5 ring compressor. Looks like the block is off to the machine shop for a hone job on Monday. I'm also going to have them install the rotating assembly and notch the cylinders to clear the Crowers.
What a perfectly crappy way to finish a beautiful day.
__________________
www.7thgenhonda.com
Old 06-28-2008   #2376 (permalink)
Wolfgang5884
Platinum Member
Wolfgang5884's Avatar
Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about Wolfgang5884 has a spectacular aura about
Send a message via AIM to Wolfgang5884
Re: It's Rebuild Time- Scored Cylinder Wall FTL (Pg. 159) - The Speedfoos' Turbo Thre
Great Pictures
Toss that block like a midget and get a K-series!
__________________
2001 Civic Ex/Sedan/5 Speed
16.258@86.5MPH
Wolfgang5884 is offline   Reply With Quote
Old 06-28-2008   #2377 (permalink)
speedfoos
speedfoos's Avatar
LOL Scott! Just for that, there's going to be something extra special in your burger tomorrow!
__________________
www.7thgenhonda.com
Old 06-28-2008   #2378 (permalink)
Wolfgang5884
Platinum Member
lol, but seriously. It sucks the cylinder wall got scored
__________________
16.258@86.5MPH
Old 06-28-2008   #2379 (permalink)
speedfoos
speedfoos's Avatar
Yeah, and Lyndale's wasn't open today so I couldn't even bring the block by to let them get started on it. Now I get to fight through Peterborough traffic in the morning to get there bright and early so hopefully they'll have it done by Wednesday.
__________________
www.7thgenhonda.com
Old 06-28-2008   #2380 (permalink)
Jza
Senior Member
Jza is a jewel in the rough Jza is a jewel in the rough Jza is a jewel in the rough Jza is a jewel in the rough
Send a message via MSN to Jza
Can you replace timing belt without removing the engine?
__________________
Jza is offline   Reply With Quote
Old 06-28-2008   #2381 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
lol good story. Gay man FTL though
__________________
Rufus is offline   Reply With Quote
Old 06-28-2008   #2382 (permalink)
speedfoos
speedfoos's Avatar
It's always a frickin' adventure anytime I work on the car. I shouldn't expect anything less.
Yes you can replace the timing belt with the motor still in the car, it's just a little tight to work there on the side is all.
__________________
www.7thgenhonda.com
Old 06-29-2008   #2383 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold DsevenEm2 is a splendid one to behold
Send a message via AIM to DsevenEm2
bastard ring compressor! o well.. it was going to the machine shop anyway right?
harbor freight engine stand huh.. I was in there the other day picking up a few things like a test light, micrometer and caliper the other day and saw it and was like whoa.. hmmm...
Will it do the job? I wouldn't want that thing to magically fail somehow and drop the damn motor on the floor..
__________________
"We are defined by the choices we make"
MMI Gradutate - 11-21-08
Yamaha 5-star~Honda Level1~Mercury/Mercruiser Level1~Suzuki EntryLevel1~Volvo/Diesel EntryLevel1 -- Certified
Next step: United StatesCoast Guard - BC 12-06-08
DsevenEm2 is offline   Reply With Quote
Old 06-29-2008   #2384 (permalink)
speedfoos
speedfoos's Avatar
I hadn't planned on taking it to the machine shop since I was just going to throw everything back together with the stock rotating assembly and call it a day until I got back to the states, but such is life.
The engine stand is actually pretty decent though Jose. I was a little skeptical when I ordered it, but once it showed up, its pretty sturdy.
__________________
www.7thgenhonda.com
Old 06-29-2008   #2385 (permalink)
DsevenEm2
This is Myspace
DsevenEm2's Avatar
Thats good, I might end up picking one up. I'm sure I'll find use for it eventually. Im actually about to pay off my car. Still has tons of little issues and as of right now, its not "sellable". So when I pay it off and get an extra ride (hopefully a bike) ill be able to start fixing the little issues.
There are problems with it that I most likely wont be able to finish one day (random issues, lack of tools, time), so i'll need something on the side to ride in case I cant finish something on the Honda. So until then, I'm just living with the car. No mods or anything planned. I just want to get it back to a completely stock and clean state
__________________
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
