Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-03-2002   #1 (permalink)
WhosYoDadday85
www.ImportFactor.Com
WhosYoDadday85 should not be trusted WhosYoDadday85 should not be trusted
Send a message via AIM to WhosYoDadday85
Air Suspension FAQ (Good)!
What is the difference between manual and fast bags?
The difference is in the valves. Manual kits use manual pneumatic switches. These switches are slower than electric valves. Manual valves include the gauge, switch, and valve together. This requires the air line to be plumed directly to the switch. The switch assembly would need to be mounted in a place that would allow air to exit the system and all the hoses to be plumed. Air is release direct from the switch.
Electric valves or fast bag valves use electric switches and gauges. The valves can be mounted in any location. The switches and gauges can then be mounted in a suitable location and only need the wires ran from the electric valve. Electric valves can also be used with a remote control, Playstation style controller, or 10-switch pre-wired box allowing for seesaw, all up, all down, etc., with a flip of the switch.
What are air struts or strut bags?
Most front wheel drive cars use McPherson struts. Most struts are a combination shock and coil spring. Air struts are the same except the coil spring has been replaced with an air bag. This allows the McPherson strut equipped car to have the capabilities of the air bag suspension.
Are air bag suspension reliable?
Yes. If installed and maintained properly, an air bag suspension system will last as long as any other suspension component.
I heard strut bags can twist and bust. Is this true?
While it is true that early strut bag systems where not very good, today's air struts are much better. The new air strut systems will turn with the strut assembly and not bind up.
What do the air bags replace?
On most vehicles the air bags completely replace the springs and shocks. Some vehicles can still use their shocks.
What are air cylinders or air rods?
Air cylinders where designed for vehicles that may not have a place large enough to mounts an air bag. Hondas need to use air cylinders because the strut tower is not wide enough to use an air bag.
How is the ride quality?
It depends on your vehicle. If you are using really low profile tires or no shocks, you could have a rough ride. Most ride problems are from not having enough air in the bags. If the ride quality is poor, just put more air in the bag.
Air cylinders will ride rough. If you have air cylinders and are experience a rough ride, install a set of air accumulators. That will help your ride.
What are air accumulators and how do they work?
The problem with air cylinders is that they do not have any give like bags. When you hit a bump the air has no place to go. Air accumulators give the air a place to go. When you hit a bump, the air goes from the cylinder to the accumulator. The air then returns from the accumulator back into the cylinder when you are driving normal. The accumulator also is filled with nitrogen gas like a shock. This allows the accumulator to give a smoother ride.
WhosYoDadday85 is offline   Reply With Quote
Sponsored Links
Old 06-03-2002   #2 (permalink)
2k2civicballer
Member
2k2civicballer is an unknown quantity at this point
Send a message via AIM to 2k2civicballer
thanks that was very informative
2k2civicballer is offline   Reply With Quote
Old 06-03-2002   #3 (permalink)
Spider883
9K Redline Owns U
Spider883 will become famous soon enough Spider883 will become famous soon enough
Send a message via ICQ to Spider883 Send a message via AIM to Spider883
great info
making sticky
Spider883 is offline   Reply With Quote
Old 06-04-2002   #4 (permalink)
WhosYoDadday85
Thanks. I was surfing the net for info on air suspension, and I found it. Great addition to the "general" FAQ if you ask me[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old 06-05-2002   #5 (permalink)
EManEX
EManEX's Avatar
EManEX will become famous soon enough EManEX will become famous soon enough
Thanks,
Very informative.
EManEX is offline   Reply With Quote
Old 06-06-2002   #6 (permalink)
TOOLOWCIVIC
Ultimate Member
Are you planning on getting airsuspension? That is what I'm trying to get but CIVICONBAGS says he has airbags and his cars ride quality sucks. I am waiting to see if one day I get an a car with airsuspension and see how it rides.
TOOLOWCIVIC is offline   Reply With Quote
Old 06-07-2002   #7 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
the ride quality depends on how you 'tune' it. not sure but heard the lincoln town car was on bags, if it is that ish rides nice...
VNlilMAN is offline   Reply With Quote
Old 06-11-2002   #8 (permalink)
TOOLOWCIVIC
Ultimate Member
If you have airbags not airrods can you still put air accumulators?
Old 06-11-2002   #9 (permalink)
WhosYoDadday85
I dont know TOOLOW....
From my understanding, I think that air accumulators only go with air rods because the air has no where else to go where as with bags, the air can move and and such......
Old 07-20-2002   #10 (permalink)
TOOLOWCIVIC
Ultimate Member
Well I saw a 2k2 civic on airbags. I asked him if they were bags or rods and he told me bags. When he was driving his car looked as if it had blown shocks. It was too bouncy. I went to the place where he said he got them installed and the guy there told me that the airbag kit had just came out for the 7thgen and that the car I saw was the first to have it. I forgot to ask him what company made it but he told me that if I got the kit it would ride better than factory. From what I saw it was bouncy. Now I am having second thoughts on airsuspension. BTW he quoted me $2600 total installed. They were actually airbags with a strut.
Old 07-20-2002   #11 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
its probably the one made from chassis tech... they use 'air struts'.
Old 07-20-2002   #12 (permalink)
TOOLOWCIVIC
Ultimate Member
Well civicpunker ordered that kit. I am going to wait to see what he has to say about it and how it compares to his old suspension setup.
Old 07-27-2002   #13 (permalink)
errorr
Member
errorr is an unknown quantity at this point
Send a message via AIM to errorr
got cylinders on my prelude it rides better then factory. Ride quality depends on if its a FBSS system or a FB system size of line u are running and the cylinder quality. got mine from www.the-hack-shack.com 1 year ago. I wouldnt suggest their kit anymore its to massed produced now. CLICK TO SEE PICS thats my lude sits low dont crack my kit or nething any more got a civic for daily tho [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
errorr is offline   Reply With Quote
Old 07-27-2002   #14 (permalink)
TOOLOWCIVIC
Ultimate Member
Hey error, why would it matter if its fb or fbss. Shouldn't it ride the same? I heard bags ride better than cylinders. So if I get the bags or airstruts for my car it should ride good enough for a daily driven car? Do you have accumulators on you car.
Old 07-28-2002   #15 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
damn your lude looks pretty phat... and i think hack shack uses air cylinders from eai.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
Megan Racing coilovers...update after 10 days, post 24
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
PLEASE READ: 2K1 Suspension Replaced
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
