Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-02-2002   #1 (permalink)
Kapriccio
Member
Kapriccio is an unknown quantity at this point
Question on Eibach ProKits
I’ve just ordered the Eibach ProKit Springs for my 2K2 EX Sedan. I have 17” rims with 215/45’s and would like to know if you think it’s really necessary that I get a camber Kit? These springs will only lower the car about 1”, which is about what I’m looking for, as I do not want to loose to much comfort and drive on bad streets, just get rid of the 4x4 look. Anywone has pics of a sedan with Eibach ProKits installed? What are your comments on the ProKits if slamming is not the objective?
Kapriccio
Kapriccio is offline   Reply With Quote
Sponsored Links
Old 08-02-2002   #2 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
i know slamming isnt what your going for. and you want the ride comfort as stock n everything but i still recommend neuspeed sports. it gives a dropped look but isn't low enough where you have to worry about scraping or whatever. i got them on my coupe and i thought it wasnt low enough, i basically ride it as if it was stock except over speed bumps and steep driveways. but ya this is just my 2 cents... if your still planning on the prokit then you probably wont need a camber kit with it. atleast i wouldnt get one, i'm not even getting one for my neuspeeds. its always recommended tho. and i'm not sure about the prokit on sedans but i know the sportlines dont look too good on sedans cause the rear sits lower then the front. i think the prokit should work fine with a sedan tho cause i heard the prokit is pretty low on the front but very high on the back, on a sedan the drop might be even. but ya i still dont think its low enough to notice its dropped, and your still going to have alot of wheel gap left too...
VNlilMAN is offline   Reply With Quote
Old 08-02-2002   #3 (permalink)
Kapriccio
Member
Thanks VNlilMAN. So I'll take it I really don't need the camber kit with the ProKits. About your recommendation of the Neuspeeds, I already ordered the ProKits, so I'm just going to have to wait and see how much my car lowers and how well the handling improves. Also, I think you're right, the ProKits won't lower my car much, but since I have a wife and 3 kids, It wouldn’t be practical to slam my car to much. I still would like to hear some opinions by members who have the ProKits.
Old 08-02-2002   #4 (permalink)
Mbow
Member
Mbow's Avatar
I had the prokit springs on my sedan. The rear sat much lower than the front. I had ~3 finger gap in the front and a 1 finger gap in the rear. It rode great and not too much worse than stock. Obviously, the front dropped ~1inch but the rear must have dropped ~2 inches or so. The rear did need the camber kits. The rear camber was sitting at negative 2.5 degrees on each side. If the rear had dropped an inch it probably could have slid by w/o any camber correction. I didn't like the uneven drop and I wanted a bigger drop, so I went with the neuspeed sport springs. Also, the prokit springs are known for causing "sagging" on the sedan models. Neuspeed differentiates the coupe and sedan springs. I have a perfectly even 1 finger gap at all four corners. Also, the neuspeed sports will require camber kits at least for the rear. The ride is pretty harsh imo, but not too bad. I and the people that ride in the car can definately tell it's lowered by the way it rides. Speed bumps and bumpy drives and parking lots have to be taken at snail pace. It's not a terrible ride and everytime I walk up to my car, I just say damn because she looks so good.
Oh, and if your camber is sitting at negative 2 degrees or more, get the camber kits unless you like replace tires every year.
Mbow is offline   Reply With Quote
Old 08-03-2002   #5 (permalink)
dragoon
Post Master General
dragoon's Avatar
Send a message via AIM to dragoon
you probably got the coupe springs.
dragoon is offline   Reply With Quote
Old 08-03-2002   #6 (permalink)
BlackSI
Platinum Member
BlackSI is an unknown quantity at this point
pro kits are as close as stock as you can get, and it lowers your car about an inch. Camber kit is prob not necessary.
BlackSI is offline   Reply With Quote
Old 08-03-2002   #7 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
Quote:
Quote
[hr]Originally posted by: dragoon
you probably got the coupe springs.[hr]
eibach onlu makes coupe springs, i guess i'll confirm this after mbow's post. so i guess the only springs for sedan is neuspeed or goldlines... well coilovers are another option too..
