Re: Dropping the ride... Hey guys, good to be part of this forum!
so i have a 02 civic coupe. when i bought the car, the guy had dropped it a lot and left the stock shocks. the ride was terrible and the shocks bottomed out and hit the stops on a daily basis.
so i decided to take care of the problem and i got a full kit of tokico shocks and springs. it was a pain to install but i got it all installed and it looks and works great! I also needed tires so instead of getting new tires for my hub caps, i was able to get a great set of 17's with tires for almost the same price.
my wheels are 215/45/ZR17. i did the math and these new tires are a tad taller than my old 185/65/R15. but they are quite a big wider too, which might be the main problem.
the only problem is that on right turns and in heavy bumps, my left rear tire is contacting my fender! the left side might even be riding a little lower.
what do you guys suspect the problem is? also, can you guys explain "settling" will the springs ride EVEN lower once it settles? which would be big trouble for me. i was told to wait like a month and then get an alignment.... would an alignment help this issue?
i took pliars and bent the inner lip of the fender upward a bit, and its gotten better but still does bottom out. i dont want to wear out and damage my brand new tires.
any help would be awesome! thanks! |
