Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-12-2002   #76 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
ey whussup faint
just to fill everyone, he's from clubrsx.com. he knows alot about suspension specifically in the air/hydro area.
some compressors can fill up a 3 gallon tank in like 2 mins.. its not that long, but ya its long enough so that you cant really "play" around with it. thats why bags is mainly just to lower/raise the car. and i'm sure they make accumulators for air cylinders, i've seen them before. and theres always air struts, civicpunker has them on his ride and he said the ride is great. keep in mind lincolns are on factory non-adjustable bags and those ride nice..
n for the front we have plenty of room for cylinders, its just the bag that is limited.. let me try to invite civicpunker into this convo cause he actually has strut bags on his ride... i'm sure it was all bolt on and the steering rod was connected to it...
VNlilMAN is offline   Reply With Quote
Sponsored Links
Old 12-12-2002   #77 (permalink)
FaintReality
Member
FaintReality is an unknown quantity at this point
The strut bags work bitchin cause you just slide the bag over the stock strut/shock, replacing the spring. The only problem is that this usually won't allow you to lay the car out. I had them for my 00 Celica and it only lowered the car approx. 2.5", far from where I wanted it. You will need to cut the strut down shorter, and get a shorter shock, if at all possible, to lay the car out. Check out the air cylinders and air struts from www.dzmotorsports.com Their air cylinders are the only ones I know of that have a built in shock and the upper mount both pivots and rotates for less tower and cylinder stress. http://www.showtimehydraulics.com also has a pair of bags that you use with the stock strut in which they claim to be the only leak proof bag on the market.
__________________
02 DSM RSX-S with many mods...
http://images.cardomain.com/member_i...07_77_full.jpg
Click here for pics Make sure to rate my vehicle and sign my guestbook!
FaintReality is offline   Reply With Quote
Old 12-12-2002   #78 (permalink)
FaintReality
Member
By the way, the first air setup on my 91 s-10 consisted of a 5 gallon tank and 1 compressor. It took about 10min to fill that tank, and you could only get 2 full hits out of the front...I then got (2) 12 gallon tanks and a belt driven compressor, man, it was like juice. I could hit it all day long without any problems or worrys. Let me tell you, it aint cool when you are driven tuckin 3" of rim and you come to a corner not being able to hit the front due to lack of air. Needless to say, my fenders were tweaked to hell. My truck had a 2.5" body drop though, so in your hondas you shouldn't have to worry about that...
__________________
Old 12-12-2002   #79 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
theres different type of strut bags, the one civicpunker got i believe replaces both spring and STRUT. n dont s10s need big bags, thats why you would run out after 2 hits. n not sure what compressors you had but i'm sure there are much better ones out there(i'm talking about the regular ones and not the belt driven. also i've heard you can use the AC air compressor).
i dunno i'm an air man, the thought of having a trunk full of batteries scares me. but then i guess the thought of having 2 pressurized tanks scare some people too.
Old 12-12-2002   #80 (permalink)
BiGDoG
Super Member
BiGDoG's Avatar
BiGDoG is on a distinguished road
Send a message via AIM to BiGDoG Send a message via MSN to BiGDoG
I still dont know what to get [IMG]i/expressions/face-icon-small-confused.gif[/IMG],from reading i think hydros r the way to go but that means no more system [IMG]i/expressions/face-icon-small-sad.gif[/IMG] ... I want a kit that lowers the front more...so which one should i get, im thinking of doin something by spring time so help me out here
BiGDoG is offline   Reply With Quote
Old 12-14-2002   #81 (permalink)
FaintReality
Member
Unless you plan to hop, 2 batteries is all you need with a hydro setup. I have 2 pumps, 2 batteries, 2 subs, 3 amps, etc. and it will all fit in the trunk with no problems. Be creative, not ghetto...
About the air, yes, on my S-10, I had 2600lb bags on all 4 corners, but they are not much bigger than the 2500lb bags used with the air struts. Go talk with anyone with air and unless they run compressed air or have a belt driver compressor, I will bet you they bitch and complain. Everyone I know of does, which is the big downfall for air. The bigger comressors are a little quicker, but still take several minute to fill a small tank in which will only give you a few hits do to all the weight in the front. You will be able to hit the rear up several times since there is no weight in the rear. Also, the bigger the compressor, the more current it draws from the alt. If you have a stereo systems, you can forget bumpin while the compressor are running (which is almost all the time) since your headlights and interior lights will dim dramatically, to the point where they almost turn off. Not trying to scare anyone away or push them towards juice, just giving you the facts from my previous 2 air equiped vehicles and from all my friends experiences as well. I admit, I wanted to put the RSX on air, since I had all these stereotypes about juice, but once I did my research, talked to a couple different shops that specialize in adjustable suspension (MIC, and Totally Polished) as well as other owners with juice, I then realized it is totally different on a daily driver than a hopper, and gave it a shot. I am now more that satisfied, and would not go back to air...
If you do go air, I would use compressed air or you will eventually get fustrated and wish you did other wise. Just be careful with them PSI levels or you will blow a bag.
