Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-11-2002   #16 (permalink)
y2k2ciVic
Member
y2k2ciVic is an unknown quantity at this point
Send a message via AIM to y2k2ciVic
well said goldline!!! I am interested in your springs any comments or why yours over eibach or neuspeed. To remove this ad, register today for free or log in if already registered!
y2k2ciVic is offline   Reply With Quote
Sponsored Links
Old 07-11-2002   #17 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
just to let you know i didn't necesarily become a mod cause i know more. i dont want my opinion or information to be valued more then any other member on this board just because of my title... n to clear things up when i meant "sag" in this particular post i meant that the back is going to be lower then the front(cause if you look above that sentence i did say "sag in the rear"). didnt mean that the springs itself will sag(settle over time, giving a lower drop after a year).
and you would probably know more about this so i guess these are questions from me... arent springs measured in how many lbs it takes to lower it one inch? so if the system weighs 100 and the spring rate is 300. wouldn't it be 1/3" and not 1/2". and arent lowering springs progressive meaning that they have a different spring rate depending on the part of the spring your looking at. for example having a 100lb system in your trunk would drop it 1/3" more but having a 300lb would only drop it 1/2"(remember this is just an example) more and not 1" more cause its a progressive spring.
VNlilMAN is offline   Reply With Quote
Old 07-11-2002   #18 (permalink)
GoldLine
Member
GoldLine is an unknown quantity at this point
I see you've done your home work. You are absolutely correct. Spring rate is lbs per 1" of deflection(or spring travel). Now I don't want to split hairs, but Imentioned that the spring rate is "almost" 300lbs and would represent "almost" 1/2". So yes, your absolutely correct. 100lbs of stereo equip would generate 1/3" in ride height. Keep in mind, this is a fairly heavy spring rate for a Honda. 92-00 Civic spring (rear) rates are in the 190lb range.
As far as sagging goes, if a spring is made well, there should be no sagging other than the spring seating on the rubber pad(which normally occurs in the first 48hrs). In my opinion, (and it's only an opinion) Eibachs, Neuspeeds, H&R, Progress, Gold Lines (of course) are fairly similiar in quality and manufacturing techniques. Stay away from anything "not" built in the US. Although, that can be somewhat difficult due to the fact that everyone "claims" there springs are made in the US. Fact of the matter is, other than the ones I've mentioned above, and possibly a few others, most springs are manufactured off shore. The US may not build a fantastic car, but they have their s___ together when it comes to building coil springs.
In regards to variable rate springs, from ride height down to solid height, springs are(for the most part) only functioning as a single/linear rate spring. The variable rate comes into play primarily when the strut is at full droop, coming back down to ride height. The softer rate allows the vehicle to come back to a ride height much softer. Then, as the spring, or vehicle, reaches normal ride height, the spring transitions into a straight rate design. Not the most technical reasoning, but I'm trying not to lose anyone.
Hope this helps. Any other questions, please feel free to contact me in the office anytime.
Jeff
GoldLine is offline   Reply With Quote
Old 07-11-2002   #19 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
are the goldline spring rates 300 for our cars and 190 for 99-00? if it isn't, do you know the exact specs for both cars? just wondering why there is such a huge difference. and btw what is the stock spring rate?
Old 07-12-2002   #20 (permalink)
GoldLine
Member
To be exact, the spring rates on the 01> are 290lbs. The 92-00 Civic rear rates are 190lbs. The difference being completely different platforms. Struts located in different positions cause for different spring rates. Keep in mind that these are rear rates only. Stock rates on the 01> are in the range of 250-260lbs.
Old 07-12-2002   #21 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
woah 100lbs difference... i wonder what makes the rears on our cars so bouncy even when they have a stiffer spring rate.
Old 07-12-2002   #22 (permalink)
GoldLine
Member
Have you driven in a vehicle w/Gold Lines?
Old 07-12-2002   #23 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
nope, but i heard they were great. but ya sorry i'm sold on neuspeeds tho. although i would most likely choose goldlines over eibach. IMO they(eibach) are way overrated and overpriced because of that. but ya on my list it goes 1) neuspeed, 2) goldline 3) h&r 4) eibachs, probably wouldnt even mess with the rest...
Old 07-13-2002   #24 (permalink)
WishIWaitedForRSX
Member
WishIWaitedForRSX is an unknown quantity at this point
Here are pics of stock struts with Eibach Sportline on stock rims, dropped 3 days ago.
I like the drop... Not overdone. Not as high as the Prokits.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF422.jpg (47 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF424.jpg (48 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] ACF426.JPG (71 Kb)
WishIWaitedForRSX is offline   Reply With Quote
Old 07-13-2002   #25 (permalink)
Mbow
Member
Mbow's Avatar
Looks very nice! Seems to be just a little higher than the neuspeed sports I just installed. I have a 1 finger gap at all corners.
She will look great with some new wheels.
Oh, glad to see you are keeping the nbp baby clean!
Mbow is offline   Reply With Quote
Old 07-13-2002   #26 (permalink)
WishIWaitedForRSX
Member
Quote:
Quote
[hr]Originally posted by: Mbow
Oh, glad to see you are keeping the nbp baby clean![hr]
Hell ya... The first thing that came to mind when I looked at the car after it was drop was: Man those rims are TINY.
Just had a wash and wax. Such a b!tch to keep these black cars clean and tidy!
Old 07-15-2002   #27 (permalink)
Voiceofid
End Bringer
Voiceofid's Avatar
Send a message via AIM to Voiceofid
well, this page helped me a lot, i was debating between eibach and neuspeed, guess i was right choosing neuspeed, my local shop quoted me for about 210 shipped for neuspeed sports, pretty good? and my friend would install them for about 150... or should i wait till i buy all 4 camber before i do it? and then do the shock/spring and camber all at once?
Voiceofid is offline   Reply With Quote
Old 07-15-2002   #28 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
uh.. i got mine installed for 210... you could find neuspeeds for 140 shipped... i got mine for 140 at a local shop by working them down from 155. installation should only be 80-100 on average... i got mine done for 70. thats supposed to be your boy and hes charging you 150? if it was my boy i would do it for free or dinner the most...
Old 07-16-2002   #29 (permalink)
y2k2ciVic
Member
Thas our general rule, your boys when your done you have to take all of the mout to eat. Hey vnlilman you gotta wacth your friends tho, it took me two days to do a full drop on my accord,=) with 4 of us we bullsh!tted alot. =) they milked me out of two dinners for all 4 of us. 40 bones, them bastards.
Old 07-16-2002   #30 (permalink)
Voiceofid
End Bringer
Voiceofid's Avatar
Quote:
Quote
[hr]Originally posted by: VNlilMAN
uh.. i got mine installed for 210... you could find neuspeeds for 140 shipped... i got mine for 140 at a local shop by working them down from 155. installation should only be 80-100 on average... i got mine done for 70. thats supposed to be your boy and hes charging you 150? if it was my boy i would do it for free or dinner the most...[hr]
the local shop claim that they are getting the springs from their source at 180 dollars, and maybe it's just where i live, locally, a spring install cost about 300-250 for JUST the install, so 100-150 bucks for the install sounds good to me...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
