Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-12-2003   #1 (permalink)
sovereign82
Member
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
Send a message via AIM to sovereign82
The never ending Squeek Saga Continues
Well I worked on the car this weekend. It seems I had two different squeeks. One I fixed, the other one I did not.
My passenger side squeek is gone. It was always a minor squeek coming from that side and it was a simple fix...
When I took apart the rear driver's side, it now sounds like its the SPC Camber's brushings that are squeeking up a storm. I lubricated them up with some spray lubricant and it helped...a little...for awhile, the car only squeeked when I was stopping (which is still very annoying). Within 30 minutes, however, the car was squeeking nonstop once again. So now I believe its the camber...but how to fix it? I have no idea...maybe I have a defective one or something....
Details of the squeek....
When I jacked the car up, there was no noise on the way up....when I let the car down, there wasn't any squeeking at first....the tire hit the ground...no squeeking...but I would say as soon as the majority of the weight was put on the tire, the squeeking was INTENSE and LOUD...a very rubbery sound....the rest of the way down when removing the jack was sooooo loud.
My car is going into a shop for some bodywork so I'll probably have them take a look at the squeeking and see what they say...but I'm afraid they are going to say "you just need to lube up the brushing"....I already did that . Any other ideas?
Matt
sovereign82 is offline   Reply With Quote
Sponsored Links
Old 05-12-2003   #2 (permalink)
noname
Reppin' "Custom Concepts"
noname's Avatar
noname is an unknown quantity at this point
Send a message via AIM to noname Send a message via Yahoo to noname
replace the camber kit?
noname is offline   Reply With Quote
Old 05-12-2003   #3 (permalink)
sovereign82
Member
then i need a new alignment...has anyone else ever had a defective one?
Matt
Old 05-12-2003   #4 (permalink)
djmota
djmota's Avatar
djmota is just really nice djmota is just really nice djmota is just really nice djmota is just really nice
did you do the install on the rear kit?
If so you are not supposed to tighted down the inside big bolt (the one with the bushing) untill the suspension is loaded...(car on the ground)
not doing this will flex the bushing one way once your car is on the ground
Try loosening the inside bolt, let your car down and then tighted it up.
It sounds like you bushing is moving. Its not supposed to. Doing what I described should fix it ..if not then the damage is already done.
If you need to replace them just line the new one up side by side next to the old and adjust until they are equal. no alignment needed.
__________________
133.48 whp 117.57 tq all motor untuned dynojet
188.87 whp 187.99 tq 75 shot n20 untuned dynojet
147.5 hhp 130.5 htq all mtr tuned church's dynapack
my old d17 set up.
now swapped k20a2 4.7fd lsd kpro
djmota is offline   Reply With Quote
Old 05-12-2003   #5 (permalink)
sovereign82
Member
I just the shop that did the alignment do the install, i didn't think it was worth jacking the car up to tighten a few screws. Thanks for the advice, i'll give it a shot....but how am i supposed to tighten the inside screw with the car on the ground?
Old 05-12-2003   #6 (permalink)
Mex
Ultimate Member
Mex's Avatar
Mex is a jewel in the rough Mex is a jewel in the rough Mex is a jewel in the rough
Send a message via AIM to Mex
this is very true. here's what it may look like:
I just finished switching out the old bushings with new ones today, dropped the car, tightened the bolts, and the car sounds wonderful!
btw, once you lower the car, you just have to crawl underneath to reach those bolts. or you can lower your car with your wheels on jackstands-- that gives you more room, but it's more effective if your car is level.
Mex is offline   Reply With Quote
Old 05-12-2003   #7 (permalink)
djmota
djmota's Avatar
exactly! good luck
__________________
my old d17 set up.
Old 05-12-2003   #8 (permalink)
sovereign82
Member
dbl post...this network jack sux~
Old 05-12-2003   #9 (permalink)
sovereign82
Member
it doesnt look torn like that...but Im pretty sure the guy didn't do it right...I dont think he was their normal "alignment specialist". On another note, I left SPC an email on Friday. I received a call from them today and the gentleman left me his name and extension. Extremely impressive! I will call him tommorrow and get his take on this as well. Thanks guys.
Hmmmm my car is like 2" off the ground...Ill have to do the jackstands or try to look through the wheel and stick my arm in there lol.
