Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-29-2004   #1 (permalink)
wawawang
New Member
wawawang is an unknown quantity at this point
diy camber adjustment
the camber gauge im going to purchase
Do you guys think that this is the correct gauge to measure my camber. I have eibach sportlines and I got the bolt cambers for my front end. Im not going to get cambers for the rear for a while. I was going to use this gauge to adjust the front camber by adjusting the bolts. So what do you think? If that gauge is not correct can you guys suggest to me a good one. Thanks...
wawawang is offline   Reply With Quote
Sponsored Links
Old 09-29-2004   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
No it is not.... DO NOT BUY THIS.
(Not to mention you can pick that exact thing up at Harbor Freight tools for about $5
Pick up this instead.
http://www.stockcarproducts.com/long9.htm
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 09-29-2004   #3 (permalink)
wawawang
New Member
Thanks for the fast response. Can you explain why that one is not acceptable.
Old 09-29-2004   #4 (permalink)
rickinthescv
Diamond Member
rickinthescv's Avatar
rickinthescv will become famous soon enough rickinthescv will become famous soon enough
Send a message via AIM to rickinthescv
It is a perfectly acceptable tool to use in order to either: set the initial camber, then take it to an alignment shop to finish it up properly; or to find out how far it is off to order the correct set of alignment bolts.
For example, you use it to set the camber roughly. This will allow you to ride to the shop in a few days and get the alignment done by a laser, which is far more accurate. The tool can only get it close.
Or you may use it to find out if you need one pair of bolts (usually 1 degree off) or two pairs of bolts (2-3 degree off).
Now just realize that no hand held tool is enough to go against a laser machine that costs thousands of dollars. Plus lowering a car will have other items out, toe in, caster, and camber.
__________________
2001 Civic EX Coupe
Satin Silver
Eibach Sportlines
RH Evolution C2
Kumho 205/40HR-17
rickinthescv is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
