Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-15-2004   #1 (permalink)
rijowysock
ThE FaMiLy SeDaN
rijowysock's Avatar
Send a message via AIM to rijowysock
when u tie up ur calipers... to change springs you...?
yanno how when u change springs or basically ur removing the front strut.... u tie up ur caliper and etc so that it doesnt droop and therefore doesnt make it so ur CV's pop out of place.. what did u tie off to? im j/w last time we just held it but this time ima be doing2 cars and ima need something to hold it up.. and i was jw
thanx
riley
rijowysock is offline   Reply With Quote
Sponsored Links
Old 12-15-2004   #2 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
I took a couple of bolts and used some of the existing holes inside the fender well then tied my string around them.. works great. Just becareful which hole you use.. lol
flotsamm is offline   Reply With Quote
Old 12-15-2004   #3 (permalink)
civic01vtec
The only job I need is a blowjob
civic01vtec's Avatar
civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned
Send a message via AIM to civic01vtec
i think i used zipties........but i forget
__________________
The 2nd Amendment America's original homeland security
'01 Civic EX -- boosted
'99 Chevy 2500 Ext. cab 4x4 with a
454 <--- under 10 mpg
'02 Chevy Trailblazer
civic01vtec is offline   Reply With Quote
Old 12-15-2004   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
I tied it to the strut bar... of course, you need a strut bar to do this.
You probably could also string it to a ceiling joist if you got it, other people just use the side of a tire and let the brake rest on it.
Boilermaker1 is offline   Reply With Quote
Old 12-16-2004   #5 (permalink)
Vinnie
Super Member
Vinnie's Avatar
Vinnie should not be trusted Vinnie should not be trusted Vinnie should not be trusted Vinnie should not be trusted
Its a good thing ur thinking about this now...I just installed my teins and on one side the CV popped out. Took a bit to get bak in...
Vinnie is offline   Reply With Quote
Old 12-16-2004   #6 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Just slip a tire underneath it. I never tied my off, just propped up against a tire.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 12-16-2004   #7 (permalink)
TeLLy
Yes, it's an Acura EL
TeLLy's Avatar
TeLLy is a name known to all TeLLy is a name known to all TeLLy is a name known to all TeLLy is a name known to all TeLLy is a name known to all TeLLy is a name known to all TeLLy is a name known to all
I stuck a tire under as well.
TeLLy is offline   Reply With Quote
Old 12-16-2004   #8 (permalink)
4drcivic2k1
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Zip ties usually. Or duct tape. You can put a tire under it too.
4drcivic2k1 is offline   Reply With Quote
Old 12-16-2004   #9 (permalink)
dj02
Post Master General
dj02's Avatar
dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all
Send a message via AIM to dj02
Quote:
Quote:
werd!
__________________
-OuTuViT-
"Computer games don't affect kids,
I mean if Pac-Man affected us as kids,
we'd all be running around in darkened rooms,
munching magic pills and listening to repetitive electronic music."
-Kristian Wilson, Nintendo, Inc, 1989
it has been said that sometimes,
something as small as the flutter of a butterflys wing
can ultimatly cause a typoon
half way around the world
-chaos theory
The Edge... there is no honest way to explain it
because the only people who really know where it is
are the ones who have gone over.
-Hunter S. Thompson
dj02 is offline   Reply With Quote
Old 12-16-2004   #10 (permalink)
tavdawg
Member
tavdawg's Avatar
tavdawg is an unknown quantity at this point
Send a message via AIM to tavdawg
bungee straps work well to
tavdawg is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Jdm Dc5r Problems cvc2f2f Forced Induction and Swaps 9 06-17-2004 02:00 AM
Polyurethane Bushings --COMING SOON!-- dirtEsanchez Suspension Performance 31 04-19-2003 07:43 AM
How Much? AEM: Four Piston Caliper Big Rotor Brake Kit SDE Other Honda Civic Parts and Products 7 03-05-2003 09:36 PM
Big Brake Kit question 555 Wheels,Tires & Brakes 12 08-29-2002 12:44 AM
Painted My Calipers *Pics* mike Honda Civic Member's Rides 25 06-26-2002 09:08 AM
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
All The Suspension Info You Need!! Please Read!!!
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
