Go Back   Honda Civic Forum > GENERAL > Honda Civic Member's Rides
Honda Civic Member's Rides Honda Civic Member's Rides - Want to show off your Honda Civic mods? Need help deciding what Civic part, mod, or even what version Honda Civic to buy? Anything and everything about your very own Honda Civic member's ride goes here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-21-2007   #1696 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: It's Never Too Cold for Head - (Pg. 114) - The Speedfoos' Turbo Thread!!
^^^ Absolutely Dopes.
Cyls 2 and 3 were the ones with low compression, but those pics were after sopping up oil and coolant and scrubbing the old gasket off. And plus there are at the bottom of the stroke whereas 1 and 4 are up top.
And no, the work never really does end!
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Sponsored Links
Old 12-21-2007   #1697 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
your oil pan is on the way clint.
anyways, i really hope youre straight edging that block before you drop the head back on. you can spray as much copper shit on the gasket as you want, but if the deck and the head arent flat, it aint gonna seal. I wouldnt use the copper shit on a metal gasket IMO. it's already got that coating on it from the factory. what are you torqueing the studs to? and are you using moly lube to get the preload right? last time i did my oil change, i spotted some nasty watery oil mix on the cap, but the oil came out looking ok, and the coolant level has been the same since the motor went in, but the stuff in the catch can looked like watered down gravy. i need to re-think my breather setup because i think thats where the moisture might be coming in from.
grammar > me
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 12-22-2007   #1698 (permalink)
speedfoos
speedfoos's Avatar
LOL - send me you damn PayPal addy and the shipping cost already man!
OK, I straight edged the tops of the bores last night and everything was good. I'll do the block today and see what happens. The head I'm putting on there is flat - or so the machine shop told me, I'll have to believe them.
Studs are torqued to 60 ft./lbs as per ARP's recommendation. I did use the moly lube they came with when I installed them. I shouldn't have to re-seat them should I? None of them came out during when I loosened the nuts.
You're probably right about the moisture being breather-related. I'll be completely re-doing my setup with some check-valves and plumbing it into both the IM and the exhaust to get all that shit out of the engine.
__________________
www.7thgenhonda.com
Old 12-22-2007   #1699 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
dude clint, ur fuckin crazy, i hope all goes well, good news about ur cylinders too, im curious to see how this all turns out, its looking pretty crazy, i hope when ur all done u turn the boost way up and go at it(with a video camera on board of course), u are torquing the head studs right... im sure u are, just make sure u r doing it in the correct order, what is the correct torque anyway?
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 12-22-2007   #1700 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light
Send a message via MSN to DaRk_MauL
Hey clint if the head still off could you take a pic from the cyl wall?
because i am still wonder about those lines i got at the top I think its from
the piston rings but could ya check? thx in advance.
__________________
http://users.telenet.be/seriousspace/Jdmvicbanner.jpg
NA [I/H/X]:15.68sec on 1/4 mile
boosted: not yet
DaRk_MauL is offline   Reply With Quote
Old 12-22-2007   #1701 (permalink)
speedfoos
speedfoos's Avatar
Yeah, the head's still off, let me go outside and snap a pic real quick.
Adam, the correct torque on head bolts is like 48 ft./lbs IIRC and on the the ARP studs it's either 60 or 65, I'll check before I spin them back on. In regards to turning up the boost, I should be able to make more power at less pressure, so - if things go well - 6 psi with the new head will feel like 9 psi on the old head.
Everything is just about ready to go back on the car. I still need to do the valve lash, but I finished prepping everything else. Let me go get those pics Ching.
__________________
www.7thgenhonda.com
Old 12-22-2007   #1702 (permalink)
speedfoos
speedfoos's Avatar
Fucking brrr! It's cold out!
Oh and one other thing...
3000th POST FTMFW BITCHES!!!
All right Ching, here you go.
I also opened up the ports on the manifold a little bit today to accommodate the hogged out exhaust ports on the new head a little better. Did the rough work with my drill and rasp bit and then cleaned it up with a dremel. They start at about 37mm and taper down. The exhaust ports on the head are 40mm, but I don't want to attack the mani too much in case this head is shit and I have to PnP the one I just took off.
