Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-06-2008   #2161 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
Re: FUBAR'd Main Bearing FTMFW!!! - (Pg. 144) - The Speedfoos' Turbo Thread!!
well clint, im afraid skipbarber is right, this is gonna be no small process, i do not envy you, well i do, cuz ur turbo, but this is not gonna be fun, sorry bro To remove this ad, register today for free or log in if already registered!
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Sponsored Links
Old 03-07-2008   #2162 (permalink)
civic-driver
Senior Member
civic-driver's Avatar
civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned
ok well i had a five hour drive today i started thinking about your car speedfoos, sad i know, and i had a thought about your oil. I remember that you said you run 5w-30 oil in your car. I also remember reading that if you use a heavy oil that the honda oil pumps , i believe it was on d-series i found this, that the stock oil pump can have troubles keeping up the pressure. So i thought that mixed with the oil leak that Andyman was talking about could have caused your problem with lack of "lube." it might be kind of a long shot but i thought i might through it out there.
also any word on the carrillo rods? do you know if they are only FI? maybe a possible NA? thanks man
__________________
My N/A research thread:
http://www.civicforums.com/forums/18...10-13-a-4.html
comments and everything else go here:
http://www.civicforums.com/forums/18...ment-here.html
civic-driver is offline   Reply With Quote
Old 03-07-2008   #2163 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
No biggie then. Tranny will come out tonight! Wish I had taken better pics when I had it out the other weekend. I can only make out B....B on it!
Yeah but 5W30 isn't that heavy and I'm pretty sure 98% of the turbo guys have been running that weight since Tom Cruise created turbos with his witchcraft. The D17 and D16 oil pumps are different from what I understand and the D17s don't have that same weakness, requiring shimming. I never had a pressure drop.
No word on the Carillos still. I just ended buying Bob's used Crowers. Carillos were designed for FI though. No reason you couldn't use them for NA, they'll just be heavier, but still strong enough to handle high-comp pistons.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 03-07-2008   #2164 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
I run 10-30, I'd never run a boosted car with anything lighter...
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 03-07-2008   #2165 (permalink)
speedfoos
speedfoos's Avatar
Yeah, she gets thicker dino pee on this next go-round, that's for sure. Blech. Really don't feel like pulling the tranny tonight. Gonna have to wait till after open court volleyball. At least I know none of my tranny bolts will be seized and that I can pull it out from the top once the water neck comes off (thanks again Rufus!).
__________________
www.7thgenhonda.com
Old 03-07-2008   #2166 (permalink)
speedfoos
speedfoos's Avatar
Here's a dumb question.
OK, so once I pop my tranny off tomorrow (too tired and too many beers tonight), I get the codes to determine which bearings I should need. I order the 12 crank bearings (2 extra for my temp fix) as per the chart, plus the appropriate plastigage. Now when installing the new bearings, there's a good possibility that I may need to use some different sized bearings depending on the wear I've put on the crank, right after checking the clearance with the plastigage? Theoretically, none of the stock-sized bearings could fit anymore and I may need to mix and match sizes to get the proper clearance right?
So instead of ordering 12 bearings, I might need to order a whole fuckload more in case I need to cover a different size range right?
Or am I just being paranoid?
__________________
www.7thgenhonda.com
Old 03-07-2008   #2167 (permalink)
CivicHatch9one
7th gen old timer.
CivicHatch9one's Avatar
CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned CivicHatch9one should not be questioned
Send a message via AIM to CivicHatch9one
that makes sense and is a great question. i do not know the answer but i will look around elsewhere to find out.
__________________
CivicHatch9one is offline   Reply With Quote
Old 03-07-2008   #2168 (permalink)
DaGriz
New Member
DaGriz will become famous soon enough DaGriz will become famous soon enough
Normally you would measure the crankshaft on each journal and record each journal's size to determine any out of roundness and if it is at all under sized. I suggest that after you polish the journal to get the brass scoring off, you measure it. I don't know in what increments new bearing are available. I suspect that you will need only a set of stock bearing for that one journal. I would hold off on buying the other until you tear down the engine and measure all the crank journals
DaGriz is offline   Reply With Quote
Old 03-07-2008   #2169 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
you can't mix and match bearings, the upper and lower halves of the bearings must be the same.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 03-08-2008   #2170 (permalink)
speedfoos
speedfoos's Avatar
I appreciate it Pete. And for anyone else who reads this, rest assured I'm digging around for answers too.
Thanks Dad, I need to dig around because I have never seen the actual bearing thicknesses listed with the bearing color.
Good stuff Edwin, that does bring down the potential numbers of bearing I could need, but there are still 7 sizes. For instance. The block I have sitting here is labeled BCCCC. Say for arguments sake, my crank is labeled 12341. This means I should only need to order these bearings (from left-to-right)
J1 - Pink
J2 - Green
J3 - Brown
J4 - Black
J5 - Yellow
But if my crank journals are a little run out, should I order one size up just to be safe? Edwin, did your crank take the bearings the code told you it would need? Where's my damn Captain Crunch secret decoder ring?
J1 - Yellow
J2 - Brown
J3 - Black
J4 - Blue
J5 - Green
I know bearings are cheap at $4 a pop, so that's not a big deal if I only have to order 10 of them, plus another 8 rod bearings (same concept and situation here) for the full build. But it will get stupid expensive if these numbers were to grow exponentially.
__________________
www.7thgenhonda.com
Old 03-08-2008   #2171 (permalink)
skipbarber
skipbarber's Avatar
the block and crank i used had 16k on it. the bearings it called for were almost too tight. my other block and crank on the other hand, would probably need undersized bearings because id need to have the crank turned..
__________________
sig by speedfoos
Old 03-08-2008   #2172 (permalink)
speedfoos
speedfoos's Avatar
Oversized is what you meant, right? Since you would have had to have the crank turned (taking material off) which would result in needing a bigger bearing to take up that slack. Hmm, OK. I'll just order stockers and size up when tomorrow then.
I rolled the other half of the main bearing out this morning and it's just as dorked up. I'm going to polish the brass marks off the crank with some 800 grit tomorrow and pull the tranny. The only thing I did on it this morning was get the other bearing half out and break loose the axle spindle nuts. I had to help my buddy fix his wife's truck today.
__________________
www.7thgenhonda.com
Old 03-08-2008   #2173 (permalink)
greeen01civic4d
balls in ur mouth
so whats the update clint, any pics of the journals?? or other bearings?? im curious to see the damage
__________________
Old 03-08-2008   #2174 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Damn, sorry Clint....I had to go outta town for a day....looks like all your questions have been answered.........I can get you the part numbers but like everyone has stated before. You need a measurement to know which you need. Sounds like you got it down now.
I wouldn't worry about a temp fix now. There is no temp fix. If that bearing is damaged I worry about that crank being damaged. I wouldn't drive it period. Take her back to the states and do it properly. Then you'll have a completely built 300+WHP SOHC civic done the right way. Plus you haven't done any permanent damage to the block or head. You temp fix it, drive it,. and you're gonna have some expensive paper weights
Just my 2 cents man! Just remember now matter how frustrated you get....It's just nuts & bolts man!!
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 03-08-2008   #2175 (permalink)
skipbarber
skipbarber's Avatar
they call thicker bearings undersized.
__________________
sig by speedfoos
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
