Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-19-2004   #1 (permalink)
nunzio42
Super Member
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
instalation question
aight i am thinking about getting some tokicos and sportline springs, for a full replacement of the stock setup, will this install be relativly easy, i did some search and the tokicos have to be drilled to fit an 03 is this with a standar drill? I am in south florida and have been quoted like 200+ dollars just for the install. This fair? Or does anyone know of a place i can go to for a better price?
Only thing that i think i may need is a spring compressor to get the springs on the struts? i was thinking about simply replacing just the springs but i was was worried that without a spring compressor i would not beable to complete the install and thus have a car with no suspension on it......hard to do much of anything with that......
Thanks for the help!
nunzio42 is offline   Reply With Quote
Sponsored Links
Old 09-19-2004   #2 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
If your mecahnically inclined and have a good set of hand tools you can do it. Its not that hard of an install though can be time comsuming the first time. Make sure that you remember the location of the upper spring perch and upper mount before taking the strut assembly apart. This is whats called indexing, where you draw a vertical line down the side of the strut marking the parts for reference to make it easier to reassemble.
To do it right and not risk any harm to both you and your car, you'll need a spring compressor, tie rod separator(not the pickle fork style), floor jack, jack stands and a torque wrench.
If good at taking stuff apart and putting it back together again with the right tools I say go for it. If not 200 bucks isnt that bad of a deal assuming the person knows WTF theyre doing.. especially with our suspension.
flotsamm is offline   Reply With Quote
Old 09-19-2004   #3 (permalink)
cubanmike26
cubanmike26's Avatar
cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light cubanmike26 is a glorious beacon of light
I agree with Flotsamm. The install should not be so hard, although the first time you do it will always be the worst. Have you seen the mounting springs DIY from Mex; if not, here the link(http://www.7thgencivic.com/forums/sh...ad.php?t=86545)
I thought Tokikos would be a perfect fit but I guess I was wrong. On some other thread I remember reading that you have to extend the knuckle bolt size to 2mm larger than what it is, and then it'd work fine, but the bad thing about extending is that this would void the warranty from tokico. I'm not entirely sure about this, I have to do more reasearch.
cubanmike26 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
