Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 03-01-2005   #1 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
I'm gonna pimp slap the next person who asks if they need a camber kit.
For the love of god, stop asking. I thought 3 times a day was enough, apparently not. I suppose its better to educate yourselves before rather than later, but if you use the search function like you're supposed to, and you do your research before you spend upwards of $800 on a drop done right, then you should figure out in 5 minutes or less that YES YOU NEED A CAMBER KIT. For mild drops (less than 1.25") you probably don't, but you may opt for one just to be safe. I have a friend dropped on Pro-kits, no camber kits, and he's got nearly spec alignment numbers. Any lower, you probably want one if you value your tires. While toe kills tires more than camber does, you can only adjust toe so much (especially in the rear). Toe and Camber settings effect eachother, so you need to have the adjustability to get your toe to 0. In the front, your camber can be as much as -2.25 before your steering rods run out of travel, but -2.25 will probably do something to your tires.
Rear kits are a threaded adjustable length upper control arm. It bolts in with 3 bolts, 2 on the body, one on the back of the drum and you can adjust its length to control the angle of the wheel. This part is critical as the rear is far more prone to camber changes than the front (nature of a multi-link double wishbone). You need it. There's numerous kits available. SPC and Ingalls probably make the most inexpensive and widely used ones, they're $110-140 depending on the store... you can spend plenty more if you want, I've seen them go as high as $400 for JDM brand super adjustable (5 degree) arms, but they're unnecessary for basic adjustment. A normal range (+2/-3 degree) kit will take care of any reasonable drop.
Front kits... well 2 options. Camber or Crash Bolts that are smaller than the stock crash bolts give you additional range of motion by freeing space up in the knuckle hole to set the knuckle more upright. They're $20-30 bucks, but they have plenty of flaws. If you drive hard, they have a tendency to move and not hold their setting. As a result, frequent alignments (every few months) are a necessity. If you're looking at any sort of racing, I don't recommend them unless the rules specify that this is the only way you can change your camber. Honestly, if you can get your camber back to about -1.5 degrees or less without the use of camber bolts and still get 0 toe, I wouldn't even bother with the bolts.
Camber Plates are the better alternative. They replace the upper mount of the strut with a sliding bearing surface and the entire suspension angle changes from the top. This allows the use of stock crash bolts which hold their setting much better, it also provides a better reaction from the corner because the wheel is aligned with the suspension like its supposed to be (scrub radius unchanged). Plates run from about $200 to $400, there's a few available.
I don't think I missed anything.... if you have a question about anything that has been posted here or still do not understand, then post it IN THIS THREAD.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline
Sponsored Links
Old 03-27-2005   #2 (permalink)
goodtimes
Ultimate Member
goodtimes's Avatar
Send a message via AIM to goodtimes
how hard is it to put on a front camber kit on an 03?
__________________
R.I.P
Vinh Tran
You will be missed
1985 - 2005
07 STi
goodtimes is offline
Old 03-27-2005   #3 (permalink)
Boilermaker1
Jap-Euro Fusion
Take the top crash bolt out, put the camber bolt in, take it to the alignment shop.
Old 03-27-2005   #4 (permalink)
goodtimes
Ultimate Member
goodtimes's Avatar
? were is the crash bolt
thanks
__________________
R.I.P
Vinh Tran
You will be missed
1985 - 2005
07 STi
Old 03-27-2005   #5 (permalink)
Boilermaker1
Jap-Euro Fusion
Bottom of the strut
Old 03-28-2005   #6 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
When you lower your car, how does this affect the camber and toe on the front wheels?(Lets say you haven't installed camber bolts or plates)
I've read a few times that their is a degree of camber that wont' eat your tires? Is that true?
nindoo is offline
Old 03-28-2005   #7 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Front camber will go more negative but only slightly. Rear camber will get more negative than the front. Also, your toe will come in. Go look at the geometry and just picture what happens to the steering arm when the camber get more negative.
When making more negative camber, the toe will go in, when making more positive camber, the toe will go out. But it can be changed by using the tie rod.
