TEIN Question
Lowest NHBP coupe in San Francisco
I looking into TEIN for my 03 civic coupe. Is it right TEIN only has the SS for our cars? Is there A FLEX for the EM2?
PLEASE HELP OUT
PLEASE HELP OUT
There is also the Tein Basic.
For your to fit the Tein Flex you would have to cut holes in your hood.
Autocross Junky
Tein Claims that the Si version of the Flex Dampener needs or requires any modification to fit on our cars. weather or not it does remains to be seen.
rsx and si FLEX systems will fit our cars with modifications...tein said because of that they're going to make adjustments and release the FLEX for the em2 in the next 6 months or so...
Autocross Junky
it depends on your aplication. for autocross they have a little mild of a spring rate. best to go with the Flex springs (Yes, Tein will mount them on the SS's if you ask). also, the flex dampeners come with intergrated camber plates wich is a much better (More accurate, easier to adjust) system then camber bolts. too bad they are so damn expensive.
martinsmartin
Aug 15, 2015 07:34 PM
EM_WON
Jul 22, 2015 06:49 PM
