Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-31-2008   #1 (permalink)
chocopinoy
New Member
chocopinoy is an unknown quantity at this point
Megan Coilover height adjustment Help
Hey. i got me a set of megan coilovers and im kinda of confuse on adjusting the height...ok. the coilover has a top ring, a ring 1, and a bottom ring (ring 2). Ive read rsx forums on megan coilovers..adjusting the height while installed.... saying just loosen ring 2 (bottom ring) while the top ring and ring 1 are together. Then take your spanner wrench and turn the top ring clockwise. Is this correct? Or do I have to loosen any other rings? Also anyone have these coilovers remember their adjustments for a 1 finger gap all around?.. what were your Measurements between ring 1 and ring 2.... Im running on 205/40/17. Ive tried searching the forums but found no solid answer to my question. Thanks To remove this ad, register today for free or log in if already registered!
chocopinoy is offline   Reply With Quote
Sponsored Links
Old 04-04-2008   #2 (permalink)
john_817
Member
john_817's Avatar
john_817 is an unknown quantity at this point
Send a message via AIM to john_817
Re: Megan Coilover height adjustment Help
to loosen u just take the top 2 red rings and turn the bottom clockwise and the top one counter-clockwise
john_817 is offline   Reply With Quote
Old 04-04-2008   #3 (permalink)
metalviper
Diamond Member
metalviper's Avatar
metalviper is just really nice metalviper is just really nice metalviper is just really nice metalviper is just really nice
Send a message via AIM to metalviper
your two top springs are for the spring preload. they should be together. the bottom most nut is for the actual height adjustment. if you can't find the preload and height adjustment specs, email Megan racing. Just look at the pic. its pretty self explanatory, the closer the bottom nut is to the middle nut the lower the drop. the further the bottom and middle, the more ride height you'll have
__________________
"It's not hard, it's just not easy"
!!!!7thGen!!!!
Koni/GC 6.6kg Front 9.2kg Rear, Ksport camber/caster plates, Megan rear Camber Kit, eBay Fogs, DIY Blacked out headlights, JVC KDAR-480 HU, DIY Red LED Dash Lights, DC5 sidemarkers, magnaflow exhaust, EP3 Seats, Skunk2 Rear LCAs, progress rear bar....more to come
BUY STUFF! http://www.civicforums.com/forums/19...her-stuff.html
metalviper is offline   Reply With Quote
Old 04-04-2008   #4 (permalink)
Valdeezy
Super Member
Valdeezy's Avatar
Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all Valdeezy is a name known to all
Send a message via MSN to Valdeezy Send a message via Yahoo to Valdeezy
The numbers on the springs are the measurements for the spring load. The bottom ring will adjust the ride height.
__________________
"N/A EM2 Crew
Don’t jump on the turbo bandwagon!!! Go Naturally Aspirated Baby!!!
Come joins us at
http://www.7thgenhonda.com
You will learn more and there isn't so many noob douchebags associated with it!!!!
Valdeezy is offline   Reply With Quote
Old 04-04-2008   #5 (permalink)
ONE7thREBUILT
Senior Member
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura about ONE7thREBUILT has a spectacular aura about
You can't adjust ride height using the spring. For the front you need to disconect the tie rod ends and the lower strut mount losen the lowest ring and spin the gray portion around until you get the height where you want it. On the back you need to disconect the lower strut mount bolt and spin the gray part again to get the height where you want it. One warning though the front is able to lower your car much more than the back on this set.
ONE7thREBUILT is offline   Reply With Quote
Tags
97 , adjust , adjusting , adjustment , adjustments , civic , coil , coilover , coilovers , dx , height , megan , racing , rsx , set
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
