Rear Sway Bar - Honda Civic Forum
Suspension Performance Post Suspension related modification information and/or questions here
LinkBack Thread Tools Search this Thread
Old 02-11-2007   #1
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
Rear Sway Bar
I just installed a Progress rear sway bar on my 02 LX Sedan yesterday. My car is lowered on the Progress drop springs as well. My problem is that the rear end has developed a "bounce" when it go over bumps. For each bump I hit the rear end bounces about 2-3 times. Besides this my car isn't nearly as low in the rear as it had been. Is there a way to put the sway bar on upside down? Any other reasons why a sway bar would affect ride height? Any suggestions or input would be greatly appreciated!
PitchBlack is offline   Reply With Quote
Old 02-11-2007   #2
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
You can put the sway bar on upside down but it shouldn't affect height. Can you take a picture of it? If it's on wrong it's probably hitting the control arms which might be causing the ride height problem.
MisterFrankieJ is offline   Reply With Quote
Old 11-18-2009   #3
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Re: Rear Sway Bar
What did you have to do to get sway bars to work on your LX? I'm assuming that it didn't come with rear sways from the factory
Mavrick272 is offline   Reply With Quote
Old 11-18-2009   #4
Re: Rear Sway Bar
heres what it should look like installed the right way.
gearbox is offline   Reply With Quote
Old 01-06-2010   #5
White97Bring is an unknown quantity at this point
Re: Rear Sway Bar
To tell you my honest opinion. You need new struts. That will solve your bounce problem and you can forget all about that sway bar. Tip to all who read this dropping your car on old *** struts equals tons of bounce issues on civics.
White97Bring is offline   Reply With Quote
Old 01-07-2010   #6
Autocross Junky
Zzyzx's Avatar
Re: Rear Sway Bar
Quote:
Yup, and a stiffer anti roll bar is just going to make this more apparent...
Zzyzx is offline   Reply With Quote
Old 01-24-2010   #7
R3DL1N3's Avatar
Re: Rear Sway Bar
Right, you need better dampers. You're bouncing around because the stock struts can compensate for the new spring rate. Lowering the car only adds stress to your stock dampers.
R3DL1N3 is offline   Reply With Quote
Thread Thread Starter Honda Civic Forum Replies Last Post
FS: 2001-2005 Civic Part out GotSiR Parts for Sale 8 06-23-2016 04:06 PM
Rotation knocking sound near wheels pizzahutcombo Mechanical Problems/Vehicle Issues and Fix-it Forum 8 10-27-2015 07:37 PM
Inherited 2005 EX Special Edition. Preparing to sell. muniorbust 7th Generation Civic 33 08-31-2015 08:59 PM
Clunk from front suspension Marco83 7th Generation Civic 13 08-11-2015 08:39 PM
Just finished changing my sway bar links (Dear Future Juror) juror Mechanical Problems/Vehicle Issues and Fix-it Forum 1 07-18-2015 10:48 PM
Tags
2000, 2006, 2007, 2008, 95, bar, bars, civic, forum, honda, link, rear, remove, si, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2007 CivicForums.com
