Tokico Spring Orentation. Help!
Rep Power: 0 Tokico Spring Orentation. Help!
Im installing a set of Tokico DSpecs matched with a set of Tokico 5907F-P lowering springs.
My questions is, how do you know which way to install the spring? The most obvious thing i can think of it is the words printed on the spring facing up not downward. Is the correct?
Also, I didn't have to use a spring compressor to get the bolt at the top of the shock tightened all the way down. But I can push down on the spring enough to create pace between the strut plate and the strut mount?
Is this supposed to be right because the lowering spring is smaller in size than the factor spring? Or should it be really tight that I cant budge it?
Thanks for the replies.
Rep Power: 0 Re: Tokico Spring Orentation. Help!
Where did you get those springs from? There is how to index your strut post in here somewhere search for it it should show you how to. If these are lowering springs you dont need a spring compressor when installing them you might need it when removing the stock springs.
Prelude Owner
It will tighten up when the car is lowered. They can not be as tight when the suspension is completely in the air.
Make sure they are indexed properly though. Look for the thread that was mentioned above.
Received 1,440 Likes
Rep Power: 338 Re: Tokico Spring Orentation. Help!
Oh, wow, glad to hear it worked well for you
Thanks for coming back to feed back
beanhead
09-24-2015 12:04 PM
TheRiddicles
09-21-2015 01:28 AM
