Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-08-2009   #16 (permalink)
metalviper
Diamond Member
metalviper's Avatar
metalviper is just really nice metalviper is just really nice metalviper is just really nice metalviper is just really nice
Send a message via AIM to metalviper
Re: pros, cons, and opinions please
Quote:
Originally Posted by sl33pyriceboi View Post
you "should" get a alignment every time you raise or lower the car.
but given that ur toe is set to zero.
a -1 to +1 degree will not effect ur tire wear. tat was the point i was trying to make. especilly if you are only gonna be raised a few months. then you'll drop back down.
im kinda confused about what your trying to say there...
__________________
"It's not hard, it's just not easy"
!!!!7thGen!!!!
Koni/GC 6.6kg Front 9.2kg Rear, Ksport camber/caster plates, Megan rear Camber Kit, eBay Fogs, DIY Blacked out headlights, JVC KDAR-480 HU, DIY Red LED Dash Lights, DC5 sidemarkers, magnaflow exhaust, EP3 Seats, Skunk2 Rear LCAs, progress rear bar....more to come
BUY STUFF! http://www.civicforums.com/forums/19...her-stuff.html
metalviper is offline   Reply With Quote
Sponsored Links
Old 01-09-2009   #17 (permalink)
Curiouz_G
Ultimate Member
Curiouz_G's Avatar
Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice
Quote:
Originally Posted by EnvyX View Post
Koni/GC setup uses sleeves - and its probably one of the best units out there with regard to price. It costs about $1000, but handles with setups a lot more expensive. In fact, I have it, and love it. It rides better than stock yet handles so much better. I can also get it to sit 4 inches off the ground if I want.
had em and now on Tein SS-P's. Prefer the Teins and so does some other members of the forum. The Teins ride soooo much better for a DD. As for handling, until winters over and i slap my RS-2's back on, I cant tell you how much they differ from each other.
__________________
[http://www.maroxxx.com/S2000/s2000textsmall.jpg
The pleasure of a dream is that it is a fantasy. If it happens then it was never a dream to begin with.
Curiouz_G is offline   Reply With Quote
Old 01-09-2009   #18 (permalink)
WannaBFast
Prowlin' with a Purpose
WannaBFast's Avatar
WannaBFast will become famous soon enough WannaBFast will become famous soon enough
Send a message via AIM to WannaBFast
what do u call eibach ground control? is that cheapie? they cost more than ur springs.
agree. +1 for you. i have them myself and they perform ridiculously just as well as the 1500+ ones.
woah there hold on, i never said anything about brands...
and im not disputing that the koni/gc setup is bad either, im just saying that IF one were to get a coilover sleeve kit, they should probablly get the dampers as well.. as the stock shocks wont even come close to cutting the mustard for the springrate that they usually come with
__________________
01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
WannaBFast is offline   Reply With Quote
Old 01-09-2009   #19 (permalink)
WannaBFast
WannaBFast's Avatar
yes and no.
when you first drop ur car, drop it to a heigh that you like. (as for me i am pretty slammed, i have almost no finger gap between fender/wheel)
after u get the height you like (most ppl have like a two finger gap or so) THEN get an alignment.
toe = zero degrees
camber = -1 degree.
why -1? becaues if you need to raise ur car up, you can raise it up to 2-3 inches w/o really affecting ur tire wear....(or getting another alignment to correct the camber)
plus, running -1 camber gives you better handling than 0 degreees.
hmm front toe i agree with you, but the stock factory toe for the rear is .16 degrees of total toe, thats .08 each side.. whoever sets this to zero on the rear is setting it incorrectly...
__________________
Old 01-12-2009   #20 (permalink)
metalviper
Diamond Member
metalviper's Avatar
are you guys still running stock specs??
__________________
!!!!7thGen!!!!
Old 01-12-2009   #21 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all DeX is a name known to all
I had the same debate when I was lowering, here's what I did.
I decided to go with springs and only springs because they're cheaper and give close to the same result. It's not the same ride comfort and I don't have the flexibility of adjusting the suspension 11 different ways but I wondered if I would even do that. Would I ever get under my car just to change the damper or raise it .25 inches? Not likely. And my stock (yes, stock) struts are still going strong after 2 winters in Calgary, a summer in Atlanta and a winter in New York. The springs I chose were Tein S-Tech for $200 and installed them myself, the front and back have close to the same gap after settling and it handles great. And with the 18s it looks awesome.
So unless you got $1000 to spare (I don't) then I vote for springs and just springs.
__________________
7th Generation Member Against Street Racing Number 43
www.em2ab.com
Fully integrated carputer with W-Fi, GPS, 2000 songs/music videos, and weather
7 inch Xenarc 700TSV VGA in dash touchscreen
Compustar 2 way paging alarm/starter system
35% tint excluding windshield
D.I.Y. Blacked Out Headlights
D.I.Y. Debadge
D.I.Y. Remote Trunk Release
D.I.Y. Trunk Air Shocks (Scouting Parts)
Air Ride Suspension Setup (Awaiting Parts)
DeX is offline   Reply With Quote
Old 01-12-2009   #22 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
aaaaaaaahahahah too much to read... this is wt happens when i dont go on for almost a week
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 01-12-2009   #23 (permalink)
DeX
Canadian, Eh!
DeX's Avatar
Some more for you to read. When you get your suspension on, install a camber kit as well, it is required if you don't want to buy new tires in 6 weeks. And when you take it to a shop to get an alignment done (also required for said purposes), have them adjust the camber kit as well. This made all my rubbing issues go away.
__________________
www.em2ab.com
D.I.Y. Debadge
Old 01-12-2009   #24 (permalink)
THECHRIS
New Member
THECHRIS's Avatar
THECHRIS is an unknown quantity at this point
this is exacly what i wanted. input from people on both sides. but i think i still have some more look around.
thanks boys.
THECHRIS is offline   Reply With Quote
Tags
civic , cons , honda , pros
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
