Monroe Shocks and Strutts?
Old 03-12-2008
carter's Avatar
carter is an unknown quantity at this point
I want a softer ride and im at about 115 000KM I was thinking of changing the shocks and struts would that be a good investment?
Would they be better for a softer ride because Im putting on 18" Enkies FN18s. Im tierd of feeling all the bumps and stuff in the road and I saw the display at Canadian Tire and as it shows the Shocks seem to be alot softer than stock.
Just wondering if anyone knows much about them?
Old 03-12-2008
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Re: Monroe Shocks and Strutts?
18's doesn't make it any better for a softer ride because you have to go a more low pro tire... if you want to lower expect it to be a little rough... i would try going with just blues/s.techs. that set up is pretty soft compared to other springs/struts
Old 03-13-2008
carter's Avatar
Well how much softer is the Monroe setup compared to "blue/ Stech" and can thoes come in adjustable set where i can lower it and raise up higher then normal for the winter time just a 1.5" drop and about a 1.5" high?
Im looking for a softer ride nothing sporty.. That 1.5" drop is at MAX I would probably go down about a 1/2" at most.
I just need some advice on getting a softer setup.
Thanks so far tho ^^ +1
Old 03-13-2008
rev125yz's Avatar
rev125yz is an unknown quantity at this point
what he means by "blues" are tokico blues, preferably with stock springs, is a better ride than with the stock struts/shocks. but like he said, 18's will not help the situation much. but the blues would be the cheaper route than a coilover setup.
Old 03-13-2008
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
Want a softer ride? Ditch the 18's, you'll have a tough time getting a soft ride on those.
Old 03-13-2008
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Monroe is Oriellys/Autozone junk........only put that on your beaters..........You're softest ride is gonna be stock suspension & stock wheels............You will never ever get a nice ride outta them
Old 03-13-2008
Murderjetz's Avatar
Murderjetz is an unknown quantity at this point
yeah dude...18's = **** ride. 17's are a good enough size without sacrificing much of the ride quality, I'd say.
Old 03-13-2008
carter's Avatar
Well, I dont have a problem with how it rides now.. I just know it will get a bit ruffer with the 18s.. So I was trying to find a balance and find out what setup could help equal the situation out.
tokico blues and the s-techs?
So dont change the stock springs there what you keep for the best ride quality? Struts/Shocks are what you can upgrade?
Old 03-13-2008
carter's Avatar
I found this site http://www.prostreetonline.com/s/sus...ico-shocks.asp
which of these better suit my needs? I dont care much for a drop, Im more worried about ride quality I know 18s wont help but I wnat somthing that might just a bit .. More so i dont want to damage the rims.
Old 03-13-2008
Diamond Member
Envy's Avatar
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
dude. im sorry. search a little. you always create useless threads that have been covered a million times before. And you always ask about shitty parts. The magnaflow and enkeis being the exception. dont skimp on your ride. or youll pay mroe in the long run, possibly your life with egay coilovers ridin on a dubs with a autozone special shock while blinding oncoming drivers with your glare-ific HID kit and getting called a ricer for your dual exhaust on a 4cyl civic. Just mix a bunch of tried and true paths for mod-wise.
You Gotta Pay to Play.
Old 03-14-2008
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
18s and soft ride??? honestly, why ask...then again you bought a civic...
Old 03-14-2008
Murderjetz's Avatar
Originally Posted by Envy
...getting called a ricer for your dual exhaust on a 4cyl civic.
Is it not possible to get split 2-1 headers rather than a single 4-2-1 header and get true dual exhaust? I wouldn't call that ricey at all...fake dual exhaust is ****ing gay though.
I know I've found some headers like that for Integras before. Sorry if that's a dumb question, I don't know much about Civics.
Old 03-14-2008
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
tokico blues would be stiffer than stock. if u want a softer ride, get bags. if not, the softest ride would be stock.
Old 03-14-2008
carter's Avatar
Thanks speedricerx I tought Bags would be best but thoes are big bang in the bank.
I gota pay to play... well, ive learned to play with what ever little ive got and do it pretty well but thanks for the heads up.
Oh the HID arent that bad Maybe in a few years when im 20 and i can afford to spend my lunch money on head lights ill do that :>
Old 03-15-2008
sl33pyriceboi's Avatar
actually, Htech springs are softer than stock springs.they are made out of a material called Vanadium and far exceeds our civic oem springs.
Old 03-17-2008
carter's Avatar
okay so Htech Springs with Bags?
Now when I look for bags what are the negatives to changing to a air bag suspension set that you guys have come across if any? (oh ill research the answer at the same time).
Old 03-23-2008
Super Hoser
turboslug's Avatar
turboslug will become famous soon enoughturboslug will become famous soon enough
they are not softer than stock...
i have them w/ tokico blues and the combo is waaaay rougher than stock suspension...i guess it's not as rough as full coilovers but the ride isn't soft
skeener51
10-01-2015 05:56 PM
ken4444
09-30-2015 07:37 PM
Bruce2
09-27-2015 08:45 PM
beanhead
09-24-2015 12:04 PM
TheRiddicles
09-21-2015 01:28 AM
Quick Reply: Monroe Shocks and Strutts?