Toe out will eat your tires more than camber.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline
Old 03-28-2005   #8 (permalink)
nindoo
I can't seem to find a link to alignments. There was a nice outside information someone posted once. It was one of you suspension gurus that posted it.
muzhik that link was a good read.
nindoo is offline
Old 04-07-2005   #9 (permalink)
2K1Civic17"Gabe
2K1Civic17"Gabe's Avatar
Send a message via AIM to 2K1Civic17"Gabe
haha, after this was asked like 95-100 times at least, people still want more clarification. Just get a damn camber kit, figure out how to install it, its simple, dont ask how to install it, find the DIY on here if you must. Than go get an alignment, and your good to go. get an alignment every 6mo-1yr. I leave my camber set at -1 on the rears, it doesnt eat them up noticeably at all like -3 does. -1 is a good setting for a little extra grip on the road.
Heres a visual for people who dont know what camber is still. When you lower your car, your tires do this. Same thing when your shocks travel down.
// \\ << Negative camber (when you lower your car)
\\ // << Positive camber
l l l l << wow, they look good after a camber kit was installed and adjusted
You want to straighten them back up, like this l l l l. Got it good, lol
__________________
'93 Impreza L AWD 1.8 Boxer
Mods:
-KYB GR2's struts with Eibach ProKit springs w/OBX Camber Kit fr/rr
-Brembo Rotors/EBC Greenstuff pads
-04WRX wheels with Bridgeston Potenza RE-92's
-FU Strut Bar
-04 WRX axleback
-JDM "i" grille (painted emblem black)
-Fog Lights
-2.5RS front seats
-custom Shift Knob/Boot/CD player/amp/subs/mids
2K1Civic17"Gabe is offline
Old 04-13-2005   #10 (permalink)
mystery
New Member
mystery is an unknown quantity at this point
Send a message via AIM to mystery
where is a good place to purchase camber kits? one more question. say i get new suspension.. would i still want to get a camber kit? as of now. i know i need one cause not having a kit on. its eating the crap outta my tires. my rear tires are like this // \\.... it sucks.
mystery is offline
Old 05-27-2005   #11 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
if i take my springs off, will the camber kit mess up the car? How do I align the camber kit once I install it?
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is online now
Old 08-02-2005   #12 (permalink)
shroomster
Crayons taste like purple...
shroomster's Avatar
shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold shroomster is a splendid one to behold
ok pimp slap me I've been a bad boy
HA! is there a kit that works better than another or will they all give you the same performance (camber kits) WTF? only one search every 30 seconds? I'm looking through the forums right now for a DIY on camber kits so I'm bearing my face for the slap, but anyways I'd like to know at least how long it'd take to put them on or a diagram or something of how they look on the car?
__________________
iPR #7
40 Gig Creative Labs Nomad Jukebox ZEN Xtra
Diana Ham.....rest in peace.....
shroomster is offline
Old 08-02-2005   #13 (permalink)
robbclark1
robbclark1's Avatar
I know you are new schroomster, but there are so many ways to find information. It takes about 1 hour if none of the bolts are frozen. If you are installing suspension, then install it all at once. Wait for the springs to settle (about a week or so) and get an alignment.
If you search the members rides rides you can find pictures
Hotchkis is probably the best designed but will cost you. SPC is the preferred one, followed by ingalls. They all do the same thing, but you have to worry about them "freezing up."
http://www.spcperformance.com/PerfTe...rojHon1_A.html
http://www.spcperformance.com/PerfPa...art_67230.html
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.HTML
__________________
Suspension FAQ
Autocross FAQ
Old 08-17-2005   #14 (permalink)
Boilermaker1
Jap-Euro Fusion
Thats the hotchkis difference. The barrel is 7075 T6 Aluminum... so you DO NOT have to worry about the barrel rustwelding itself to the ends of the arm, they know it, so they can charge you for it. The hotchkis arms are FAR less likely to jam on you than the others.
__________________
2002 Civic
Old 08-23-2005   #15 (permalink)
ohnoitssoysauce
Senior Member
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
Send a message via AIM to ohnoitssoysauce
i heard that we only need a rear camber kit. is that true for 01
ohnoitssoysauce is offline
Old 08-24-2005   #16 (permalink)
robbclark1
robbclark1's Avatar
Quote:
'Honestly, if you can get your camber back to about -1.5 degrees or less without the use of camber bolts and still get 0 toe, I wouldn't even bother with the bolts.'
read the post. There isn't active camber gain in the front, but it is just good to have the adjustability. Besides most of the sets come in a kit with front and rear.
