Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-13-2004   #1 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
Tie Bars and Sway bars
I do not understand how lower tie bars and sway bars affect the physics of your car?
Does the tie bar affect the handling or is it just there to reduce strain on the chases?
If you were to put a thicker rear sway bar and a tire bar in the rear, would it make the tail end of the car wild and reduce body roll?
Lets say your not Auto Xing and your daily driving includes predictable long smooth turns, isn't body roll a good thing, at least in some cases? They bank the road on those Nascar tracks
nindoo is offline   Reply With Quote
Sponsored Links
Old 09-13-2004   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Tie bars (strut bars included) are just chassis reinforcements. They simply allow the suspension to work the way it was designed to work, Better. The car will feel better, but the cars handling will have remained pretty much the same. Just note that for the best handling you want a very stiff chassis. because a Flexible chassis esentially acts like a very large Un-Dampered spring, making fine tuning the handling of your car near impossible.
The Anti-roll bars will actually change the handling Charateristics of the car...
If you increase the size of the rear bar, you will decrease understeer and increas oversteer. How much depends on how larger of a bar you get, what the rest of your suspension is set up like and how hard you are pushing the car (are you pushing the car enough to notice the difference between a 22mm and 25mm rear bar).
regarding body roll... I've allways said that body roll shouldnt be your primary concern when tuning your car handling. People seem to get hung up on the idea that a car that has little or no body roll is a well handling car, when that is just not true. you could build a car that has no body roll and handles like CRAP, and you could build a car that has lots of body roll and handles Very well. Body roll its self only does 2 things that hinder handling. 1. it annoys the driver(you can learn to ignore it) and 2. it causes camber loss (which can be copensated for by running negitive camber).
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 09-13-2004   #3 (permalink)
nindoo
With that note, why do people install tein basic coilovers? does it help your tires stick better? Would a daily driver notice a performance improvement, or is it only noticed at the track where it could help shave fractions of a seconds?
Old 09-13-2004   #4 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Quote:
They would be an improvement in handling, thanks to the higher spring rates (Reducing bodyroll/camber change) and by the difference in spring rates on the front vs the rear, influencing the Oversteer/understeer charateristics of the car. tie that in with MUCH better valving on the Dampers (Shocks) and you have a good performance boost over stock. HOWEVER, the Tein Basic and SS, are both designed for the street. Meaning that although they improve handling greatly over stock, the are still designed with the average joe driver in mind... meaning they are still designed to make the car understeer at its limits. Keeping You and grandma safe.
For track use, I'd say that The Tein Basic is best to be avoided (Thanks to not having adjustible dampers) and the SS would probably be a good comprimise between decent Street maners and acceptible handling on track.
If I were to build my car for Track use exclusivly... Personally I wouldnt get Any Pre-assembled coilover. I'd be looking at fining a good Damper (Re-valved Konis?? Moton Double adjustibles???) that fit my budget. And then tie them in with a good Linier rate spring, preferably on an adjustable perch (Like Ground Control).
__________________
Las Vegas SCCA
Randy Pobst
Old 09-13-2004   #5 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Case in point about the body roll...
That was taken Yesterday... and yes its me.
Notice that there is a good amount of body roll, but also notice that the front tire is still flat on the ground.... Thanks to me running about -2.5 deg camber on the front of the car.
__________________
Las Vegas SCCA
Randy Pobst
Old 09-13-2004   #6 (permalink)
sKwiD
I Queef > You
sKwiD's Avatar
sKwiD is on a distinguished road
Send a message via AIM to sKwiD
-2.5?? Only for track use right?
__________________
A shart is a fart with a little more determination.
sKwiD is offline   Reply With Quote
Old 09-13-2004   #7 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Quote:
Nope thats daily driven...
Tire wear hasnt been a problem, as I got 60,000 Miles out of my last set of street tires. mostly because I have 0 toe front and rear. Toe will eat tires MUCH faster then camber settings, and there is a common misconseption around that when people lower their cars with out camber kits or alignments that its the Camber that kills the tires quickly when its actually the added Toe that does them in.
__________________
Las Vegas SCCA
Randy Pobst
Old 09-13-2004   #8 (permalink)
nindoo
When you say re-valved, is that mean they are shocks that have been used and rebuilt or something?
