Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Reload this Page
Front and Rear Strut Bars
Suspension Performance Post Suspension related modification information and/or questions here.
LinkBack Thread Tools
Old 10-24-2008   #1 (permalink)
mule69
New Member
mule69 is an unknown quantity at this point
Hey I am new here. I searched around a good bit but couldnt find exactly what I was looking for. I have an 02 Civic Ex coupe with manual tranny and I want to put both an upper front and an upper rear strut tower brace on my car. I also plan on putting a new intake in the future. My questions are ...
1. Which brands will fit the front without having to move anything around(I read something about the cluch fluid reservoir) and will fit with an aftermarket intake.
2. How difficult will it be to install both of these. I imagine the front one would be pretty easy, but the rear seems like it could be more difficult.
3. Do you have any links which have pictures that might help me with the installation.
My hope is that I will just be able to bolt both of them on one afternoon and be done with it and then down the road I could throw the intake on it. All I have done so far is put some 17x7s on it and I just want to get rid of all the body roll anytime i take a turn over 5mph. Thanks.
Mule
mule69 is online now   Reply With Quote
Old 10-25-2008   #2 (permalink)
manahoonie
manahoonie's Avatar
manahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questionedmanahoonie should not be questioned
Re: Front and Rear Strut Bars
Mule
...w...e...l...l...my first thoughs when reading this:
you just sound like you're saying you searched when in reality, you probably didn't
i am trying to be nice here, so if you cannot find pictures of either of these on a car yourself, then you probably shouldn't be putting them on...
i just have to ask, but HOW did you search?
to answer all your questions in two words...
Neuspeed
DCSports
manahoonie is online now   Reply With Quote
Old 10-25-2008   #3 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
neuspeed front upper strut is best, rear upper is useless.
gearbox is offline   Reply With Quote
Old 10-25-2008   #4 (permalink)
manahoonie
manahoonie's Avatar
eh, i felt a difference when i put mine on...that's with everything stock...and with the Neuspeed front upper and lower on.... front just seemed to stay planted while the rear bounced some... but i guess it depends on where you live and all. PLUS, my rear upper actually goes to the tops of the shocks in the trunk, where some (like the Neuspeed for EP/DC goes to frame supports...in the trunk pass-through
wel, from seeing other posts similar to this over the years, i and his name not car oriented or self oriented, i kind of believe we won't be seeing any more posts from this user. just thinking realistically
Old 10-25-2008   #5 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to beholdsl33pyriceboi is a splendid one to behold
front sway bar makes a big difference in handling...
however, you must get one that is a single-piece design...such as a neuspeed...
as for the rear, a strut bar makes a difference, but minimal. a progress (or anything like that) makes a BIG difference as well...
sl33pyriceboi is offline   Reply With Quote
Old 10-25-2008   #6 (permalink)
mrbanhbao
Senior Member
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
im lost on these things. so a upper front strut goes under the hood and the rear upper goes in the trunk and the lower tie bar goes below in the rear right? kus i like how it looks on ek and stuff and how it handles.
mrbanhbao is online now   Reply With Quote
Old 10-25-2008   #7 (permalink)
mule69
New Member
asdf
Old 10-25-2008   #8 (permalink)
baron340
Member
baron340's Avatar
baron340 has a spectacular aura aboutbaron340 has a spectacular aura aboutbaron340 has a spectacular aura about
ok.. here we go.. 1st this topic has been covered dozens of times... but anywho. as already stated, neuspeed and dc sports are the best out there. i'm pretty sure you have to move your clutch fluid resevoir with any of them. its just a matter of taking one bolt out moving the thing down and bolting it back in. yes you can install both of these in one afternoon, if you know what you're doing less than an hour. you need a 10 mm socket, an extension, and a 14 mm deep socket. all that being said, these things dont really do much by themselves. if you are really tired of body roll, save up and buy a set of struts and springs or coilovers. it wont make the car faster, but it will make it a ton more fun to drive.
baron340 is offline   Reply With Quote
Old 10-26-2008   #9 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
both don't do shit.
robbclark1 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
