Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-06-2008   #1951 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
Re: What's this "reliability" you speak of? - (Pg. 130) - The Speedfoos' Turbo Thread
He shouldn't have a problem with it threaded like that. Thats how I did my oil pan and never had a leak. I used Earls -10 an fittings. To remove this ad, register today for free or log in if already registered!
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Sponsored Links
Old 02-06-2008   #1952 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
isn't that basically like soldering it?
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 02-06-2008   #1953 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Basically yeah, brazing is like soldering it. You use an oxy acetylene torch and brass rod to braze the fitting to the pan. I've heard you can use a propane torch in a pinch, but I don't think that would get hot enough. However, my torch setup is back in the states so it's a no-go.
That leaky bung was an Earl's -10 and I still don't know why it leaks. Oh well. Just waiting on the new hose to get here to swap the pan out.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 02-06-2008   #1954 (permalink)
WilmncChris
Senior Member
WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light
What could be the cause is that is the location of the fitting. could be getting stress and being pulled in one direction and cause a small gap that will cause a leak.
WilmncChris is offline   Reply With Quote
Old 02-06-2008   #1955 (permalink)
speedfoos
speedfoos's Avatar
It is possible Chris, but I tried to make it a straight shot to the drain as much as I could. But that does make sense if the hose is exerting too much pressure, pushing the fitting up and towards the engine, causing it to leak out the bottom. Good point. Here's where it sits right now. New fitting will be in the same location, but I'll be using rubber hose (wrapped in heat shield) instead of braided, so it will flex more.
And here's that noise I was talking about. It is NOT/NOT coming from the intake, I haven't messed with that side of the exhaust, it's not the turbine still spinning (different sound , you can hear it) and that weird twitter at the end of the second clip is a bird.
YouTube - Speedfoos Mysterious Shutdown Whistle
If you are able to see this message it means that you don't have flash installed or that the video server is down.
__________________
www.7thgenhonda.com
Old 02-06-2008   #1956 (permalink)
tuningmycivic
Ultimate Member
i'm still a boost n00b, but it almost sounds like a boost pressure leak....but it's only apparent during shutdown....did it do it before you redid your evap/catchcan setup?
and why is you boost controller underneath the car? or is it just the angle of the pic?
__________________
Old 02-06-2008   #1957 (permalink)
speedfoos
speedfoos's Avatar
Naw Tony, that's just where it was sitting when I had most of the front ripped apart. It normally sits up by the coolant rezzy.
It didn't do it before the Evac setup, good idea. I need to have my wife shut the car off while I've got my head under the hood to try and pinpoint it. But definitely no boost leak that I can tell, spool is still wicked fast and consistent once the WG opens.
__________________
www.7thgenhonda.com
Old 02-06-2008   #1958 (permalink)
HonCiv02
Super Member
HonCiv02's Avatar
HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned HonCiv02 should not be questioned
kinda sounds like that pesky little gremlin lighting off bottle rockets under the hood of your car. that silly little bastard!
__________________
eat.sleep.honda.
HonCiv02 is offline   Reply With Quote
Old 02-06-2008   #1959 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned Eyger should not be questioned
Send a message via AIM to Eyger
holy crap I can't believe this thread is still going.....ha ha, it's all good.
That's a weird sound, maybe something to do with the BOV? Hm, Or maybe your tires are loosing pressure whenever you turn off your car?
Jk, hope you get it figured out.
Eyger is offline   Reply With Quote
Old 02-07-2008   #1960 (permalink)
speedfoos
speedfoos's Avatar
Nope, comes from the driver's front corner of the car. Which means it's either coming from the DP or the FMIC. Will troubleshoot more this weekend when I rip it apart to put the new oil pan in.
__________________
www.7thgenhonda.com
Old 02-07-2008   #1961 (permalink)
LogicWavelength
7th Gen Photographer
LogicWavelength's Avatar
LogicWavelength is a glorious beacon of light LogicWavelength is a glorious beacon of light LogicWavelength is a glorious beacon of light LogicWavelength is a glorious beacon of light LogicWavelength is a glorious beacon of light LogicWavelength is a glorious beacon of light
Send a message via AIM to LogicWavelength
Clint... just sell it and get an '87 Camaro IROC-Z.
__________________
7thGen.MT.C.
Automotive Photography Guide
BenArts
Formerly: D17A2 Turbo @ 9psi
193.96HP & 179.36 lb/ft
Currently: D17A2 Turbo @ 5psi
Way too rich HP & Way too slow lb/ft
T.E.A.R.S. Founder
Turbocharged Engines Anonymous Relief and Support Thread (T.E.A.R.S.)
You can't just add a K20 to a car like an extra plastic brick to your Lego people house.
LogicWavelength is offline   Reply With Quote
Old 02-07-2008   #1962 (permalink)
speedfoos
speedfoos's Avatar
Over my dead body will I ever own another GM piece of shit.
Unless it's a Firebird with the big graphic on the hood.
__________________
www.7thgenhonda.com
Old 02-07-2008   #1963 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
WS6 mmmmmmmmmmmmmm
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 02-07-2008   #1964 (permalink)
booba5185
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold
Send a message via AIM to booba5185 Send a message via Yahoo to booba5185
Quote:
Originally Posted by robbclark1 View Post
WS6 mmmmmmmmmmmmmm
Burt Reynolds never drove one of those tho.
__________________
I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
http://www.cnw.com/~seagull/public_h...y%20ninja1.gif Ninja #9 of the 7thgen Ninja Clan http://www.cnw.com/~seagull/public_h...y%20ninja1.gif
booba5185 is offline   Reply With Quote
Old 02-07-2008   #1965 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
I eat WS6's for breakfast. Clint, before long you should be too....
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
