Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-05-2008   #1831 (permalink)
k20em2504
Member
k20em2504's Avatar
k20em2504 is on a distinguished road
Re: Where the F*$% is the Oil Coming From?! - (Pg. 122) - The Speedfoos' Turbo Thread
I would recommend replacing the valve cover gasket and not using rtv. Rtv will cause it to leak faster than just using the gasket. To remove this ad, register today for free or log in if already registered!
k20em2504 is offline   Reply With Quote
Sponsored Links
Old 01-05-2008   #1832 (permalink)
mooze
New Member
mooze is an unknown quantity at this point
i have found this special dye. of all places autozone had it
mooze is offline   Reply With Quote
Old 01-05-2008   #1833 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
VC gasket is brand new (twice now), until I figured out where the leak was coming from I just kept replacing it. I had a lot of extra ones from leaky HG woes.
Yeah, I can't remember the goofy order needed to get the upper cover off. I thought I had to remove the PS bracket - which is under the motor mount - to do so. I'll post the sequence up later today. And I'll be using RTV since Hondabond is like $30 a tube over here.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 01-05-2008   #1834 (permalink)
dopes6070
dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned dopes6070 should not be questioned
Send a message via AIM to dopes6070
Wow and I thought paying $12 for the tube was bad
__________________
Me - 2001 K20A2 Civic & 2005 Acura RL
GF - 2008 Civic Sedan
dopes6070 is offline   Reply With Quote
Old 01-05-2008   #1835 (permalink)
speedfoos
speedfoos's Avatar
Nope. That's cheap. This country is too bloody expensive.
So I didn't have to pull the whole rocker assembly off, thank God and you guys.
I loosed everything up, shot some RTV underneath and buttoned it back up. Here's what it looks like.
I will let it sit for tonight to cure (it's cold, gonna take a few hours) and will drive it tomorrow to see if that worked. I appreciate all the suggestions folks! Now to figure it out why my boost controller doesn't. This will also be tested tomorrow.....
__________________
www.7thgenhonda.com
Old 01-05-2008   #1836 (permalink)
FoSho
Super Member
FoSho's Avatar
FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light FoSho is a glorious beacon of light
Common problem I see all the time.....watch the cam humps aswell....I see alot of rtv at the ends...if you put too much rtv it will leak aswell.
__________________
Its one thing to know your car is slow. Its another to take it to a track, and get it in writing, in front of 200 people, that your car is REALLY slow - Ashole (Gotta agree 17.2)
193WHP & 166 ft lbs @ 9 psi (GReddy Emanaged Beotch)
Dezod V3 kit w/ Tial Blow off Valve & Wastegate
Hondata Managed & SRT4 Injectors (waiting to dyno still...)
75mm Throttle Body
Dezod 2.5" Back to 3" Vibrant w/ Resonator
FoSho is offline   Reply With Quote
Old 01-05-2008   #1837 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
hey clint, when will the problems end???? In all honesty, would u do this again if u had the opportunity?? what would u do differently?
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 01-05-2008   #1838 (permalink)
speedfoos
speedfoos's Avatar
Thanks Adam and Fosho, I will be watching to see if any more leaks come up. If they, do, I'll take you up on that offer of the dye Adam.
If I were to do it all over again......and would I........I've asked myself that a lot.
I've said before, every time the nitnoid repairs get me down, I just drive it to the freeway and just blast. It's such a joy to drive that it erases all my frustration. And yeah I know. It's a freaking Honda Civic. Not a BMW, or an Audi, or a Cadillac. It's a car that cost $18K brand new. And I love it.
Now. What would I do differently if I were going to do it all over again.
I would have gone right to real engine management, that way I wouldn't have to wonder if I'm going to get any money out of my PCS-XFC when I upgrade later this year. I wouldn't have bothered with the RSX injectors although I did break even on them , considering I sold them for what I got the SRT-4 injectors for. I wouldn't have wasted money on the Y8 mani bits. I would have gotten a welder before starting the build. That would have saved me all kinds of time and about $200. Um, I would have paid Chris for the tune in Taco Bell gift certificates instead of cash.
That's really about it. Most of my issues stem from never really getting up to my elbows in the guts of an engine before. I've made some stupid mistakes, but I think I've been able to recover from them pretty well.
Although later this summer when I get ready to do the bottom end build, it should be interesting. I'll be getting the rods in about a month or so, pistons are already en route. After that it's just bearings, gaskets, a couple tools and some elbow grease before I have a built bottom end.
There's no telling what I'm going to fuck up when I do that part of the build myself!
__________________
www.7thgenhonda.com
Old 01-05-2008   #1839 (permalink)
greeen01civic4d
balls in ur mouth
lol, thats too funny, ill be here to see what shit u break this summer
__________________
Old 01-05-2008   #1840 (permalink)
speedfoos
speedfoos's Avatar
Go check Matt's thread when you get a chance...
__________________
www.7thgenhonda.com
Old 01-06-2008   #1841 (permalink)
speedfoos
speedfoos's Avatar
The leak is fixed!!!! Thanks folks! Oh and I also figured out my boost controller. Now to just dial it in to 9 psi again.
__________________
www.7thgenhonda.com
Old 01-06-2008   #1842 (permalink)
dopes6070
Glad you got it fixed. I HATE leaks!
__________________
Old 01-06-2008   #1843 (permalink)
Alpha 5
Ultimate Member
Alpha 5's Avatar
Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned Alpha 5 should not be questioned
Send a message via AIM to Alpha 5 Send a message via MSN to Alpha 5 Send a message via Yahoo to Alpha 5
I love how you like to talk about my meat.
BTW, glad the leak is gone.
I am thinking about sending you a "Care" package. lol
Alpha 5 is offline   Reply With Quote
Old 01-07-2008   #1844 (permalink)
speedfoos
speedfoos's Avatar
Thanks Matt.
Alternator is here! :woot:
Going out to install it right now. And I notice there's already a DIY on how to RnR one so I don't have to feel guilty about not doing one!
__________________
www.7thgenhonda.com
Old 01-07-2008   #1845 (permalink)
speedfoos
speedfoos's Avatar
Alternator is in, but it appears to not have fixed anything. I'm going to pull out my gauge wiring and re-do it this week and see if that fixes it. Basically going to run new power wires to see if that helps anything. In fact I'm going to go do that right now.
__________________
www.7thgenhonda.com
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
