Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-31-2009   #211 (permalink)
BigVic4545
Member
BigVic4545 is an unknown quantity at this point
Re: Do It Yourself Spring Install - Detailed Info & Pics
spray a TON of WD40 spray and let it sit for 10 minutes....then grab a socket wrench and use all the power u have. To remove this ad, register today for free or log in if already registered!
BigVic4545 is offline   Reply With Quote
Sponsored Links
Old 01-31-2009   #212 (permalink)
elementalchain
Member
elementalchain's Avatar
elementalchain is an unknown quantity at this point
This DIY was amazing. Although it took me 4 hours to do the fronts and hour and half to do the rears. This was by myself and my OEM jack. Also, this was the first major thing that i did to my car myself so i took my time and followed it to a T.
elementalchain is offline   Reply With Quote
Old 02-02-2009   #213 (permalink)
Duf
New Member
Duf is an unknown quantity at this point
Quote:
hi,
i got one loose, but the left one is stuck like hell sprayed a hole can on it let it sit for about 15 minutes and i pulled it like a maniac but it's still not loose
someone with ideas that can help me get this bastard loose?
Duf is offline   Reply With Quote
Old 03-07-2009   #214 (permalink)
fiend
Senior Member
fiend's Avatar
fiend is an unknown quantity at this point
Just what i was looking for, just got my new rims in, once i get my struts, rotors, and maybe new lowering springs, i'll be using this thread, no point in puttin on my struts then takin it all apart again when i get my new springs in. just gonna wait for all the parts so i can drop it on new springs, struts, rotors, rims, and tires, great job man! definitely will be a HUGE help! installed coilovers on a friends cobalt so i have some idea of whats goin on.
fiend is offline   Reply With Quote
Old 04-07-2009   #215 (permalink)
westcali_playa
Member
westcali_playa is an unknown quantity at this point
this seems liek a bitch to do
westcali_playa is offline   Reply With Quote
Old 04-07-2009   #216 (permalink)
amexicancarguy
Member
amexicancarguy's Avatar
amexicancarguy is a glorious beacon of light amexicancarguy is a glorious beacon of light amexicancarguy is a glorious beacon of light amexicancarguy is a glorious beacon of light amexicancarguy is a glorious beacon of light
it is! its easy but time consuming. this is a great DIY tho. easy to follow.
__________________
Civic: Its not how fast you can go but how long you can last...
amexicancarguy is offline   Reply With Quote
Old 04-08-2009   #217 (permalink)
westcali_playa
Member
sucks i got my tein stechs but i dont have the right tools...hopefully il get a day off soon and get some jack stands and a few others.. shops by my house charge from 4-5 hundred for install wtf!
Old 05-04-2009   #218 (permalink)
primesession21
New Member
primesession21 is an unknown quantity at this point
This was great. put on my h&r springs last night and threw on some 15" fat fives
primesession21 is offline   Reply With Quote
Old 07-06-2009   #219 (permalink)
bigworm
New Member
bigworm's Avatar
bigworm is an unknown quantity at this point
wonder who will be the first to loose his teeth when disassembling front struts
bigworm is offline   Reply With Quote
Old 07-07-2009   #220 (permalink)
Tib_05
New Member
Tib_05 is an unknown quantity at this point
Quote:
Originally Posted by Albertross View Post
Knocking sound - Most likely the nuts that tighten down the struts via the upper mount are not tight.
Binding/Popping sound - Seated incorrectly, or you need some thick grease to grease the upper mounts and where the spring sits.
I have the same problem only on the left side what could it be,
-my spring is seated correctly and perfectly indexed
-my endlinks and strut mounts bearings are brand new
-my ball joint, tie rod end, sway bar bushings and compliance bushing are ok
My next step is the top mount, if its not that i really dont know what it is?????
Thanks
Tib_05 is offline   Reply With Quote
Old 09-23-2009   #221 (permalink)
VicBNimble
Member
VicBNimble's Avatar
VicBNimble is an unknown quantity at this point
Tib_05, it sounds like your top mount. When I installed my springs, everything was tightened down correctly but after a few minutes of driving I heard some knocking in the front while going over bumps in the road. Turns out the springs had settled and the top mount needed to be tightened.
__________________
05 LX SE Coupe SSM manual
Revo SS, Spoon knob, LED Tails (Black), Black housing headlights, Injen SRI, DC strut tower brace, HKS Hi-Power axle-back, custom HKS grille emblem (lol!), Azul Sprint-5 17"s w/Nitto Neogen 215/45s, H&R Sports (1.5" drop), Ingalls camber kit, DIY rolled rear fenders, ACT prolite flywheel (8.5lbs), more to come...
VicBNimble is offline   Reply With Quote
Tags
07 , 2001 , chassis , civic , compressor , dix , diy , front , honda , install , installation , metric , spring , springs , steps
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