Do you know if its possible to buy blown front struts for our gen civics. I'm hesitent on butchering my stock struts to install the konis.
The yellow konis I've seen have a valve on them, setting from soft to firm. Is it right to say that the firmer you set them the better the handling?
Old 09-13-2004   #9 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Re-valving is when you have Koni or one of their approved service shops Up valve the dampers. to make them stiffer. (Note that Konis are 100% repairable too, and there are many service shops equiped to Repair and/or revalve Koni shocks)
You may be able to find some stock struts.... ask around here (in the Marketplace) and you may find someone tring to get rid of their stock parts.
Firm valving absolutly does not mean better handling.... Shocks primairly influence corner entry and exit. And they do so by controling how fast weight gets transfered off of and to the tires. so by altering the valving you control how fast the weight of the car shifts around the car.
Almost all single adjustible dampers only allow you to adjust the Rebound dampering.. I.e. how fast the shock allows the spring to expand. this is fine, because rebound affects handling more then BUmp (how fast the damper lets the spring compress, so Bump affects ride quality more)
Basic concept with single Rebound adjustible dampers: Increase the Rebound Valving on the side of the car you want to have stick LESS. so, if the car is understeering, then you either Decrease the rebound on the front of the car OR you increase the valving on the Rear of the car. Do the opposite if the car is oversteering.
Just an example. On the street I run my Konis Full soft on the front, and about 1/2 to 1 turn up from full soft on the back. when I autocross I run the front at full soft and the rear 1/4 turn from full stiff, and then adjust from there to suit the course.
__________________
Las Vegas SCCA
Randy Pobst
Old 09-13-2004   #10 (permalink)
nindoo
Zzyzyx stuff is starting to get technical.
What is the difference be between the sway bars on an RSX Type S and A civic EX coupe?
What makes the RSX chassis and suspension superior to ours if it is?
Old 09-13-2004   #11 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
the chassis is the same besides some slight mods with axles and tie rods. They just have better shocks and spring. It depends what year EX coupe.
http://www.sceniccityonline.com/arti...ybarspecs.html
RSX/RSX-S have 19mm rear sways, and RSX-R has 22mm rear sway. Si has a 17mm rear sway. The front sway bars are about 16mm I believe for all of them, but don't quote me on that.
Have you read the FAQ?
As much as we can get technical with you, you should have a basis of what is going on. If you are really interested, read all you can. Check out other racing forums like www.sccaforums.com and READ THIS!
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 09-13-2004   #12 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
The si has a 25.4mm front bar like the early 7th gens did. and I believe the early Si had a 15mm rear bar, the newer ones have the 17mm
The RSX, has a 23mm front bar.
Thats good info Robbclark posted, be sure to check up on some of it.
BTW, I have an 01 EX.. Started with a 25.4mm front bar and 12mm rear bar, over the last 2 years its ran with a 19mm rear bar, No front bar, and finally to what it has today a 15.9mm front bar and a 25.4 mm rear bar. (Note that this car is setup for autocross)
__________________
Las Vegas SCCA
Randy Pobst
Old 09-14-2004   #13 (permalink)
nindoo
Very informative stuff.
Wow your set up is a little extreme, compared to stock.
Why did Honda drastically change the set up on the 03 in comparison with the 02. I'm thinking the suspension was tuned for north americans because Honda thought we wanted a softer more comfortable ride over bumps.
Old 09-14-2004   #14 (permalink)
robbclark1
robbclark1's Avatar
It is to induce understeer which is safer for stupid drivers.
__________________
Suspension FAQ
Autocross FAQ
Old 09-14-2004   #15 (permalink)
nindoo
You guys are very patient; I've seen this topic has been covered numerous times. My car has 25.4/13.0 set up I was wondering if a 19mm rear sway bar would reduce understeer.
I know Zzyzx you don't like this setup but I am a novice and I think with your setup I'd break my face lol.
Tags
2001 , 2007 , bar , bars , camber , civic , coupe , daily , driver , forum , honda , install , installation , intence , lower , sway , tie , toe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Site Supporters
aluminum radiator
Honda car spoilers