__________________
Old 12-14-2002   #82 (permalink)
spanky
Super Member
spanky's Avatar
spanky is an unknown quantity at this point
Send a message via AIM to spanky
I dunno about the messed up ride with cylinders. I have alot of friends turn to cylinders and they ride smooth. I still have a car on Hydros and i like it but its a bitch to maintain. I been dealing with Hydros for 9 years and there good to a point as so is air. They both have there down falls. Personaly i like them both but i get a better ride out of cylinders then i do with hydros. and also there is a way to have a belt driven compressor in a honda/acura the only bad thing is losing the air con but i did it. I give props to the person with the rsx it looks nice. The only thing i have to say is that AIM and BLOWJACKS are the only company that people should stay away from. Also there the same company so dont think one is better then the other because AIM, BLOJACKS, AND CHASIS TECH are the same people so dont get ripped off. But what ever you choose its up to you. If i was you i would try to find out from people that have kits that you really know and that will tell you which one to buy. get some with hydros and some with air and you figure it out.
Because anyone can tell you that they like it but when you know someone they can be more honest with you.
spanky is offline   Reply With Quote
Old 12-14-2002   #83 (permalink)
FaintReality
Member
Spanky: On your hydro setup, do you use springs, accumulators or neither? I replaced the springs with 4 accumulators and my ride is better than it was with the GC coilovers. I have driven in several air equiped vehicles and have never been impresses with any of them as far as ride quality is conserned.
About the belt driven compressor, you can use certain CA units if you are willing to ditch the AC, but I live in the desert so that isn't an option. My S-10 had a 2.5" body drop so the AC had to be ripped out to lay body, but it sucked in the summer since it gets 110+ degrees here.
Old 12-14-2002   #84 (permalink)
FaintReality
Member
I am in the process of re-doing my setup since I switched from reverse flow cylinders to normal cylinders, but I would be more than happy to give those of you who are interested in adjustable suspension and are trying to decide between juice and air, a ride in my car to check it out for yourself once I get it all back in. I am in Southern Cali near LACR.
__________________
Old 12-14-2002   #85 (permalink)
spanky
Super Member
spanky's Avatar
I did accumulators and spings and then just springs and then just accumulators and after all the test i got a good ride better then coil overs with both spring and accumulators. But before i worked for The hack shack i thought that air ride wasnt that good and isnt worth it. But when the owner took me a rid in a car with it on oh my goodness i fell in love. You didnt even feel the speed bumps and when we was on the freeway and everyone knows how LA area freeways (ex: 60,10,710 and so on) This thing handled up to speeds up to 100. Remember the ride hight was at its perfect hight. It will only ride like that when your at your perfect ride hight. If topped off then it it will ride like crap and when you have it too low again it will ride like crap but when you get it perfect then it will ride like a Mercedes benz. But the Hydros they have a better ride then they had before. Back in the days it was like u was on a boat but with the accumulators they ride even better now. The only thing is blowing a hose. I have used so many hoses and they all clame to be good but everyone should know that its good some time but not all the time. I usualy blow my hoses or lock up my hydro cylinders from hitting it too much. Dont get me wrong im not hatting on hydros like i said i like them both but i was just saying there is some ups and downs to both. Why some people that arent really educated on this stuff can do something and break something and make it seem like its the parts fault but remember these parts are all moving parts and need to be maintained its not something that will last forever. So i mean its up to anyone what they want im not going to take sides for me i got a air ride for the shows and now im selling my 2k2 civic to get a H2 and go off roading in it. I tride the rest and now its time to try off road [IMG]i/expressions/laugh2.gif[/IMG] But im also going to get a car maybe i might get a rsx i always wanted one because i love integs and i like messing with the motors and building them up and racing them on the track but i like the new civic si so i dunno yet . The only thing i hate about the new Si is that damn rally shifter it just doesnt feel right to me i like it closer to me and right by my side. But yah it dont matter to me what is the best i like them both and if i was that person that wanted to get either or just make sure u get more educated on both products and see which one is worth it for you.
Old 12-15-2002   #86 (permalink)
spanky
Super Member
spanky's Avatar
Here is the pic that someone wanted to see how low my car is and to see how fast it goes *video is short*
Video
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] MY_CIVIC2.JPG (40 Kb)
Old 12-15-2002   #87 (permalink)
FaintReality
Member
Spanky: So whats on the honda, air or juice? I am not familiar with the hondas but I believe the front suspension is the same as my RSX-S...If so, and you have air cylinders, how did you mount the steering rod to the cylinder? I am guessing you have air struts...Your in LA right? Maybe we can meet up, I would like to check out the car and suspension setup...I am in Lancaster 93534.
As far as the hydros go, my car was as smooth as a catti, in which I didn't like. I am in the process of putting them back on since I switched to normal cylinders and made new upper mounts, but I plan to get the accumulators charged with a higher PSI. Right now I am only running the cylinders and accumulators and the ride just doesn't feel right for a sports car. I think I will get them charged to like 400-500 psi rather than the 300 psi to make the car rougher...I would think springs would make the car bouncy?
__________________
Old 12-15-2002   #88 (permalink)
spanky
Super Member
spanky's Avatar
The civic does have a similar suspension as a rsx and its on air. I dont have air strut bags on my car those things suck and didnt do wat i wanted so i put air cylinders on there and i have it mounted on there with a custom bracket that i made.
Old 12-15-2002   #89 (permalink)
FaintReality
Member
You got any pics of the brackets you made? Did you just weld them to the cylinder?
__________________
Old 12-16-2002   #90 (permalink)
spanky
Super Member
spanky's Avatar
Here is a link to the pic of the brackets sorry about the quality its off a webcam.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] bracket 1.jpg (16 Kb)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