Old 08-03-2002   #8 (permalink)
Kapriccio
Member
VNlilMAN, I ordered my Prokits from Tire Rack, and the description said they are for the "2/4dr" and the Eibach part no. is EIB-4051-140, just as you had specified on your very informative post on springs. So, aparently Eibach feels that their springs fit the coupe and the sedan. Is there really a difference between the coupe and sedan springs?
Old 08-03-2002   #9 (permalink)
dragoon
Post Master General
dragoon's Avatar
only the rear ones, i believe
Old 08-03-2002   #10 (permalink)
Zolutar
Senior Member
Zolutar's Avatar
Location: Utah, while roaming Montana, Idaho and Wyoming
Zolutar is an unknown quantity at this point
Send a message via Yahoo to Zolutar
I just installed the eibach prokit on my 2k1 coupe, and my car needed the rear cambert kit as it was out almost 2.5 degrees. The ride is harsher than stock but the look is fantastic. I will post newer pics soon but I couldnt imagine the drop any lower.
Also in reguards to the drop difference with different models, the rear I dont know about, but for the fronts, the drop will vary depending on the engine, as the Ex motor weighs more than the lx/dx. The springs were probably designed for an ex, so a lx sedan is not going to sit "right"
Zolutar is offline   Reply With Quote
Old 08-04-2002   #11 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
Quote:
Quote
[hr]Originally posted by: Kapriccio
VNlilMAN, I ordered my Prokits from Tire Rack, and the description said they are for the "2/4dr" and the Eibach part no. is EIB-4051-140, just as you had specified on your very informative post on springs. So, aparently Eibach feels that their springs fit the coupe and the sedan. Is there really a difference between the coupe and sedan springs?[hr]
i know eibach says they're made for both 2 door and 4 door but majority of the people with sedans complain that the rear sits lower then the front. this is obvious cause the sedans weigh much more in the rear then the 2 doors. if you look at eibach springs on a 2 door, the drop is even, imagine you put more weight in the back and of course the rear is going to sit lower. this is why neuspeed and goldline have made 2 seperate springs cause they acknowledged that the sedans weigh more in the rear. but ya dont take my word for it, ask people with eibach springs on a 4 door, i knoe 'mbow' has this problem
Old 08-06-2002   #12 (permalink)
RE
Member
RE is an unknown quantity at this point
Quote:
Quote
[hr]Originally posted by: Zolutar
Also in reguards to the drop difference with different models, the rear I dont know about, but for the fronts, the drop will vary depending on the engine, as the Ex motor weighs more than the lx/dx. The springs were probably designed for an ex, so a lx sedan is not going to sit "right"[hr]
How much of a weight difference is there between the LX and EX models? I don't think it would be a significant factor. Also what is the weight difference between an auto and manual tranny?
RE is offline   Reply With Quote
Old 08-06-2002   #13 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
dx: 2,405 lbs.
hx: 2,434 lbs.
lx: 2,465 lbs.
ex: 2,553 lbs.
its probably like a .2" difference.
Old 08-06-2002   #14 (permalink)
Mbow
Member
Mbow's Avatar
Quote:
Quote
[hr]Originally posted by: VNlilMAN
Quote:
Quote
i know eibach says they're made for both 2 door and 4 door but majority of the people with sedans complain that the rear sits lower then the front. this is obvious cause the sedans weigh much more in the rear then the 2 doors. if you look at eibach springs on a 2 door, the drop is even, imagine you put more weight in the back and of course the rear is going to sit lower. this is why neuspeed and goldline have made 2 seperate springs cause they acknowledged that the sedans weigh more in the rear. but ya dont take my word for it, ask people with eibach springs on a 4 door, i knoe 'mbow' has this problem[hr]
HAD that problem. I got the neuspeed sports now thanks to you. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Don't you remember my posts?
Old 08-06-2002   #15 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
sorry, thats what i meant to say, had not has. but ya glad you like them now
Tags
eibach , prokit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