__________________
Suspension FAQ
Autocross FAQ
Old 10-03-2005   #17 (permalink)
Honda2k4
Super Member
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
are there different camber kits for 01-04 civics? depending if its an 01, 02, 03, or an 04? or is it 1 size fits all?
Honda2k4 is offline
Old 10-03-2005   #18 (permalink)
Boilermaker1
Jap-Euro Fusion
1 size fits all rears. Theres 2 front sizes.
__________________
2002 Civic
Old 10-03-2005   #19 (permalink)
Honda2k4
Super Member
Honda2k4's Avatar
14mm and 16mm?
Honda2k4 is offline
Old 10-03-2005   #20 (permalink)
robbclark1
robbclark1's Avatar
Quote:
Originally Posted by Honda2k4
14mm and 16mm?
yes, 14mm 01-02
16mm 03-05
__________________
Suspension FAQ
Autocross FAQ
Old 10-04-2005   #21 (permalink)
Kyle23
Super Member
Kyle23 should not be trusted Kyle23 should not be trusted
I have some subs that have caused my camber to almost be in the red (honda dealership and they cant fix it any further) I need to bring the back up a litte b/c I dont like the negative camber on the rear. Any suggestions?
Kinda looks like ^. just not nearly as bad
Kyle23 is offline
Old 10-04-2005   #22 (permalink)
robbclark1
robbclark1's Avatar
he has bags and using a camber kit would be pointless
IF you don't have a camber kit, get one. If you do have a camber kit, take it off and change the position of the arms to get more positive camber out of it.
__________________
Suspension FAQ
Autocross FAQ
Old 10-04-2005   #23 (permalink)
truehonda
Ultimate Member
truehonda has a spectacular aura about truehonda has a spectacular aura about
Send a message via AIM to truehonda
:cough: We have about 100 in stock :cough:
Seriously people. A $500+ of tires is not worth $150 not spent and having to buy new ones in about 2 months.
truehonda is offline
Old 10-05-2005   #24 (permalink)
CivicMexicano
El Pinche Turbo Mexicano
CivicMexicano's Avatar
CivicMexicano is an unknown quantity at this point
I was about to buy an Eibach Camber kit, its also aluminium, anyone here use it, or recomend it?
Also how much does th Hotchkis one cost?
__________________
Speed Is, Freedom of the Soul.....
CivicMexicano is offline
Old 10-13-2005   #25 (permalink)
truehonda
Ultimate Member
Eibach is ok, Hotckis is expensive. Thats why we sell SPC, higher quality than eibach or equal and cheaper than hotchkis.
Eddie
Old 10-14-2005   #26 (permalink)
robbclark1
robbclark1's Avatar
Quote:
Eddie
Eibach is SPC. I hvae heard of people buying Eibach camber kits and getting SPC ones.
__________________
Suspension FAQ
Autocross FAQ
Old 10-14-2005   #27 (permalink)
CivicMexicano
Taht odd, an auction on Ebay says theyre Alumimun, i thought SPC were steel...
__________________
Old 10-14-2005   #28 (permalink)
truehonda
Ultimate Member
They are similar because they are produced in same factory. In terms of quality, I like SPC because of their customer service which is part of quality to me.
Old 10-27-2005   #29 (permalink)
Gangsta Dave
People Eating Tasty Animals PETA
Gangsta Dave's Avatar
Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all Gangsta Dave is a name known to all
Eddie
I have spc on the rear and they work fine for me def worth buying. It actually makes the car look better imo. the wheels aren't all jacked lookin / \
Gangsta Dave is offline
Old 12-10-2005   #30 (permalink)
jeffsta17
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Send a message via AIM to jeffsta17
This thread is very helpful thanks guys!
jeffsta17 is offline
Closed Thread
Tags
aluminium , bolts , camber , hondatech , install , kit , obx , review , spc , wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Decided what coilovers to get: KW's opto_isolator Suspension Performance 156 12-16-2003 08:44 PM
Camber Kits Juancho007 Suspension Performance 1 07-06-2003 05:03 PM
How low? scsGrumPyDriveR Canada East 4 05-13-2003 11:05 PM
Alignment on lowered vic ? BoYrAcEr Honda Civic DIYs and Civic Tech Chat 18 04-17-2003 11:43 PM
camber kit question TuffVietta Suspension Performance 3 10-16-2002 02:58 AM
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
All The Suspension Info You Need!! Please Read!!!
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
