Suspension PerformancePost Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I think that you could get away with using the EX mounts for the RSX bar, but you definetly need the bushings for the RSX bar, since they are sized to fit the 19mm bar. The EX bushings (15mm) would probably be too small.
sicsol: so to install the rear anti-sway bar from the RSX onto an 01 Civic EX, you just need to jack the car up and unbolt the thing, then bolt the new one in right? i mean, is there any kind of tension on the bar so its hard to install/remove? also, about how much does the RSX's anti-sway bar weigh?
also, how did you know what torque to use when tightening the bolts back up after installing the anti-sway bar?
<< Here are the Acura part numbers for those with an EX:
52300-S6M-A01 Spring, RR. 19 (1 of these)
52306-S6M-A01 Bush 19MM (2 of these)
52308-S6M-000 Holder, R. RR. (1 of these)
52309-S6M-000 Holder, L. RR. (1 of these)
That is all you will need if you have an EX. >>
so the part that they call, "Spring, RR", is the actual sway bar itself? its 60bucks, what does RR mean, usually right rear, but if this is the sway bar why would it say right rear as opposed to just rear.
slikor: Remember to get the torque specifications by doing a little reverse engineering. Set a torque wrench to a certain torque level and try to unbolt the bolt. If if doesn't come off, then up the torque and try again. Eventually you'll be able to unbolt it and you'll know the approximate torque to use when bolting it back on.
bluecoupe: Try www.acuraautomotiveparts.net and all of your questions will be irrelivent.
Only thing holding me back from this mod is as soon as I install it, I'm afraid Neuspeed will release their sway bars that are "in development" at the moment. Wish we knew the specs on the Neuspeed, I don't see how it could be any "better" so to speak. Also, I think it's real cool to have genuine Honda/Acura parts whenever possible. hmmmm decisions, decisions.
usually I am a torque king. I torque everything, but since I didn't have the specs I just tightened them enough to be considered tight (I didn't want to have to break my back to get the thing off if it didn't work). And so far there is no clunking in the rear. As for how i installed it, if you refer to the pics that Grey hosted, there is a pic of how the jack and the stands were set up. With the wheels hanging there is hardly any tension on the bar. It is probably one of the easiest mods I have done so far. Just for comparison, I would say it was much easier than putting on my AEM CAI.
..... ok then, guess we're using different definitions of "spring" here. I suppose that if you think about it, anything that absorbs and re-deflects energy could be called a spring, so I guess that's what it is.... thanks!
