Honda Civic Member's RidesHonda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Re: What's this "reliability" you speak of? - (Pg. 130) - The Speedfoos' Turbo Thread
get that fixed.....hook the evac back up & let me know how that works!! As soon as It's warm I'm go time for evac, headgasket,studs, t-belt, water pump, & possibly IM
Aren't turbo cars fun Clint?
__________________ Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
Sponsored Links
Quote:
Originally Posted by speedfoos
It's my personal fight against Mother Nature. I hate the thought of that ozone layer hanging over my head, day after day, just waiting to come crushing down on the Earth. We need to do our best to get rid of it.
Bastard ozone, feeling like it's all high and mighty. I've had exhaust blown in my face many times, did i get a hole eaten thought my south pole? nope. pansy.
__________________ I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
Evac is good to go! Hooked it back up on Sunday and have been beating the piss out of the car like nobody's business and no smoke (from the exhaust anyway) now that oil leak is fixed. Press on with the evac setup man, it's good to go!
Steve, we've been watching that satellite spin idly for a while now. It's all dish and antenna anyway so will be pretty burnt up by the time it clears atmo.
Now I just need to fix my flaky idle. I hate piggybacks.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
I've probably got about 20 hours into the emanage on my car + whatever the tuner had in it. I've finally managed a rock solid 11.6-12.0 under boost....partial throttle is not an option still .....and my idle is solid unless really really cold....then it's rough for first 10 seconds....still can't get a solid afr while cruisin either.
There is just no way around our computers unless you completely take it out of the equation! Down with the piggyback!
75mm Throttle Body
I'm hoping that the AEM will perform well enough to keep my car from exploding when/if I ever get it. My half-tuned, mystery A/F ratio E-Manage hasn't blown her up yet... so I'm feeling positive about it.
__________________ 7thGen.MT.C. Automotive Photography Guide BenArts
Formerly: D17A2 Turbo @ 9psi 193.96HP & 179.36 lb/ft
Currently: D17A2 Turbo @ 5psi Way too rich HP & Way too slow lb/ft
I think your issue was fuel. You NEED bigger injectors. The 9psi on rsx injectors is pushing the limit. Emanage of course is not the best but you can make it work under the right circumstances.
Yep.....my injectors were super maxed out at 9psi....I ran it leaner to achieve the dyno numbers below but it would not be safe on street.....7-8 range is more doable!
75mm Throttle Body
I've just been putting off fucking with the tune. I need to send a datalog off to Chris but haven't cuz I've been too lazy to hook up the laptop. I may run some logs tomorrow though as this is getting just plain irritating.
I haven't spoken with Gerry since Sunday, Steve. Last I knew he would be done with them this week!
__________________
But here's my plans on building the motor.
When I get back to the states this fall, I'm going to buy a D17A2 off Ebay or some junkyard and swap that into the car and roll N/A for a while, I still have an HP header and my catback, stock injectors and stock airbox so I'll just rock w/o a cat.
This will give me the downtime needed to sell my PCS-XFC setup, resurface my FW, install a stronger clutch, and properly build the bottom end. I'm really not looking forward to running NA again, but it will be more motivation to finish the build. That's my plan anyway.
__________________
which motor are you planning on building up??? cuz it sounds like u are planning to build the a1 not the a2 when i would think its better to build the a2 and just leave the a1 in the car til its built... i think thats what you may have meant... either way clint, keep us updated like you always do and can't wait to see this thing in person!
Yup! And honestly when it comes to the massive amounts of boost that I will be running, I don't think there would be much difference between the two motors.
Headed back home after getting the directions to the dyno for tomorrow!
__________________