And then I attacked the cool side of the turbo with my wire brush. A clean, shiny turbo is a a happy turbo. I did a bunch of other stuff today too, but nothing worth taking pics of.
__________________
www.7thgenhonda.com
Old 12-22-2007   #1703 (permalink)
greeen01civic4d
balls in ur mouth
awesome, when do u think ur gonna be done reinstalling? i really want to hear that baby roar, i think ur really gonna like the pnp head, as long as it was done correctly and well, otherwise it might suck, im also wondering if ur gonna have to re-tune to get your idle back because of the different cam and bigger ports...
__________________
Old 12-22-2007   #1704 (permalink)
speedfoos
speedfoos's Avatar
I should be able to have it running tomorrow. As soon as I find my Hayne's manual for the valve lash specs and torque settings for the rocker arm assembly, I'll do the lash. I think it's in the car.
Yeah, I'm going to have to re-tune. I'll get it close by myself, and for the rest of it, well that's what I paid Chris for. One year's worth of tunes - good until Sep 08.
__________________
www.7thgenhonda.com
Old 12-22-2007   #1705 (permalink)
booba5185
7thgen Terminator Ninja
booba5185's Avatar
booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold booba5185 is a splendid one to behold
Send a message via AIM to booba5185 Send a message via Yahoo to booba5185
hey is the valve clearence the same on a pnp head? or do you have to change it at all (from the norm .009 and .007)
__________________
I am the South West CLIT Commander
Quote:
Originally Posted by My Father
A friend bails you out of jail, a best friend is sitting next to you in jail saying, "She didn't look like no cop did she?"
Sportin the DX with the high performance piston return springs, are you?
http://www.cnw.com/~seagull/public_h...y%20ninja1.gif Ninja #9 of the 7thgen Ninja Clan http://www.cnw.com/~seagull/public_h...y%20ninja1.gif
booba5185 is offline   Reply With Quote
Old 12-22-2007   #1706 (permalink)
DaRk_MauL
Super Member
hey clint thx for pics by the way it looks you got the same wear and probably more miles to so its normal.
Good job on enlarging the mani ports.but yeah those 40mm port are real big
on the head dude.
Nice love polishing job the turbo deserve that right.
peace
__________________
boosted: not yet
Old 12-22-2007   #1707 (permalink)
speedfoos
speedfoos's Avatar
Quote:
I would assume it's the same since you're only adjusting the space between the rocker arm and the top of the valve when the valves are closed. The PnP only affects things when the valves are open and working. I'll find out for sure when I crank it over tomorrow.
I've got about 39K (miles) on this block Ching. Those two cylinders are also the ones that showed the major compression loss too.
Valve adjustment is done!
__________________
www.7thgenhonda.com
Old 12-22-2007   #1708 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
i take it then you found your Haynes manual?
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Old 12-22-2007   #1709 (permalink)
speedfoos
speedfoos's Avatar
LOL - yeah, but the valve lash specs weren't in there. Even in the section of the book where it outlines the procedures it says, "refer to the beginning of this chapter for the valve specifications". But they weren't there. Search button and Gray's Valve Lash Adjustment DIY FTW!!
So how do like the turbo now Tony?
__________________
www.7thgenhonda.com
Old 12-23-2007   #1710 (permalink)
tuningmycivic
Ultimate Member
how's that for an answer?
__________________
Tags
383 , burning , civic , em2 , kit , mercruiser , motor , oil , pics , speedfoos , strocker , stroker , tribute , troubleshooting , wrangler
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Post your sedan pic!
Post Pics Of Clean Jdm 7th Gens
2004-2005 Post Your Ride
Page 210 = The New Project!! -The Speedfoos' 383 Stroker thread!!
PINOYS! Sound off and post your Civic Pics!
2001 - 2003 Post your ride....
Varnerr88 new jdm thread pictures and talk come on in..
Lets see those BLACK Civics!!!!!
7th Gen Members Rides Accident's and Crashes Thread
EM2Crew Reppin (56k keep dreamin)
Site Supporters
aluminum radiator
Honda car spoilers
