Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-22-2003   #1 (permalink)
Civic2k1racer
Senior Member
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
just installed my neuspeed F U bar
i finally installed it today...it took a while, the bar didnt line up correctly, so i tried jakcing up the drivers side, it didnt help, it was the same(i even loosened the third bolt) so i was ready to give up...i lowered the car back down, then tried to place the bar on the drivers side first, then force it on the passenger side, it worked. i torqued it to 33 ft lbs, does anybody know how much u torque that third bolt that i had to loosen for jacking up the drivers side, i did it to about 33 ft/lbs anyway. well its kinda wet out so i didnt really test it out fully. the car still does lean like crazy when i turn, i know its only a strut bar, but ill test it out more when it dries up outside. i really didnt notice better steering as much as i thought i would
im gonan install my x brace next week, so hopefully ill notice more of a change
Civic2k1racer is offline   Reply With Quote
Sponsored Links
Old 05-22-2003   #2 (permalink)
Weaponx12o
Ultimate Member
Weaponx12o's Avatar
Send a message via AIM to Weaponx12o
why'd you have to jack up the car? mine just popped in place, err kinda had to force it at times. but it fit nonetheless. every bolt for that should be torqued 33 ft. lbs. show pics of your x-brace install.
__________________
* life without knowledge is like death in disguise *
Too Low Club #6
Weaponx12o is offline   Reply With Quote
Old 05-22-2003   #3 (permalink)
Civic2k1racer
Senior Member
i tried jacking it up cause it says to in the instructions if it doesnt fit into place. i thought maybe they sent me the bar for the wrong car or something, it was impossible to fit it on the drivers side after puttin it on the passenger side first, so i tried putting it on the drivers side first, then the passenger, then it fit.
Old 05-22-2003   #4 (permalink)
Sweetpants
Member
Sweetpants is an unknown quantity at this point
Send a message via AIM to Sweetpants
i jacked my car up when i put mine on. wasnt a big deal just moved the strut around until the bolts lined up with the strut bar.
Sweetpants is offline   Reply With Quote
Old 05-22-2003   #5 (permalink)
Pharoh
Bobaganoosh!
Pharoh's Avatar
Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of Pharoh has much to be proud of
Send a message via AIM to Pharoh Send a message via MSN to Pharoh
I had to jack up my ride. I pitty the fool that ever has to take off my bar...there's alot of pressure on it.
Pharoh is offline   Reply With Quote
Old 05-23-2003   #6 (permalink)
Weaponx12o
Ultimate Member
Weaponx12o's Avatar
you have to try to put it in at the same time. it's harder to install if you do one side at a time.
__________________
Too Low Club #6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Megan Racing coilovers...update after 10 days, post 24
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
