Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-05-2008   #1936 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: I Hacked the Site and some Pipe - (Pg. 125) - The Speedfoos' Turbo Thread!!
Evac system works a little too good!
I was driving home yesterday - with my leaky fitting that I had slather with red gagunga juice - and this old couple in front of me had gotten on my last nerve. So popped into 2nd, gunned it, and boosted on by them. Only to look in my rearview and see a huge plume of smoke shooting from the ass end of my car.
Oh fuck. This is ain't good.
Oil pressure and temps are good. Coolant is good, car is running fine, so I ease the last mile home and park the car to let it cool. I'm thinking I blocked my return line with too much RTV and blew the seals on the turbo.
She finally cools down and I start ripping things apart, fearing for the worst. Plugs are nice and brown and so are the tops of the pistons. Check, no blown ring. Pull off the exhaust and the DP. Check, no oil in the discharge side. Pull off the intake tube and bottom charge pipe. Check no oil there either.
Problem found. Evac system works TOO well. Under boost, the intake mani valve shuts and all crankcase gases are evac'd into the exhaust, before the cat. Since this is pretty much uncombusted vapor, it makes a huge super Batmobile cloud of smoke as it gets dumped into the superheated exhaust stream.
= big fucking cloud of smoke.
Need less to say, I pulled the evac line out of my exhaust feed, stuck a filter on it and plugged the line going into the exhaust. I'll cut it off and weld it closed later.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 02-05-2008   #1937 (permalink)
FGCOUPE
Diamond Member
FGCOUPE's Avatar
FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all FGCOUPE is a name known to all
glad to hear you found and fixed the issue!!
FGCOUPE is offline   Reply With Quote
Old 02-05-2008   #1938 (permalink)
speedfoos
speedfoos's Avatar
Now on to the oil fitting debacle.
Motherfucker is still leaking although not nearly as much as it was before. This is still too much for my taste. So I get to thinking.
This country sucks if you want to find anything that isn't a factory part and getting work done is ridiculously expensive. This rules out buying an aluminum -10 AN bung and getting it TIG'd onto my old pan. Yes I can order stuff from the states, but that's a long time to be leaking oil. Plus the Rubi is gone so I can't deadline the Civic and steal Momma's truck.
Hmm. I converted the return on the turbo to take a standard nipple instead of an AN compression fitting.......that means I still have that 1/2" NPT to -10AN 45 degree fitting that came with my oil feed kit.......and I've got this virgin aluminum pan........and I've got a 1/2" step drill bit.......and a shit ton of JB Weld.......
Yep. My mom drowned all the stupid kids.
Shablam!!
Squeegle squeegle
Glorp!
Sceeerrrtttchch! (fitting was tight! probably didn't need the JB Weld, but it's insurance)
Fwivvvvvah!
Blerrrring!
So you can see that there is no chance for oil to leak out of the union between fitting and pan. It's threaded tightly, JB welded, and the geometry of the fitting end and the exit into the pan is such that it won't leak from there. I have the fitting I used to run on this (prior to converting to a nipple) and they never leaked.
So I think I'm good. I just have to wait for some hose to get here and I should be leak free once more.
Now I just have diagnose a new, strange whistle when I shut the car down that I have never heard before. Sounds like a boost leak, but I have zero signs and symptoms of one. Always an adventure.....
__________________
www.7thgenhonda.com
Old 02-05-2008   #1939 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
Re: What's this "reliability" you speak of? - (Pg. 130) - The Speedfoos' Turbo Thread
lol debacle lol
__________________
02BLKCIVIC is offline   Reply With Quote
Old 02-05-2008   #1940 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Damn Clint! I just ordered all of my parts for the evac setup!!!! DAMNIT!!!!!!!!!!!!!!!!!!!!!!!!!!
I guess we can just run the intake manifold side w/ check valves?
The whistle noise is very common especially with a cold air intake / have your wife shut it off & put you're ear to the turbo intake filter. I bet it whistles
Man, now what are we gonna do for evac?
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 02-05-2008   #1941 (permalink)
speedfoos
speedfoos's Avatar
Naw, this is a new whistle. It never used to do this. I'll take a little vid of it tomorrow morning and post it up. It does it when the intake tube is off the turbo as well. Weirdest thing.
I'm not sure what do to for the evac, I mean it's fine for the car to dump all that smoke out, but I think the tree huggers will end up slashing my ties and stuffing potatoes into my exhaust - although they'd have to be big ones because of the 3" tubing!
I mean, it's fine at this point with just a filter on the end and boost pressure pushing out it during boost (IM check valve closed) and the then it gets re-circed into intake charge during vac driving (former exhaust check valve closed). I would still run it the same, you now don't have to cut into the exhaust.
Debacle is one of my favorite words Don.
Quote:
Originally Posted by FGCOUPE View Post
glad to hear you found and fixed one of your issues!!
Quote fixed!
__________________
www.7thgenhonda.com
Old 02-05-2008   #1942 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light filipinop1405 is a glorious beacon of light
Send a message via AIM to filipinop1405 Send a message via MSN to filipinop1405 Send a message via Yahoo to filipinop1405
Well, i'm glad to hear that its coming along clint! gl with the rest of them!
filipinop1405 is offline   Reply With Quote
Old 02-05-2008   #1943 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
wow? jb weld? i knew that shi t was strong.....but i didnt know it was THAT strong....
so it never leaked on u speedfoos?
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 02-05-2008   #1944 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
ill bet ur whistle is in the exhaust somewhere, not to question ur skills, but i bet u have a pinhole leak somewhere that is creating a whistle.... its prolly ur only new addition to the car lately, id check there first, with a giant swap and some soap
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 02-05-2008   #1945 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
YOu could let your car suck up some of the seafoam crap.....It causes it to smoke like a big dog. I promise if there is a leak in your exhaust you will find it with this stuff....
Alpha 5 is offline   Reply With Quote
Old 02-06-2008   #1946 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
Hey alpha thats an awesome idea HAHA. I say go for that!
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Old 02-06-2008   #1947 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Thanks.....I just hope they have that stuff in the UK.
Old 02-06-2008   #1948 (permalink)
speedfoos
speedfoos's Avatar
Nope, no thanks on the Seafoam. I was thinking exhaust too Adam, but it's coming from the front of the car, and I didn't mess with anything before the cat.
The JB Weld is just insurance. That fitting threaded in really tight so I'm not worried about it leaking or moving at all even without the JB Weld.
__________________
www.7thgenhonda.com
Old 02-06-2008   #1949 (permalink)
WilmncChris
Senior Member
WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light WilmncChris is a glorious beacon of light
Just my two cents, but if that was my setup I would braze the fitting onto the pan.
WilmncChris is offline   Reply With Quote
Old 02-06-2008   #1950 (permalink)
filipinop1405
Diamond Member
I'm stupid but what does braze mean chris
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
