Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 06-20-2006   #46 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Quote:
Originally Posted by draganjr
What about no drop and tires from 185s to 205s... would I need a kit?
If you want the adjustability then go for it. Otherwise, it isn't necessary.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline
Sponsored Links
Old 06-21-2006   #47 (permalink)
draganjr
Senior Member
draganjr's Avatar
draganjr is an unknown quantity at this point
Thank you.
I placed some on my Acura Intgera, but is was lowered and had 17".
I does work.
but I was sure on the not lowering and but bigger tire thing.
Now I know and thanks.
__________________
Heatware
PayPal Verf.
draganjr is offline
Old 07-12-2006   #48 (permalink)
QRTR
Member
QRTR's Avatar
QRTR is an unknown quantity at this point
has anyone on this board use a rear lower camber kit instead of the upper ones to eliminate
the tires from rubbing the fenders...
QRTR is offline
Old 07-15-2006   #49 (permalink)
robbclark1
robbclark1's Avatar
There is no such thing as a rear lower camber kit. It is a camber arm. Look at the suspension and you will see you can't change the camber from the bottom.
__________________
Suspension FAQ
Autocross FAQ
Old 07-25-2006   #50 (permalink)
TheGeneralLee
Member
TheGeneralLee's Avatar
TheGeneralLee can only hope to improve
Maybe Somebody Already Answered This But What If You Get Coils? Do I Still Need The Camber Kit? On A Sedan
__________________
http://i27.photobucket.com/albums/c196/autobotleader/Omerta.jpg
R.I.P. 7thgen Club Member #9
TheGeneralLee is offline
Old 07-26-2006   #51 (permalink)
ian01ex
Member
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Yeah, Camber kit is different from the coilovers. If you change your drop you need to take it in and have the camber adjusted but if you are staying where you are at then they will do you good.
ian01ex is offline
Old 07-26-2006   #52 (permalink)
HonCivX02
Super Member
HonCivX02 is an unknown quantity at this point
Send a message via AIM to HonCivX02 Send a message via Yahoo to HonCivX02
Quote:
For the love of god, stop asking. I thought 3 times a day was enough, apparently not. I suppose its better to educate yourselves before rather than later, but if you use the search function like you're supposed to, and you do your research before you spend upwards of $800 on a drop done right, then you should figure out in 5 minutes or less that YES YOU NEED A CAMBER KIT. For mild drops (less than 1.25") you probably don't, but you may opt for one just to be safe. I have a friend dropped on Pro-kits, no camber kits, and he's got nearly spec alignment numbers. Any lower, you probably want one if you value your tires. While toe kills tires more than camber does, you can only adjust toe so much (especially in the rear). Toe and Camber settings effect eachother, so you need to have the adjustability to get your toe to 0. In the front, your camber can be as much as -2.25 before your steering rods run out of travel, but -2.25 will probably do something to your tires.
Rear kits are a threaded adjustable length upper control arm. It bolts in with 3 bolts, 2 on the body, one on the back of the drum and you can adjust its length to control the angle of the wheel. This part is critical as the rear is far more prone to camber changes than the front (nature of a multi-link double wishbone). You need it. There's numerous kits available. SPC and Ingalls probably make the most inexpensive and widely used ones, they're $110-140 depending on the store... you can spend plenty more if you want, I've seen them go as high as $400 for JDM brand super adjustable (5 degree) arms, but they're unnecessary for basic adjustment. A normal range (+2/-3 degree) kit will take care of any reasonable drop.
Front kits... well 2 options. Camber or Crash Bolts that are smaller than the stock crash bolts give you additional range of motion by freeing space up in the knuckle hole to set the knuckle more upright. They're $20-30 bucks, but they have plenty of flaws. If you drive hard, they have a tendency to move and not hold their setting. As a result, frequent alignments (every few months) are a necessity. If you're looking at any sort of racing, I don't recommend them unless the rules specify that this is the only way you can change your camber. Honestly, if you can get your camber back to about -1.5 degrees or less without the use of camber bolts and still get 0 toe, I wouldn't even bother with the bolts.
Camber Plates are the better alternative. They replace the upper mount of the strut with a sliding bearing surface and the entire suspension angle changes from the top. This allows the use of stock crash bolts which hold their setting much better, it also provides a better reaction from the corner because the wheel is aligned with the suspension like its supposed to be (scrub radius unchanged). Plates run from about $200 to $400, there's a few available.
I don't think I missed anything.... if you have a question about anything that has been posted here or still do not understand, then post it IN THIS THREAD.
