Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 1 Week Ago   #1 (permalink)
xsaqzw
New Member
xsaqzw is an unknown quantity at this point
Eibach Pro-Kit Springs/Step 1
I ordered the Eibach pro-kit springs a few days ago and got them installed by Midas because I didn't have the right equipment or knowledge or time.. First off these are supposed to be 1" lowering springs but my car doesn't look any lower. He installed them on the stock shocks and struts which to my understanding is part 2 of the Eibach suspension kit, with step 3 being the anti-sway bars. I drive off and immediately notice the alignment is severly off so I instantly go back to Midas. They align the car after having to convince me to pay them $20. I drive off, everything seems good. Seems tighter. I park my car and go to a friends house for a little while and when I come back to my car I turn and notice a "popping" noise. I get out and put my hands on the springs and turn the steering wheel and sure enough the springs are making the noise. I get in and try to drive... My alignment is extremely off. It's too late to go back to Midas now so I will have to go tomorrow... No driving until then.
Does anyone know what the fuck is going on? And do I need to get the shocks and struts to get the full lowering effect? And if so, where can I get them?
Sorry if these sound like noob questions but I'm just getting into modding my car and I'm not sure what else to do. Thanks for the help..
-Nicholas
Edit: Should I just get some Tokio HP shocks instead?
xsaqzw is offline   Reply With Quote
Sponsored Links
Old 1 Week Ago   #2 (permalink)
turbo zombie
New Member
2005 Honda Civic
turbo zombie's Avatar
turbo zombie is an unknown quantity at this point
Re: Eibach Pro-Kit Springs/Step 1
first off, i've never really trusted chain shops. the more i've learned about cars, and the more stories i've heard about chain shops, the less i've trusted them. next time try to go to a reputable independent, or a dealer. they're more expensive, but you get less headaches from them. really anytime you do major work to the front suspension, you'll need an alignment, they should have told you that before even starting the work.
shock absorbers have nothing to do with ride height, unless you lower it so much you hit your bump stops. all they are there for is literally dampeners of the spring speed. hit up the car bibles for more info on shocks. edit: i was wrong on this, shock absorbers don't affect ride height but struts do, and our cars have struts on both ends.
the springs have to be aligned with the spring perches, if you don't do that they won't sit right, and can possibly be the reason it doesn't look lower. it could also be possible that the tech put them in upside down. what year is your car? there is a suspension FAQ stickied at the top of the this forum, post 8 seems to describe your problems exactly.
__________________
Current:
2005 Civic Lx Coupe, auto
Previous:
1985 Volvo 245, 5 speed (avatar)
1984 Ford Festiva, 4 speed
1979 Volvo 242, 2.3 turbo, auto
1986 Volvo 245, 5 speed
turbo zombie is offline   Reply With Quote
Old 1 Week Ago   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
yeah your biggest fail was going to midas. they totally installed your springs wrong, and its not even possible to align a lowered car properly unless you have aftermarket camber kit front and rear. to answer your question, aftermarket shocks like tokicos usually make the car sit higher than oem because they are stiffer and can better function with a lowered car. so if anything, the ride height will go up with new shocks. ofcourse this is only true if your oems were old or leaking to begin with. and i agree with the above comments, they either put the springs backwards, maybe switched rear and front, or did not align them properly. the pop noise means its not installed properly. and a 1 inch drop should be noticable. alot of times its even lower than an inch like 1.2 depending on the car. i would get this fixed immediately.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 1 Week Ago   #4 (permalink)
gearbox
Super Moderator
yeah your biggest fail was going to midas. they totally installed your springs wrong, and its not even possible to align a lowered car properly unless you have aftermarket camber kit front and rear. to answer your question, aftermarket shocks like tokicos usually make the car sit higher than oem because they are stiffer and can better function with a lowered car. so if anything, the ride height will go up with new shocks. ofcourse this is only true if your oems were old or leaking to begin with. and i agree with the above comments, they either put the springs backwards, maybe switched rear and front, or did not align them properly with the indexing marks. the pop noise means its not installed properly. and a 1 inch drop should be noticable. alot of times its even lower than an inch like 1.2 depending on the car. i would get this fixed immediately.
__________________
www.lubecontrol.com
Member 1025782
Old 10 Hours Ago   #5 (permalink)
turboslug
Super Hoser
turboslug will become famous soon enough turboslug will become famous soon enough
just my opinion but tokico blues suck ass....i have a set and they aren't noticeably stiffer than stock. they don't last longer either. from day 1, the nylon seals on the front struts were squeaky. every couple months i have to spray some lube at the seal to shut them up. i also had problems with the rear. one of them started leaking after 1 month. now that corner is sagging. their lifetime warranty is crap too. i tried to warranty my shocks but tokico said i have to do it through the vendor. no vendors want to do it for me so they tell me to go back to tokico.
as for shocks causing increase in height, i think it's due to the pressurized nitrogen gas that pushes upwards. the car will sag when the shocks leak because the nitrogen is gone.
turboslug is offline   Reply With Quote
Old 9 Hours Ago   #6 (permalink)
Mr_Plenty
Super Member
Mr_Plenty's Avatar
Mr_Plenty has a spectacular aura about Mr_Plenty has a spectacular aura about Mr_Plenty has a spectacular aura about
^^^no tokico blues doesnt suck.
OP...most likely the spring isnt seat properly in the perches. Also you fail because you could have looked at the diy on this site and gotten in done yourself over the weekend...good luck
__________________
2002 NHBP HONDA CIVIC EX
Never Complete......
TO DO LIST:
-Strut King Pedals
Mr_Plenty is offline   Reply With Quote
Old 9 Hours Ago   #7 (permalink)
gearbox
Super Moderator
my tokico blues were ALOT stiffer than oem, my ride is so firm its crazy. and i drive over hellish roads where the car is non stop moving up and down. i even completely loaded up the car with hundreds of pounds to the point where the tires were tucked for 2000 miles as i drove home. after that and almost 3 yrs later, the shocks are still in perfect working condition and the ride height is even front to back same as when they were installed. i actually bought these used, so they have a total of about 3 yrs of hard abusive driving on rough road and sharp cornering. maybe you just got a bad set.
__________________
www.lubecontrol.com
Member 1025782
Tags
7th , camber , car , civic , eibach , front , gen , higher , honda , kit , kits , make , pro , shocks , sit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
