Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Reload this Page
control arms
Suspension Performance Post Suspension related modification information and/or questions here.
LinkBack Thread Tools
Old 07-19-2008   #16 (permalink)
keepItJDM
New Member
keepItJDM's Avatar
keepItJDM is an unknown quantity at this point
Re: control arms
just replace the bushings
keepItJDM is offline   Reply With Quote
Old 07-19-2008   #17 (permalink)
Mr_Plenty
Super Member
Mr_Plenty's Avatar
Mr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura aboutMr_Plenty has a spectacular aura about
Re: control arms
could be ball joints, compliance bushings, could be the strut install did they line it up with the paint marks or the arrows? etc. You should do a visual and physical inspection on those.
Mr_Plenty is offline   Reply With Quote
Old 07-19-2008   #18 (permalink)
alscrx
Member
alscrx is an unknown quantity at this point
Re: control arms
Is it a more of a rattle or metal on metal sound?? If so that a compliance bushing for sure.
Check your sway bar end links with an allen key and wrench to see if they need to be tightened. Thats makes a pop noise also. Learn from me,lol.
alscrx is offline   Reply With Quote
Old 07-21-2008   #19 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
Re: control arms
way off topic what if my half shaft moves left and right by about two inches?
02BLKCIVIC is offline   Reply With Quote
Old 07-21-2008   #20 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Re: control arms
I'd say you had a k series in there, you dont have a half shaft.
Triz, If you pulled the hub out of the bearings you should have taken the knuckle off and pressed the hub back in with a good hydraulic press to be sure it seated good. It you didnt get it all the way back in there I'm pretty sure the axle nut can come lose when the hub starts to seat or move around, you can side load the wheel bearing as well. The CV joints are usually good for some popping sounds during turns. You could have a very dangerous situation if you keep driving the car without knowing whats wrong. Also if its a ball joint and it breaks, that will ruin your day too, hehe. Front ends in FWD cars do 80% of the car's functions. The back wheels are basically like training wheels, if something in the front lets go its going to be an interesting ride. On the plus side it will be a sure tale of where that pesky noise is coming from.
02fpcivic is offline   Reply With Quote
Old 07-21-2008   #21 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to beholdrobbclark1 is a splendid one to behold
Re: control arms
Ball joint = loose wheel and creaking when turning
Compliance bushing = creaking with lateral and horizontal movements, cracks in the bushing
CV joint = ticking while moving, grease all over the place
Spring = popping when turning
Shock = popping/clanging with horizontal moment, oil leaking from shock
robbclark1 is online now   Reply With Quote
Old 08-06-2008   #22 (permalink)
bartsavage
New Member
bartsavage's Avatar
bartsavage is an unknown quantity at this point
Re: control arms
i had the same loud banging problems too.....i replaced the lower control arm bushings......the front ones were broke and the back were ok but i replaced anyway...
bartsavage is offline   Reply With Quote
Old 08-06-2008   #23 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: control arms
i have loud creaking when turning but i think its bushings not ball joint.
gearbox is online now   Reply With Quote
Old 08-07-2008   #24 (permalink)
robbclark1
robbclark1's Avatar
Re: control arms
Quote:
If you have creaking while turning and not moving, how could it be the bushings? Bushings don't move.
Bushings squeek, they don't creak. Creaking means that metal is hitting metal, like when door hinge needs oiling. Bushings make a sound like rubber is rubbing on metal. If it is creaking, especially when not moving, then it is your ball joints.
Old 09-02-2008   #25 (permalink)
ksoazn
New Member
ksoazn is an unknown quantity at this point
Re: control arms
my car have like metal rattle sound when taking slow turn
but none at high speed
ball joint ?
ksoazn is offline   Reply With Quote
Old 09-03-2008   #26 (permalink)
skoot
Senior Member
skoot is an unknown quantity at this point
Re: control arms
How much would ball joints cost to replace?
skoot is offline   Reply With Quote
Old 09-03-2008   #27 (permalink)
bomerman19
Senior Member
bomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to allbomerman19 is a name known to all
Re: control arms
rob you forgot endlink's if your endlinks are not as tight as the can be the sway bar will pop and make a banging noise.
as for replacing the hub honda makes the wheel bearing really tight and it almost always comes apart and if you don't replace that bearing it usually goes bad in about three months slide hammers suck for changing wheel studs do what gerry said use a press.
Oh and Rob where's my ball joint separator?
bomerman19 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
