Will '02 Si Struts work on a '01 EX?
Rep Power: 0 Will '02 Si Struts work on a '01 EX?
Found some on craigslist (Model: S5T (RR) R-AO, NISSIN SHOWA) for a 02 Si.....need some badly for my 01 EX. Will they fit?
http://sfbay.craigslist.org/scz/pts/4604424242.html
Received 1,440 Likes
Rep Power: 338 Re: Will '02 Si Struts work on a '01 EX?
US Si model will require using 16mm crash bolts on the front. You will need drill the knuckles holes to 16 (2001 have 14mm bolts)
Rep Power: 232 Re: Will '02 Si Struts work on a '01 EX?
i think if hes putting 16mm struts on a 01 he will need reducer washers not drilling. if he was using 01 struts on a 02+ there would require drilling ??? K-sport sells reducer washers the last time i checked.or maybe im just confused.
yer right, for some reason i mixed up - yes, reducer washers should work.
Rep Power: 0 Re: Will '02 Si Struts work on a '01 EX?
So the fronts fits with reducer washers ? This means 03 05 civics and RSX and EP3 ?
what about the rear struts?
Read this thread
http://honda-tech.com/showthread.php?t=1715937
Read this thread
ORskier
05-03-2015 12:54 PM
GH04si
04-15-2015 08:13 PM
thesushiboy
04-12-2015 02:54 AM