Woosah my friend.... WOOOOSAAAAHHH
HonCivX02 is offline
Old 07-26-2006   #53 (permalink)
notoriouspyro
Crack kills... But then again... So do I...
notoriouspyro's Avatar
notoriouspyro is a jewel in the rough notoriouspyro is a jewel in the rough notoriouspyro is a jewel in the rough notoriouspyro is a jewel in the rough
Send a message via AIM to notoriouspyro Send a message via Yahoo to notoriouspyro
Ok... I got bags but I'm suffering from positive camber even when not locked up. Is there anything that I can do? I had heard that when bagged you can't get a camber kit and I'm pretty much screwed on that one, is that true?
__________________
Team Notorious
It's not a hobby, it's a way of life...
teamnotorious.net
notoriouspyro is offline
Old 08-10-2006   #54 (permalink)
bengtat
New Member
bengtat is an unknown quantity at this point
camber
Great info!! Exactly what I need to know... Now all I need is -1 camber for the front to give me better confidence in cornering...
Thanks
bengtat is offline
Old 08-10-2006   #55 (permalink)
robbclark1
robbclark1's Avatar
Quote:
sorry for the late answer. Think of it this way...with bags you are constantly changing the height and the camber. The rear is arm, so any time you change the height, the arm stays put and you can't do anything about camber unless you get under and adjust it. A camber kit with bags is pretty much pointless, but again bags are pointless unless for show.
__________________
Suspension FAQ
Autocross FAQ
Old 01-16-2007   #56 (permalink)
vietskittle
New Member
vietskittle is an unknown quantity at this point
Red face
Quote:
mmk... so, i'm getting these Eibach Coil over Shock Absorbers...
2005 Civic Honda Coil Over Shock Absorber
these are actually coilovers right? not just shocks? because i am dumbfounded to find them so cheap if that were case. i feel like there's a catch. like, its just shocks or something. i mean, 265 (w/shipping!) for COILOVERS?! that is just insane!... i was going to get springs, shocks, and DEF cambers, but im worried that these "shock absorbers" are not what i'm expecting, although they sure look and seem like more than what i want.
so what you're saying is -if i were to get these and just keep them at the same height adjustment i wouldn't have to change the camber? but no matter WHAT, even with coilovers, a camber is ALWAYS needed, is it not?
because it just doesn't sound smart to not get a camber kit if there is a drop involved, especially a serious one.
~sandyy
-p.s.
thank you everyone! for without you, i wouldn't be able to learn about all this shiznit i wanna know... =]
vietskittle is offline
Old 01-16-2007   #57 (permalink)
AmbulanceMonkee
AmbulanceMonkee's Avatar
AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned AmbulanceMonkee should not be questioned
Send a message via AIM to AmbulanceMonkee
Once you get your coilvers set at the drop you want, you will need to set the camber. Then, if you change the height on the coilovers, you will need to adjust your camber.
As for those coilovers, they say they're sold in a set of four, and they mention the springs and shocks in the description, so yeah, it looks like it comes with everything. I have no idea why the price is that low. I'd call them and ask some questions before I bought them, tho.
__________________
Life is hard. It's harder when you're stupid.
Search, and learn.
Quote:
Originally Posted by modoman View Post
the same curiosity some people have with the minds of serial killers, i have with ricers.
Quote:
Originally Posted by DeX View Post
You don't have a sport car.
"There are more than 550 million firearms now in circulation, one for every 12 people on the planet. The only question, is how can we arm the other 11."
newest pics of my car.
AmbulanceMonkee is offline
Old 01-16-2007   #58 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
^yea those are pretty cheap man.....i mean REALLY CHEAP
sl33pyriceboi is offline
Old 01-17-2007   #59 (permalink)
vietskittle
New Member
awesome... that's what i thought. thanks =]
Old 01-23-2007   #60 (permalink)
EBP EX
Member
EBP EX's Avatar
EBP EX will become famous soon enough EBP EX will become famous soon enough
Send a message via AIM to EBP EX
Ok, this is going to sound like a really, really stupid question. For the rear camber kit, after I install it, I can just take it to an alignment shop and they'll be able to adjust it to the proper settings? I have no idea what takes place in an alignment, I just know that they put it on an alignment rack and put some stuff into a computer that controls it, so I figured the machine does all the work. I guess I'm confused as to how the machine could adjust the camber kit.
__________________
'94 San Marino Red B20B Civic Coupe
'08 Fiji Blue Pearl K20Z3 Civic Coupe
EBP EX is offline
Closed Thread
Tags
aluminium , camber , hondatech , kit , obx , review , spc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Decided what coilovers to get: KW's opto_isolator Suspension Performance 156 12-16-2003 08:44 PM
Camber Kits Juancho007 Suspension Performance 1 07-06-2003 05:03 PM
How low? scsGrumPyDriveR Canada East 4 05-13-2003 11:05 PM
Alignment on lowered vic ? BoYrAcEr Honda Civic DIYs and Civic Tech Chat 18 04-17-2003 11:43 PM
camber kit question TuffVietta Suspension Performance 3 10-16-2002 02:58 AM
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