Old 05-12-2003   #10 (permalink)
djmota
djmota's Avatar
when I did mine I used the hand thru wheel technique...too low to get all the way under there.
__________________
my old d17 set up.
Old 05-13-2003   #11 (permalink)
Mex
Ultimate Member
Mex's Avatar
bad news guys. the squeak is slowly starting to return. so it must not be from that lower bushing (though that may have been part of it). I also have an SPC kit in the rear.. please post to let me know what's going on! I literally took everything apart when i fixed that bushing.. every other part on the car looks fine I wonder if my rear strut tower bar has something to do with it...
Old 05-13-2003   #12 (permalink)
SlammedBlueEM2
All Eyes On Z
SlammedBlueEM2's Avatar
Send a message via AIM to SlammedBlueEM2
I dunno.
I've had squeaks in the rear suspension before. First it was just the passenger side GC coilover.
Now it's just the entire rear, or both sides.
Then I noticed BOTH stock struts were leaking.
So yup... it's definitely my struts.
SlammedBlueEM2 is offline   Reply With Quote
Old 05-13-2003   #13 (permalink)
SlammedBlueEM2
All Eyes On Z
BTW, I have the SPC camber kit, too. I don't see how it could ever squeak.
Old 05-13-2003   #14 (permalink)
sovereign82
Member
Well I redid it today and it was squeeking a little (but much improved) at first...and now its gone completely away....lets hope it stays this way. Mex, if you would like, I can give you the number to a gentleman at SPC who specializes in their support...let me know.
Thanks all~
Matt
Old 05-13-2003   #15 (permalink)
sovereign82
Member
Quick question about the front suspension....I have the "popping issue" because I didn't align the arrows properly...It seems like a pretty easy fix. Anyways, if I work on the fronts but return the car to the same height (and I dont adjust the cambers), can I save my wheel alignment? Or will I mess that up no matter what?
Matt
Old 05-13-2003   #16 (permalink)
dj02
Post Master General
dj02's Avatar
dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all
Send a message via AIM to dj02
Quote:
Matt
u still need a alignment. any time u mess with the hight u need to get a alignment.
__________________
-OuTuViT-
"Computer games don't affect kids,
I mean if Pac-Man affected us as kids,
we'd all be running around in darkened rooms,
munching magic pills and listening to repetitive electronic music."
-Kristian Wilson, Nintendo, Inc, 1989
it has been said that sometimes,
something as small as the flutter of a butterflys wing
can ultimatly cause a typoon
half way around the world
-chaos theory
The Edge... there is no honest way to explain it
because the only people who really know where it is
are the ones who have gone over.
-Hunter S. Thompson
dj02 is offline   Reply With Quote
Old 05-13-2003   #17 (permalink)
sovereign82
Member
Im not going to be chaning the height though...I just need to simply remove the suspension, make a minor adjustment on the top, and put the suspension back on.
Matt
Old 05-13-2003   #18 (permalink)
djmota
djmota's Avatar
no change in hieght no problem with alignment.
__________________
my old d17 set up.
Old 05-13-2003   #19 (permalink)
sovereign82
Member
http://www.geocities.com/sovereign82/bolt.JPG
thats the bolt u need to loosen and tighten when the car is on the ground....its geocities, so cut and paste the link
Old 05-13-2003   #20 (permalink)
Alignment Man
Member
Alignment Man is an unknown quantity at this point
Alignment problem
Jack the car up a little so the wheels clear and put a slip plate unde the wheel, you can take a plastic gallon milk jug and cut off the flat sides put two piece together and lower the wheels. take a nut on a piece of string hold it against the top of the tire an dmessure how far the sting is from the bottom of the tire. After you do the work check to make sure you have the same readings after you are done, if not you need a trip to the alignment shop.
Alignment Man is offline   Reply With Quote
Old 05-14-2003   #21 (permalink)
sovereign82
Member
NOoOOoOoOoO!!! The Squeak has returned....calling SPC today.
Matt
Old 05-14-2003   #22 (permalink)
sovereign82
Member
I just got off the phone with SPC. It looks like they will be sending me a new rear camber arm. If you are experiencing a similiar problem, feel free to PM me and I'll give you the gentleman's name and number at SPC who deals with their problems.
Thanks,
Matt
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
All The Suspension Info You Need!! Please Read!!!
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
