Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Reload this Page
Squeeking noise in rear strut
Suspension Performance Post Suspension related modification information and/or questions here.
LinkBack Thread Tools
Old 08-16-2008   #1 (permalink)
Honda05
Super Member
Honda05 has a spectacular aura aboutHonda05 has a spectacular aura aboutHonda05 has a spectacular aura about
My car just now started making this weird squeaking noise in the rear left strut.. Not sure what is causing it.. Any ideas?
Honda05 is offline   Reply With Quote
Sponsored Links
Old 08-16-2008   #2 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
Re: Squeeking noise in rear strut
try spraying penetrating oil on ur camber kit, hte inner bushing, see if it dissipates, if it does, its typical, bushings squeak on camber kits regularly, drives me nuts
greeen01civic4d is offline   Reply With Quote
Old 08-16-2008   #3 (permalink)
Honda05
Super Member
ok cool.. ill try that
Old 08-16-2008   #4 (permalink)
greeen01civic4d
balls in ur mouth
its what caused mine, been through 3 camber kits, im too particular
Old 08-16-2008   #5 (permalink)
Honda05
Super Member
well that didnt work.. i sprayed zep 45 on the camber bushing and around the sway bar endlinks.. This is the first time its done it since ive had the cambers and ive had the same ones for alittle over 2 years
Old 08-16-2008   #6 (permalink)
kcari
Diamond Member
kcari's Avatar
kcari is just really nicekcari is just really nicekcari is just really nicekcari is just really nice
could it just be your shocks being worn?
my coilovers makes a little noise whenever I go slowly over speed bumps.
Tein says this is normal.
kcari is offline   Reply With Quote
Old 08-16-2008   #7 (permalink)
Honda05
Super Member
does it sound like creeking noise kinda
Old 08-16-2008   #8 (permalink)
kcari
Diamond Member
kcari's Avatar
yes creeking - i know for a fact its my coilovers/shock because i just recently put my OEM ones back and they made a bunch of noise and my newly overhauled coilover shocks are a lot more quiet
Old 08-16-2008   #9 (permalink)
Honda05
Super Member
do you know how i would go about fixing it?
Old 08-16-2008   #10 (permalink)
Honda05
Super Member
i had someone else tell me i could have a bad bushing somewhere to
Old 08-16-2008   #11 (permalink)
greeen01civic4d
balls in ur mouth
there was a tsb about this too, i have it somewhere, its a bad bushing in the lower control arm
Old 08-16-2008   #12 (permalink)
kcari
Diamond Member
kcari's Avatar
well i dont think my noise is in the lower control arms because i get the same noise in the front whenever i go over speed bumps. I forgot to mentionthat sometimes when I spray a little white grease onto my coilovers it stops making that noise. It could just be the springs rubbing against the shocks somehow - but this could not be your problem...
Old 08-17-2008   #13 (permalink)
i5r
Senior Member
i5r's Avatar
i5r is an unknown quantity at this point
i would try spraying down everything hahaha it worked for me
i5r is offline   Reply With Quote
Old 08-17-2008   #14 (permalink)
Honda05
Super Member
i tried that.. Didnt work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
