Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-28-2003   #1 (permalink)
StreetLevelPerformance
Your Parts Guy
StreetLevelPerformance's Avatar
StreetLevelPerformance is on a distinguished road
Installing JIC-Magic FLT-A2 tonight have questions...(update INSTALLED)
Will the RSX kit fit without modification? Obviously no one on this forum has them installed but does anyone know of anybody that does?
thanks
__________________
Street Level Performance
sales@streetlevelperformance.com
Fuel Return Conversion Kit
NRG Strut Bars
TSI Extreme Turbo Kit
StreetLevelPerformance is offline   Reply With Quote
Sponsored Links
Old 05-28-2003   #2 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
I think it will need modification. Hondawerx says that you need control arms from a RSX, but other than that I don't know.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 05-28-2003   #3 (permalink)
SlammedBlueEM2
All Eyes On Z
SlammedBlueEM2's Avatar
Send a message via AIM to SlammedBlueEM2
Quote:
You need RSX tie rod ends. I think the stock tie rod might need to be shaved a little, but I cannot say how much.
Front axles if you're doing the brake conversion but that won't work unless you have the K-series engine with it because where's the intermediate driveshaft going to go for a D17 engine?
__________________
Retired
SlammedBlueEM2 is offline   Reply With Quote
Old 05-28-2003   #4 (permalink)
Your Parts Guy
actually I just found out from Zeil Motorsports that the EP ones will fit and thats what we are installing. for anyone interested, the EP FLT-A2 are out.
__________________
NRG Strut Bars
Old 05-28-2003   #5 (permalink)
Nitek
Member
Nitek is an unknown quantity at this point
i believe the rear lower shock mount may have to be shaved fit the shock in (correct me if im wrong). other than that, it should be straight up forward. Just wondering where did you get the jic flt-a2 from and how much? If you can i like to see pics.
Nitek is offline   Reply With Quote
Old 05-28-2003   #6 (permalink)
Spider883
9K Redline Owns U
Spider883 will become famous soon enough Spider883 will become famous soon enough
Send a message via ICQ to Spider883 Send a message via AIM to Spider883
how much are they?
__________________
03' S2000
If it isn't broken then take it apart and make it better.
Spider883 is offline   Reply With Quote
Old 05-28-2003   #7 (permalink)
SlammedBlueEM2
All Eyes On Z
I hope they work. I thought it was the RSX one.
__________________
Retired
Old 05-28-2003   #8 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
A little off topic, but I was checking out the Different top end suspensions for our car, mainly Tein Both the SS and Flex and The JIC jic flt-a2 . the SS is the weakest of the spring rates, at 336F/448R for the civic model and 448F/559R for the RSX. next up is the jic flt-a2 at 450F/506R for both the RSX and Si versions. lastly the Tein Flex is rated at 448F/559R the same as the SS versions for the same car. It will be interesting as to which setups jic flt-a2 Vs Tien Flex will enhance our cars performance the most. both have taken different approches. Tien going with a more agressive spring rate on the rear (i assume to get as much weight to the back in corners) where Jic went with a weaker back but a stronger front. On paper it looks like the Tien will help get the back to rotate better(less understeer or possibly Oversteer) where Jic looks to have taken a more moderate route (possibly more Understeer Vs. Tien) Both the jic flt-a2 and the Tien Flex cost about the same $1800-$1900.
Interesting..........
B&G is not listed here because they dont publish the spring rates of their suspension.
Zzyzx is offline   Reply With Quote
Old 05-28-2003   #9 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
you got jics??? daaaamn thats sick foo...
EP3.. only thing you might have a problem with is alignment. aswzero had a problem with it. something to do with the tie rods. ya i know if it was for the DC5 you would have to shave 1mm of each side of the lower rear bracket. damn thats a nice setup tho, take pics of it if you can
VNlilMAN is offline   Reply With Quote
Old 05-28-2003   #10 (permalink)
SlammedBlueEM2
All Eyes On Z
That's what I was trying to point out. I forgot to mention that it was the toe angle he had an issue with.
A little toe out ain't bad if you're racing though it'll cause more wear on the tires. But for street, it's not necessary.
__________________
Retired
Old 05-28-2003   #11 (permalink)
Your Parts Guy
i forgot my dam key for my locking lugs so we couldnt put them on....im so pissed. i am going first thing in the morning to do the install and will have pics soon after.
zeil motorsports (importer of JIC-Magic) says that these will fit the 7th gen coupes and sedans without modification. i gotta say these things are beautiful i cant wait to install them.
__________________
NRG Strut Bars
Old 05-28-2003   #12 (permalink)
Your Parts Guy
ya they were sitting in the box at the shop teasing me.
__________________
NRG Strut Bars
Old 05-28-2003   #13 (permalink)
Your Parts Guy
Quote:
EP not RSX I didnt know which one they sent when i started the thread
---slammedBlueEM2---
the front lets you adjust the camber not sure about the rear didnt get to see them yet.
--spider883---
cant post what i paid.
__________________
NRG Strut Bars
Old 05-28-2003   #14 (permalink)
SlammedBlueEM2
All Eyes On Z
For the rear you need a camber kit. That's the only good thing about our stock front suspesnsion compared to the traditional 4-wheel double wishbone is that you can adjust the front camber with the JICs.
