Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Reload this Page
air ride camber question
Suspension Performance Post Suspension related modification information and/or questions here.
LinkBack Thread Tools
Old 07-23-2008   #1 (permalink)
Veracious
Reflector Collector
Veracious's Avatar
Veracious is an unknown quantity at this point
i got a question for all the guys who got air ride... i got air ride installed n my car is just about finished n rdy to be on the road.. now i know my tires wont last no where near as long as b4..but is there anything i can do to help my tread life with air bag suspension installed...is it even worth getting a rear camber kit and installing it.. then gettin the rear wheels adjusted at like ?? PSI so it is straight and then just know that your wheels are start at that same psi to reduce treat wear or what? sorry if its a dumb question but im curious as what to do since i got some major camber issues lol
Veracious is offline   Reply With Quote
Sponsored Links
Old 07-23-2008   #2 (permalink)
jee88
New Member
jee88's Avatar
jee88 is an unknown quantity at this point
Re: air ride camber question
i dont have airride but if i did thats what i would do, sounds smart to me
jee88 is offline   Reply With Quote
Old 07-23-2008   #3 (permalink)
filipinop1405
Diamond Member
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
what you can do is get rid of air ride...lol ok got the jokes out...lol. i would say do the psi thing but pretty much don't drive a whole lot slammed but drive with your car raised some... if you understand what i'm trying to say...
oh and i don't have air ride if you're wondering....
filipinop1405 is offline   Reply With Quote
Old 07-23-2008   #4 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
I think a rear camber kit will help and you can eyeball it. However, the bushings in the camber kit probably aren't made for air ride's constant changing. Additionally, it isn't the rear that you have to worry about it, it's the front. Changing the front's height drastically changes toe, which then will eat tires. You can try to rotate them every 3k miles or so to help. But you chose a suspension that is prone to tire wear so you will have to live with consequences.
robbclark1 is offline   Reply With Quote
Old 07-23-2008   #5 (permalink)
2k3civicgyrl
Member
2k3civicgyrl's Avatar
2k3civicgyrl is an unknown quantity at this point
maybe try these tires...
http://www.nittotire.com/#index%2Etire%2Einvo
they are supposed to help with reducing camberware...i dont have air ride...yet lol but my bf does, he was going through tires every 3 months, untill he got these and he has had them for a yr and no issues with them. if you drive your car at a stock ride hight you wouldn't have any problems with camber. since your changing the height of the car with bags at a flick of a swith a camber kit will only help you at certain heights, it wont help all the time therefore it is a waste of money so just don't drive layd out all the time.
2k3civicgyrl is offline   Reply With Quote
Old 07-23-2008   #6 (permalink)
xschizx9
Senior Member
xschizx9 will become famous soon enough
what you do if you have gauges, is once you get it at a comfortable PSI and ride height, eyeball the alignment best you can, then you can go get an alignment, just make sure you tell the mechanic not to adjust your ride height, and you should get close to factory settings.
and when you raise and lower just make sure you check your gauges to see what PSI each corner is at and you will have pretty even wear on your tires.
xschizx9 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
