Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Reload this Page
Tokico Blue V.S. KYB GR-2 Question???
Suspension Performance Post Suspension related modification information and/or questions here.
LinkBack Thread Tools
Old 09-14-2008   #1 (permalink)
NuShine_Drifter
Member
NuShine_Drifter is an unknown quantity at this point
Whats the best brand??? I have neuspeed springs and wondering what wil give me the best ride quality?? Thanks...
NuShine_Drifter is offline   Reply With Quote
Old 09-15-2008   #2 (permalink)
speedricerx
Diamond Member
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
Re: Tokico Blue V.S. KYB GR-2 Question???
stock...
blues stiffer than the kybs
use search button
speedricerx is offline   Reply With Quote
Old 09-15-2008   #3 (permalink)
mrtrinh
Super Member
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
yes search please. this has been covered numerous times. both are basically the same thing. oem replacements and can only handle a maximum drop of 1.7". i had tokico blues with megan springs for 3 years and no problems so my answer is tokico
mrtrinh is offline   Reply With Quote
Old 09-15-2008   #4 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
You can't run those springs on either of those shocks. Koni /thread.
robbclark1 is offline   Reply With Quote
Old 09-15-2008   #5 (permalink)
ryox82
Super Member
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Koni, or bilstien if you are a baller lol.
ryox82 is offline   Reply With Quote
Old 09-15-2008   #6 (permalink)
Kevbotron
I like my commute
Kevbotron's Avatar
^yup... Tokico's seem to blow on drops over 1.5"-1.7" .. get Bilstein or Koni Yellows.
I've had Tokicos on my prokit springs for 2 years n' still going strong
Kevbotron is offline   Reply With Quote
Old 09-15-2008   #7 (permalink)
rjngo
Super Member
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
not if you get the d-specs or HTS 508...these can handle a lower drop than the blues
rjngo is offline   Reply With Quote
Old 09-15-2008   #8 (permalink)
Kevbotron
I like my commute
Kevbotron's Avatar
Oyeah I forgot about the D-specs (whites) .. never heard of the the HTS 508's and ya I meant the Tokico blues hehh
Old 09-15-2008   #9 (permalink)
colourwolf
Senior Member
colourwolf's Avatar
colourwolf will become famous soon enough
depends on what springs do u have, if u have neuspeed sport which was rated 1.5"F 1.75"R, dropped less than 2" arround after settled . you should be fine with either one.
If you have neuspeed race(2.5" drop )......either sell the springs or get some better shocks..lol
colourwolf is offline   Reply With Quote
Old 09-15-2008   #10 (permalink)
ryox82
Super Member
ryox82's Avatar
From the day I got my pro kit/blues setup my car has just felt mad unstable on rough long island roads...the wheel is always being yanked around when I am on shitty roads. I have Koni's sitting in a box that I am going to be putting in once I cut the OE strut housing....just been lazy.
Old 09-15-2008   #11 (permalink)
Kevbotron
I like my commute
Kevbotron's Avatar
^yahhh I've noticed that too.. I wonder if it would make much of a difference changing the dampers. I go so slow on my folks bad roads that I will never lose control anyways lol
Old 09-15-2008   #12 (permalink)
ryox82
Super Member
ryox82's Avatar
lol i know what you mean. The dampener has the most affect on ride quality in my opinion. I will let you know once I put the konis in how I feel about it. I hope that fixes the issue cause it makes me hate driving sometimes.
The bilstiens are supposedly the jesus strut/shock....but you pay 500 plus a side on the front, and like 300 dollars per rear....I have only heard great things about it though
Old 09-15-2008   #13 (permalink)
robbclark1
robbclark1's Avatar
Ohlins and Bilstein make some good shit if you can get them.
Ryo, Konis may not solve your problem. What size rims/tires are you on and are the tires good or overinflated? I've been in a car with tokicos and they are softer than konis.
Old 09-15-2008   #14 (permalink)
ryox82
Super Member
ryox82's Avatar
proper inflation, 17 inch rims..sidewall is kinda beefy but i dont remember what size the proxies are. Even with stocks it felt like that though to be honest...also seemed like it lost alignment too easily...I have to get alignments like crazy. I also dont mind stiff but there seems to be too much bounce as well when rebounding. Nobody has been able to figure it out.
I was thinking about replacing the tie rod ends if that would help keep the toe correct in the front. The dont really look worn though to be honest....
Old 09-15-2008   #15 (permalink)
ryox82
Super Member
ryox82's Avatar
now that I think about it, I got a flat in the rear passenger and it was never right after that, even after switching to the 17 inch wheels and the struts , lower control arms look fine and I had replaced the upper control arms with a camber kit so I dont know what that would have to do with anything. If I knew someone here on the island that knew 7th gen suspension I would ask for help in getting it set up the way I want it but that isn't the case unfortunately. Also the rear pass and driver side dont feel like they rebound the same. Maybe something is blown...who knows. Anyways, im not gonna thread jack...after I install the knoni's if it still doesnt feel right I'll put up a thread with as much detail as possible on how its acting and let people throw their two cents in.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
