Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-20-2008   #2056 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Re: Holy crap, he put it on a dyno! - (Vid on Pg. 136) - The Speedfoos' Turbo Thread!
dont sound like a rod, i would guess a roller bearing of some sort as in throw out bearing maybe, does it change ever? To remove this ad, register today for free or log in if already registered!
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Sponsored Links
Old 02-20-2008   #2057 (permalink)
booba5185
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold
Send a message via AIM to booba5185 Send a message via Yahoo to booba5185
i know mine didn't sound like that, it clicked pretty bad, but i dont recall any squeeking or anything
__________________
I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
http://www.cnw.com/~seagull/public_h...y%20ninja1.gif Ninja #9 of the 7thgen Ninja Clan http://www.cnw.com/~seagull/public_h...y%20ninja1.gif
booba5185 is offline   Reply With Quote
Old 02-20-2008   #2058 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Doubt very seriously its a bearing man. I'm not familiar enough with your setup to have any idea. It could very well be a pinhole leak in one of your coolant lines somewhere. The thermostat doesn't open up until the engine reaches 170, therefore there is nothing circulating before then
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 02-20-2008   #2059 (permalink)
booba5185
booba5185's Avatar
take a long screw driver and put your eat on the end of it dude lol, i'd start under the thermostat spot (on the top of the engine), stick the screw driver down under and put your ear on it, kinda like a stethescope... maybe its coming from there? that'd be my first guess, since all the coolant goes in there for the most part
__________________
Old 02-21-2008   #2060 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
You know Andy, that's a really good point about the thermostat. I need some coffee to think through the ramifications of that. Good idea on the stethoscope booba. Be a better way to pinpoint it. Tom, it gets more continuous the warmer the car is. It's semi-intermittment after I start it once it's been sitting for like 10 minutes after the drive home from work (9 miles), but you heard in the vid, that it was pretty constant there. That's about the only change to it. I'll check higher RPM idle revs in the parking lot this morning at work.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 02-21-2008   #2061 (permalink)
speedfoos
speedfoos's Avatar
OK, drove it to work today and paid attention to the noises. After 3.5 miles - full operating temp - no noise. I go one more mile (to next stop sign) and I have the squeal at idle.
So I stick my head out the window and listen to when the noise quits. It stops above 2.5K in any gear under load, although in 1st it's still faintly audible until about 2.8K. When idling it stops the noise at about the same revs as in first when in motion.
Sounds clutch-related to me. Whether it's pilot or throwout bearing I don't know, my guess is pilot bearing though since the noise does not change when shifting through the gears.
I have no clutch slippage at all which is good. I'm still going to pull the pan and have a looksee, but I can drive it like this until I feel like buying a new clutch. I haven't decided what I want yet anyway.
This potentially good news. I've back down to WG PSI (about 7.5), just to be on the safe side though.
__________________
www.7thgenhonda.com
Old 02-21-2008   #2062 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Kinda sounds like what happened with my stage 3 comp clutch! Blew my tranny out, marble noise on turns, & that same loud squeal....mine was only related to clutch input. However both the noises sound the same. However....my thought is a bearing in the transmission. The pilot bearing does not turn nor the throw out. The noise sounds rotational in nature. Take a long pry bar and drop it right on the top of the bell of the transmission. Put ur ear on the end, I bet the noise is right there internally in the transmission.
My transmission had an intermittent knocking noise in that same spot the last week it was in!
Also, I had one 96 civic that came into the shop with that same noise. It sounded like a really bad belt slip. It was almost all the time until around 5-6k....The noise was definitely internal in the transmission. The customer op'd for a cheaper replacement than a rebuild. Problem fixed!
Just my two cents.....are transmissions are weak!
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 02-21-2008   #2063 (permalink)
speedfoos
speedfoos's Avatar
Yeah, weaksauce transmissions FTL. I hope it's not a tranny bearing. I know absolutely fuckall about transmissions. It's coming off this weekend though and I'll see what happens. The car is cooled down now so it won't make the noise. Will have to catch it tomorrow.
__________________
www.7thgenhonda.com
Old 02-21-2008   #2064 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
I remember replacing my tranny in a carport with no power tools. ugh
__________________
Rufus is offline   Reply With Quote
Old 02-21-2008   #2065 (permalink)
FoSho
Super Member
FoSho's Avatar
Actually.....Clint....our transmission are pretty easy but not without the right equipment. I wouldn't even try to do the transmission on my back.You have to drop the subframe. That is something you really need to keep in alignment. I've never seen anyone do one of ours on there back 2 feet off the ground. Not alot of room to play with! You also need an engine brace for the top to hold the motor!
I do my own but I have access to all this at my shop! Good luck man! I have extra transmission if you wanna try you're hand at rebuilding. It's tedious work but it's not hard at all!
__________________
75mm Throttle Body
Old 02-21-2008   #2066 (permalink)
speedfoos
speedfoos's Avatar
Yeah, everything is easy if you have the right tools! And I won't be using power tools either Rufus. Gonna stock up on beer and band-aids for when it's done.
I'm actually going to give dropping the subframe a whirl in my garage on jackstands this weekend. Engine brace can be done with some chain going to a rafter in garage. I'm going to measure the tranny height and see if I can get the car high enough for it to come out before I do it though. I've pulled the tranny in the shop before so I'll just working with limited clearance this time. We'll see. I'm more brave than I am smart sometimes! If you hang on to that extra tranny until this fall when I move back to the states, I'll definitely buy it from you.
__________________
www.7thgenhonda.com
Old 02-21-2008   #2067 (permalink)
FoSho
Super Member
FoSho's Avatar
Oh yeah....it's not going very far...haha
I'm near Ft. Riley if you come this way ever.....
__________________
75mm Throttle Body
Old 02-21-2008   #2068 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
I’ve done transmissions, clutches, engine replacements and everything in my garage on jack stands. Its not hard to all to get the sub-frame lined up you just need to mark it before you take it off. All with NO power tools.
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Old 02-21-2008   #2069 (permalink)
FoSho
Super Member
FoSho's Avatar
You're frickin brave man! I hate hate hate...with a captial H pulling subframes!!!!
I work smarter not harder I guess If I didn't have access to what I have...I'd be doing on my back too!
__________________
75mm Throttle Body
Old 02-21-2008   #2070 (permalink)
dopes6070
Ya I’m one of those work harder types haha. I just jump into it and hope I don’t drown. ROFL
__________________
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