Those coilovers retail for $1,980 as per JIC-Magic.com.
I can't wait for you to put'em on. I want to be 100% sure that the EP3 ones work.
__________________
Retired
Old 05-29-2003   #15 (permalink)
Your Parts Guy
couldnt install my friend had work to do but i have the coilovers in a box in my trunk ill take pics after work.
__________________
NRG Strut Bars
Old 05-29-2003   #16 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
damnit hurry up.. lol i think i'm more excited about this than you are...
btw people at clubrsx.com got theirs for 1600.. i'm sure the si's are the same..
Old 05-29-2003   #17 (permalink)
Your Parts Guy
Here's a shytty pic for ya. They are definitely going on Saturday morning at 9 am no excuses. We couldnt do them today cause I had a suprise walk-through on our house that my fiancee and I are having built. I'll take more/better pics after work.
__________________
NRG Strut Bars
Old 05-29-2003   #18 (permalink)
Your Parts Guy
pics as promised...
__________________
NRG Strut Bars
Old 05-29-2003   #19 (permalink)
Your Parts Guy
another...i am very excited to install them im just having bad luck everytime i try to.
__________________
NRG Strut Bars
Old 05-29-2003   #20 (permalink)
ViNRoCk8
#1 S2000 Fan
ViNRoCk8's Avatar
those are hot, that is the next thing I am buying. An ill set of coilovers
tell us how the ride is on saturday. Good Luck
__________________
I have a K20 subframe for sale, perfect condition.
$225 shipped, anywhere in the U.S
I don't have my civic anymore so I don't need it.
PM me.
ViNRoCk8 is offline   Reply With Quote
Old 05-30-2003   #21 (permalink)
SlammedBlueEM2
All Eyes On Z
I'm sure the ride quality on those is nothing less than impressive, but I am sure dober will say something along those lines.
It gets no better than JIC-Magic. And that is in my unbiased opinion.
__________________
Retired
Old 05-31-2003   #22 (permalink)
Your Parts Guy
We installed them (EP - FLT-A2) this morning and I've been driving around on them all day. I can barely get a finger in there and the rear is tucking a little tire. I think they are without a doubt the best modification i've done so far.
Of course when I went for the first drive I really put the JIC's to the test. They performed just like I would expect them to, exceptionally well. I have the damper setting on about halfway between the hardest setting and the softest setting and it handles like a dream. I went over bridges that gave me whiplash before with my neuspeed race springs and it felt like stock. Also, steering the car was ten times easier than it was before. I think there is a little oversteer, I need to get a alignment bad. When taking corners at high speeds the car seriously feels like a go-kart, very minimal body roll and i have no other suspension mods. Another thing that I noticed is when taking off from a dead stop the car stays planted and doesnt jerk back like it used to. I think that will make a little difference next time at the track : )
Here are some pics I took after the install. I will take my wheels off tomorrow and take some more pics.
EDIT- Installation was a breeze we took our time and finished in two hours and thats with rebalancing my wheels and tuning the JIC's
__________________
NRG Strut Bars
Old 05-31-2003   #23 (permalink)
Your Parts Guy
anotha from the back...
__________________
NRG Strut Bars
Old 05-31-2003   #24 (permalink)
Your Parts Guy
camber adjustment at my fingertips....
__________________
NRG Strut Bars
Old 05-31-2003   #25 (permalink)
TOOLOWCIVIC
Ultimate Member
Damn thats sweet. I want those. How low can they go??
TOOLOWCIVIC is offline   Reply With Quote
Old 05-31-2003   #26 (permalink)
Your Parts Guy
.5 to 3 inches....you can tuck the ish out of the wheels!!!!!
__________________
NRG Strut Bars
Old 05-31-2003   #27 (permalink)
TOOLOWCIVIC
Ultimate Member
So is the ride bouncy or what??
Old 05-31-2003   #28 (permalink)
Your Parts Guy
not at all with the setting i have right now they ride better than stock. when i hit bumps they rebound instantly. i could stiffen it up a little but i like the way it rides for daily driving.
__________________
NRG Strut Bars
Old 05-31-2003   #29 (permalink)
SlammedBlueEM2
All Eyes On Z
dober... I am so jealous... if you didn't live on the opposite coast of me, I'd hunt you down.
Sweet - sweet - sweet. You mentioned performance but forgot ride quality. But when you do give us some info on ride quality, tell us how it rides/handles on various settings.
And I'm extremely glad that Ziel made it work on the coupes/sedans without modifications.
Car looks good, too. No doubt they can go lower than Teins.
JIC-Magic.
__________________
Retired
Old 06-01-2003   #30 (permalink)
InanimateCarbonRod
Ultimate Member
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enough InanimateCarbonRod will become famous soon enough
Send a message via AIM to InanimateCarbonRod
Wow, those look nice!
__________________
InanimateCarbonRod is offline   Reply With Quote
Old 06-01-2003
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
All The Suspension Info You Need!! Please Read!!!
7th gen ball joint DIY
PLEASE READ: 2K1 Suspension Replaced
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
